Public Types | Public Slots | Signals | Public Member Functions | Friends | List of all members
pqPipelineModel Class Reference
This class is the model for the PipelineLine browser tree view. More...
#include <pqPipelineModel.h>
Inherits QAbstractItemModel.
enum  ItemType {
  Invalid = -1, Server = 0, Proxy, Port,
  Extractor, Link
enum  ItemRole { AnnotationFilterRole = 33, SessionFilterRole = 34 }
Public Slots
void addServer (pqServer *server)
 Called when a new server connection is detected. More...
void removeServer (pqServer *server)
 Called when a server connection is closed. More...
void addSource (pqPipelineSource *source)
 Called when a new source/filter/bundle is registered. More...
void removeSource (pqPipelineSource *source)
 Called when a new source/filter/bundle is unregistered. More...
void addConnection (pqPipelineSource *source, pqPipelineSource *sink, int)
 Called when new pipeline connection (between two pipeline objects) is made. More...
void removeConnection (pqPipelineSource *source, pqPipelineSource *sink, int)
 Called when new pipeline connection (between two pipeline objects) is broken. More...
void setView (pqView *module)
 Updates the icons in the current window column. More...
void addConnection (pqServerManagerModelItem *source, pqExtractor *sink)
 Called to update extractor connections. More...
void removeConnection (pqServerManagerModelItem *source, pqExtractor *sink)
void addExtractor (pqExtractor *)
 Add/remove extractor. More...
void removeExtractor (pqExtractor *)
Signals
void firstChildAdded (const QModelIndex &index)
void childWithChildrenAdded (const QModelIndex &index)
 pqPipelineModel (QObject *parent=nullptr)
 pqPipelineModel (const pqPipelineModel &other, QObject *parent=nullptr)
 Makes a copy of a pipeline model. More...
 pqPipelineModel (const pqServerManagerModel &other, QObject *parent=nullptr)
 Creates a pipeline model from a server manager model. More...
 ~pqPipelineModel () override
bool isEditable () const
 Gets whether or not the model indexes are editable. More...
void setEditable (bool editable)
 Sets whether or not the model indexes are editable. More...
void setSelectable (const QModelIndex &index, bool selectable)
 Sets whether or not the given index is selectable. More...
bool isSelectable (const QModelIndex &index) const
 Gets whether or not the given index is selectable. More...
void setSubtreeSelectable (pqServerManagerModelItem *item, bool selectable)
 Sets whether of not an item subtree is selectable. More...
QModelIndex getNextIndex (QModelIndex index, const QModelIndex &root=QModelIndex()) const
 Gets the next model index in the tree. More...
pqView * view () const
void setModifiedFont (const QFont &font)
 Sets the font hint for modified items. More...
void enableFilterAnnotationKey (const QString &expectedAnnotation)
 Store the annotation key that will be used when "this->data( ... , pqPipelineMode::AnnotationFilterRole)" get called. More...
void disableFilterAnnotationKey ()
 Disable annotation key, so "this->data( ... , pqPipelineMode::AnnotationFilterRole)" will always return a QVariant("true") More...
void setAnnotationFilterMatching (bool matching)
 Set wether annotation filter should display matching or non matching sources. More...
void enableFilterSession (vtkSession *session)
 Store the session key that will be used when "this->data( ... , pqPipelineMode::SessionFilterRole)" get called. More...
void disableFilterSession ()
 Disable annotation key, so "this->data( ... , pqPipelineMode::SessionFilterRole)" will always return a QVariant("true") More...
QAbstractItemModel Methods
int rowCount (const QModelIndex &parent=QModelIndex()) const override
 Gets the number of rows for a given index. More...
int columnCount (const QModelIndex &parent=QModelIndex()) const override
 Gets the number of columns for a given index. More...
bool hasChildren (const QModelIndex &parent=QModelIndex()) const override
 Gets whether or not the given index has child items. More...
QModelIndex index (int row, int column, const QModelIndex &parent=QModelIndex()) const override
 Gets a model index for a given location. More...
QModelIndex parent (const QModelIndex &index) const override
 Gets the parent for a given index. More...
QVariant data (const QModelIndex &index, int role=Qt::DisplayRole) const override
 Gets the data for a given model index. More...
bool setData (const QModelIndex &index, const QVariant &value, int role=Qt::EditRole) override
 Sets the role data for the item at index to value. More...
Qt::ItemFlags flags (const QModelIndex &index) const override
 Gets the flags for a given model index. More...
Object Mapping
pqServerManagerModelItem * getItemFor (const QModelIndex &) const
 Given the index, get the pqServerManagerModelItem it represents. More...
QModelIndex getIndexFor (pqServerManagerModelItem *item) const
ItemType getTypeFor (const QModelIndex &index) const
 Gets the type for the given index. More...
Friends
class pqPipelineModelDataItem
class ModifiedLiveInsituLink
The pqPipelineModel class is used to represent the pipeline graph as a tree.
pqServerManagerModel models the vtkSMProxyManager for the GUI. The vtkSMProxyManager maintains all proxies and hence it is difficult to detect/trasvers pipelines etc etc. The pqServerManagerModel provides a simplified view of the Server Manager. This class takes that simplified "model" and transforms it into hierarchical tables which can be represented by the Tree View.
The top of the hierarchy is the server objects. Each connected server is added to the root node. An object with no inputs is added as a child of its server. The outputs of an object are added as its children. Objects with multiple inputs present a problem.
Instead of repeating information in the tree, the object with multiple inputs is moved to the server. All its outputs are treated normally and added as children. In place of the object with more than one input, a link object is placed in the child list of the input objects. The link item represents a connection instead of a pipeline object.
Definition at line 55 of file pqPipelineModel.h.
◆ ItemType
Enumerator
Invalid
Server
Proxy
Port
Extractor
Link
Definition at line 60 of file pqPipelineModel.h.
◆ ItemRole
Enumerator
SessionFilterRole
Definition at line 70 of file pqPipelineModel.h.
◆ pqPipelineModel() [1/3]
pqPipelineModel::pqPipelineModel ( QObject *  parent = nullptr)
◆ pqPipelineModel() [2/3]
pqPipelineModel::pqPipelineModel ( const pqPipelineModel &  other,
Parameters
otherThe pipeline model to copy.
parentThe parent object.
◆ pqPipelineModel() [3/3]
pqPipelineModel::pqPipelineModel ( const pqServerManagerModel &  other,
Parameters
otherUsed to build a pipeline model.
◆ ~pqPipelineModel()
pqPipelineModel::~pqPipelineModel ( )
override
◆ rowCount()
int pqPipelineModel::rowCount ( const QModelIndex &  parent = QModelIndex()) const
override
Parameters
parentThe parent index.
Returns
The number of rows for the given index.
◆ columnCount()
int pqPipelineModel::columnCount ( const QModelIndex &  parent = QModelIndex()) const
override
Parameters
Returns
The number of columns for the given index.
◆ hasChildren()
bool pqPipelineModel::hasChildren ( const QModelIndex &  parent = QModelIndex()) const
override
Parameters
Returns
True if the given index has child items.
◆ index()
QModelIndex pqPipelineModel::index ( int  row,
int  column,
) const
override
Parameters
rowThe row number.
columnThe column number.
Returns
A model index for the given location.
◆ parent()
QModelIndex pqPipelineModel::parent ( const QModelIndex &  index) const
override
Parameters
indexThe model index.
Returns
A model index for the parent of the given index.
◆ data()
QVariant pqPipelineModel::data ( const QModelIndex &  index,
int  role = Qt::DisplayRole
) const
override
Parameters
roleThe role to get data for.
Returns
The data for the given model index.
◆ setData()
bool pqPipelineModel::setData ( const QModelIndex &  index,
const QVariant &  value,
int  role = Qt::EditRole
override
Returns true if successful; otherwise returns false.
◆ flags()
Qt::ItemFlags pqPipelineModel::flags ( const QModelIndex &  index) const
override
The flags for an item indicate if it is enabled, editable, etc.
Parameters
Returns
The flags for the given model index.
◆ getItemFor()
pqServerManagerModelItem* pqPipelineModel::getItemFor ( const QModelIndex &  ) const
nullptr is returned for root or invalid index.
◆ getIndexFor()
QModelIndex pqPipelineModel::getIndexFor ( pqServerManagerModelItem *  item) const
◆ getTypeFor()
ItemType pqPipelineModel::getTypeFor ( const QModelIndex &  index) const
Parameters
indexThe model index to look up.
Returns
The type for the given index.
◆ isEditable()
bool pqPipelineModel::isEditable ( ) const
inline
Returns
True if the model indexes can be edited.
Definition at line 206 of file pqPipelineModel.h.
◆ setEditable()
void pqPipelineModel::setEditable ( bool  editable)
inline
Parameters
editableTrue if the model indexes can be edited.
Definition at line 213 of file pqPipelineModel.h.
◆ setSelectable()
void pqPipelineModel::setSelectable ( const QModelIndex &  index,
bool  selectable
Parameters
selectableTrue if the index can be selected.
◆ isSelectable()
bool pqPipelineModel::isSelectable ( const QModelIndex &  index) const
Parameters
Returns
True if the given index is selectable.
◆ setSubtreeSelectable()
void pqPipelineModel::setSubtreeSelectable ( pqServerManagerModelItem *  item,
bool  selectable
Parameters
itemThe root of the subtree.
selectableTrue if the items can be selected.
◆ getNextIndex()
QModelIndex pqPipelineModel::getNextIndex ( QModelIndex  index,
const QModelIndex &  root = QModelIndex()
) const
Parameters
indexThe current index.
rootAn alternate root for walking a subtree.
Returns
An index to the next item in the tree or an invalid index when the end of the tree is reached.
◆ view()
pqView* pqPipelineModel::view ( ) const
inline
Provides access to the view.
Definition at line 254 of file pqPipelineModel.h.
◆ setModifiedFont()
void pqPipelineModel::setModifiedFont ( const QFont &  font)
Parameters
fontThe font to use for modified items.
◆ enableFilterAnnotationKey()
void pqPipelineModel::enableFilterAnnotationKey ( const QString &  expectedAnnotation)
Parameters
expectedAnnotationkey that will be lookup inside the above code.
◆ disableFilterAnnotationKey()
void pqPipelineModel::disableFilterAnnotationKey ( )
◆ setAnnotationFilterMatching()
void pqPipelineModel::setAnnotationFilterMatching ( bool  matching)
◆ enableFilterSession()
void pqPipelineModel::enableFilterSession ( vtkSession *  session)
Parameters
sessionthat will be lookup inside the above code.
◆ disableFilterSession()
void pqPipelineModel::disableFilterSession ( )
◆ addServer
void pqPipelineModel::addServer ( pqServer *  server)
slot
Adds the connection to the list.
◆ removeServer
void pqPipelineModel::removeServer ( pqServer *  server)
slot
Removes the server from the list.
◆ addSource
void pqPipelineModel::addSource ( pqPipelineSource *  source)
slot
◆ removeSource
void pqPipelineModel::removeSource ( pqPipelineSource *  source)
slot
◆ addConnection [1/2]
void pqPipelineModel::addConnection ( pqPipelineSource *  source,
pqPipelineSource *  sink,
int
slot
◆ removeConnection [1/2]
void pqPipelineModel::removeConnection ( pqPipelineSource *  source,
int
slot
◆ addConnection [2/2]
void pqPipelineModel::addConnection ( pqServerManagerModelItem *  source,
pqExtractor *  sink
slot
◆ removeConnection [2/2]
void pqPipelineModel::removeConnection ( pqServerManagerModelItem *  source,
pqExtractor *  sink
slot
◆ addExtractor
void pqPipelineModel::addExtractor ( pqExtractor *  )
slot
◆ removeExtractor
void pqPipelineModel::removeExtractor ( pqExtractor *  )
slot
◆ setView
void pqPipelineModel::setView ( pqView *  module)
slot
The current window column shows whether or not the source is displayed in the current window. When the current window changes the entire column needs to be updated.
◆ firstChildAdded
void pqPipelineModel::firstChildAdded ( const QModelIndex &  index)
signal
◆ childWithChildrenAdded
void pqPipelineModel::childWithChildrenAdded ( const QModelIndex &  index)
signal
◆ pqPipelineModelDataItem
friend class pqPipelineModelDataItem
friend
Definition at line 388 of file pqPipelineModel.h.
◆ ModifiedLiveInsituLink
friend class ModifiedLiveInsituLink
friend
Definition at line 435 of file pqPipelineModel.h.
