Public Member Functions | Static Public Member Functions | Protected Slots | Protected Member Functions | List of all members
pqComparativeRenderView Class Reference
RenderView used for comparative visualization (or film-strip visualization). More...
#include <pqComparativeRenderView.h>
Inheritance diagram for pqComparativeRenderView:
Collaboration diagram for pqComparativeRenderView:
 pqComparativeRenderView (const QString &group, const QString &name, vtkSMViewProxy *renModule, pqServer *server, QObject *parent=nullptr)
 ~pqComparativeRenderView () override
vtkSMComparativeViewProxy * getComparativeRenderViewProxy () const
 Returns the comparative view proxy. More...
vtkSMRenderViewProxy * getRenderViewProxy () const override
 Returns the root render view in the comparative view. More...
- Public Member Functions inherited from pqRenderView
 pqRenderView (const QString &group, const QString &name, vtkSMViewProxy *renModule, pqServer *server, QObject *parent=nullptr)
 pqRenderView (const QString &tname, const QString &group, const QString &name, vtkSMViewProxy *renModule, pqServer *server, QObject *parent=nullptr)
 ~pqRenderView () override
void resetCamera (bool closest=false, double offsetRatio=0.9) override
 Resets the camera to include all visible data. More...
virtual void resetCenterOfRotation ()
 Resets the center of rotation to the focal point. More...
virtual void resetParallelScale ()
 Resets the parallel scale which is used for a parallel projection. More...
virtual bool getOrientationAxesVisibility () const
 Get if the orientation axes is visible. More...
virtual bool getOrientationAxesInteractivity () const
 Get if the orientation axes is interactive. More...
virtual QColor getOrientationAxesLabelColor () const
 Get orientation axes label color. More...
virtual QColor getOrientationAxesOutlineColor () const
 Get orientation axes outline color. More...
virtual bool getResetCenterWithCamera () const
 Get whether resetCamera() resets the center of rotation as well. More...
virtual bool getUseMultipleRepresentationSelection () const
 Get whether selection will be done on multiple representations. More...
virtual bool getCenterAxesVisibility () const
 Get center axes visibility. More...
virtual void getCenterOfRotation (double center[3]) const
 Get the current center of rotation. More...
bool supportsUndo () const override
 Returns if this view module can support undo/redo. More...
bool supportsCapture () const override
 Returns if this view module can support image capture. More...
virtual void clearUndoStack ()
 Clears interaction undo stack of this view (and all linked views, if any). More...
virtual void resetViewDirection (double look_x, double look_y, double look_z, double up_x, double up_y, double up_z)
 Reset/Adjust camera view direction. More...
virtual void adjustView (const int &adjustType, const double &angle)
virtual void adjustAzimuth (const double &value)
virtual void adjustElevation (const double &value)
virtual void adjustRoll (const double &value)
virtual void adjustZoom (const double &value)
virtual void applyIsometricView ()
virtual void resetViewDirectionToPositiveX ()
virtual void resetViewDirectionToNegativeX ()
virtual void resetViewDirectionToPositiveY ()
virtual void resetViewDirectionToNegativeY ()
virtual void resetViewDirectionToPositiveZ ()
virtual void resetViewDirectionToNegativeZ ()
virtual pqDataRepresentation * pick (int pos[2])
 Picks the representation at the given position. More...
virtual pqDataRepresentation * pickBlock (int pos[2], unsigned int &flatIndex, int &rank)
virtual void selectBlock (int rectangle[4], int selectionModifier=pqView::PV_SELECTION_DEFAULT)
 Creates a "block" selection given the rectangle in display coordinates. More...
bool canUndo () const override
 Returns if the view module can undo/redo interaction given the current state of the interaction undo stack. More...
bool canRedo () const override
virtual void linkUndoStack (pqRenderView *other)
 For linking of interaction undo stacks. More...
virtual void unlinkUndoStack (pqRenderView *other)
virtual void setCursor (const QCursor &)
 Let internal class handle which internal widget should change its cursor This is usually used for selection and in case of QuadView/SliceView which contains an aggregation of QWidget, we don't necessary want all of them to share the same cursor. More...
virtual QCursor cursor ()
void setCursorVisible (bool visible)
 Set / get the cursor visibility when the mouse hovers the widget associated with this view. More...
bool cursorVisible ()
virtual void selectOnSurface (int rectangle[4], int selectionModifier=pqView::PV_SELECTION_DEFAULT, const char *array=nullptr)
 Creates a new surface selection given the rectangle in display coordinates. More...
virtual void selectCellsOnSurface (int rectangle[4], int selectionModifier=pqView::PV_SELECTION_DEFAULT, const char *array=nullptr)
virtual void selectPointsOnSurface (int rectangle[4], int selectionModifier=pqView::PV_SELECTION_DEFAULT, const char *array=nullptr)
virtual void selectFrustum (int rectangle[4])
 Creates a new frustum selection given the rectangle in display coordinates. More...
virtual void selectFrustumCells (int rectangle[4], int selectionModifier=pqView::PV_SELECTION_DEFAULT)
virtual void selectFrustumPoints (int rectangle[4], int selectionModifier=pqView::PV_SELECTION_DEFAULT)
virtual void selectPolygonPoints (vtkIntArray *polygon, int selectionModifier=pqView::PV_SELECTION_DEFAULT)
 Creates a new surface selection given the polygon in display coordinates. More...
virtual void selectPolygonCells (vtkIntArray *polygon, int selectionModifier=pqView::PV_SELECTION_DEFAULT)
- Public Member Functions inherited from pqRenderViewBase
 ~pqRenderViewBase () override
void resetDisplay (bool closest=false) override
 Called to reset the view's display. More...
- Public Member Functions inherited from pqView
 ~pqView () override
vtkSMViewProxy * getViewProxy () const
 Returns the internal render Module proxy associated with this object. More...
virtual vtkView * getClientSideView () const
 Return the client-side vtkView encapsulated by this view (if any), or return nullptr. More...
QWidget * widget ()
 Return a widget associated with this view. More...
QString getViewType () const
 Returns the type of this view module. More...
virtual QSize getSize ()
 Returns the current size of the rendering context. More...
bool hasRepresentation (pqRepresentation *repr) const
 This method checks if the representation is shown in this view. More...
int getNumberOfRepresentations () const
 Returns the number representations in the view. More...
int getNumberOfVisibleRepresentations () const
int getNumberOfVisibleDataRepresentations () const
pqRepresentation * getRepresentation (int index) const
 Returns the representation for the specified index where (index < getNumberOfRepresentations()). More...
QList< pqRepresentation * > getRepresentations () const
 Returns a list of representations in this view. More...
bool canDisplay (pqOutputPort *opPort) const
 This method returns is any pqPipelineSource can be displayed in this view. More...
- Public Member Functions inherited from pqProxy
 pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr)
 ~pqProxy () override
pqServer * getServer () const
 Get the server on which this proxy exists. More...
void rename (const QString &newname)
 This is a convenience method. More...
const QString & getSMName ()
 Get the name with which this proxy is registered on the server manager. More...
const QString & getSMGroup ()
vtkSMProxy * getProxy () const
 Get the vtkSMProxy this object stands for. More...
ModifiedState modifiedState () const
 Gets whether or not the source has been modified. More...
void setModifiedState (ModifiedState modified)
 Sets whether or not the source has been modified. More...
vtkPVXMLElement * getHints () const
 Returns the hints for this proxy, if any. More...
QList< vtkSMProxy * > getHelperProxies () const
 Returns a list of all helper proxies. More...
QList< vtkSMProxy * > getHelperProxies (const QString &key) const
 Returns a list of all the helper proxies added with a given key. More...
QList< QString > getHelperKeys () const
 Returns the keys for helper proxies. More...
virtual void addHelperProxy (const QString &key, vtkSMProxy *)
 Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More...
void removeHelperProxy (const QString &key, vtkSMProxy *)
void updateHelperProxies () const
 Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More...
vtkSMSessionProxyManager * proxyManager () const
 Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More...
bool userModifiedSMName ()
 Return whether or not the user has modified the GUI name of the source. More...
- Public Member Functions inherited from pqServerManagerModelItem
 pqServerManagerModelItem (QObject *parent=nullptr)
 ~pqServerManagerModelItem () override
static QString comparativeRenderViewType ()
- Static Public Member Functions inherited from pqRenderView
static QString renderViewType ()
- Static Public Member Functions inherited from pqProxy
static pqProxy * findProxyWithHelper (vtkSMProxy *aproxy, QString &key)
 Returns a pqProxy instance, of any, whose helper proxy is the aproxy. More...
static std::string rstToHtml (const char *rstStr)
 convert proxy documentation from RST to HTML (so that it can be used in Qt) More...
static QString rstToHtml (const QString &rstStr)
Protected Slots
void updateViewWidgets (QWidget *container=nullptr)
 Called when the layout on the comparative vis changes. More...
- Protected Slots inherited from pqRenderView
virtual void onInteractionModeChange ()
 Called when VTK event get trigger to notify that the interaction mode has changed. More...
virtual void onGenericFilmicPresetsChange ()
 Called when VTK event get trigger to notify that the generic filmic presets has changed. More...
virtual void onResetCameraEvent ()
virtual void onUndoStackChanged ()
 Called when undo stack changes. More...
- Protected Slots inherited from pqRenderViewBase
virtual void initializeAfterObjectsCreated ()
void beginDelayInteractiveRender ()
 Triggered by DelayNonInteractiveRenderEvent. More...
void endDelayInteractiveRender ()
void updateStatusMessage ()
 Triggered by internal timer to update the status bar message. More...
- Protected Slots inherited from pqProxy
void onProxyRegistered (const QString &, const QString &, vtkSMProxy *)
void onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *)
QWidget * createWidget () override
 Creates a new instance of the QWidget subclass to be used to show this view. More...
- Protected Member Functions inherited from pqRenderView
virtual void fakeUndoRedo (bool redo, bool self)
 Updates undo stack without actually performing the undo/redo actions. More...
virtual void fakeInteraction (bool start)
 Updates undo stack of all linked views to record a programmatic change in camera as a interaction. More...
void initialize () override
 Overridden to initialize the interaction undo/redo stack. More...
- Protected Member Functions inherited from pqRenderViewBase
 pqRenderViewBase (const QString &type, const QString &group, const QString &name, vtkSMViewProxy *renModule, pqServer *server, QObject *parent=nullptr)
bool eventFilter (QObject *caller, QEvent *e) override
 Overridden to popup the context menu, if some actions have been added using addMenuAction. More...
 Use this method to initialize the pqObject state using the underlying vtkSMProxy. More...
- Protected Member Functions inherited from pqView
 pqView (const QString &type, const QString &group, const QString &name, vtkSMViewProxy *view, pqServer *server, QObject *parent=nullptr)
 Constructor: type :- view type. More...
- Protected Member Functions inherited from pqProxy
void setSMName (const QString &new_name)
 Make this pqProxy take on a new identity. More...
virtual void addInternalHelperProxy (const QString &key, vtkSMProxy *) const
virtual void removeInternalHelperProxy (const QString &key, vtkSMProxy *) const
- Protected Member Functions inherited from pqServerManagerModelItem
vtkEventQtSlotConnect * getConnector ()
 All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More...
- Public Types inherited from pqView
enum  SelectionModifier { PV_SELECTION_DEFAULT = 0, PV_SELECTION_ADDITION, PV_SELECTION_SUBTRACTION, PV_SELECTION_TOGGLE }
- Public Types inherited from pqProxy
enum  ModifiedState { UNINITIALIZED, MODIFIED, UNMODIFIED }
 The modification state of this proxy. More...
- Public Slots inherited from pqRenderView
virtual void setOrientationAxesVisibility (bool visible)
virtual void setOrientationAxesInteractivity (bool interactive)
virtual void setOrientationAxesLabelColor (const QColor &)
virtual void setOrientationAxesOutlineColor (const QColor &)
virtual void setCenterOfRotation (double x, double y, double z)
virtual void setCenterOfRotation (double xyz[3])
virtual void setParallelScale (double scale)
virtual void setCenterAxesVisibility (bool visible)
virtual void setResetCenterWithCamera (bool b)
 Get/Set whether resetCamera() resets the center of rotation as well. More...
virtual void setUseMultipleRepresentationSelection (bool b)
 Set whether selection will be done on multiple representations. More...
virtual void linkToOtherView ()
 start the link to other view process More...
void undo () override
 Called to undo interaction. More...
void redo () override
 Called to redo interaction. More...
virtual void resetCenterOfRotationIfNeeded ()
 Resets center of rotation if this->ResetCenterWithCamera is true. More...
virtual void updateInteractionMode (pqOutputPort *opPort)
 Try to provide the best view orientation and interaction mode. More...
- Public Slots inherited from pqView
virtual void render ()
 Request a StillRender on idle. More...
virtual void forceRender ()
 Forces an immediate render. More...
void cancelPendingRenders ()
 Cancels any pending renders. More...
virtual void undo ()
virtual void redo ()
- Signals inherited from pqRenderView
void updateInteractionMode (int mode)
- Signals inherited from pqView
void updateDataEvent ()
 Fired when the vtkSMViewProxy fires the vtkCommand::UpdateDataEvent The view proxy fires this event at the end of vtkSMViewProxy::Update() when the update executes, not just when the method is called. More...
void representationAdded (pqRepresentation *)
 Fired after a representation has been added to this view. More...
void representationRemoved (pqRepresentation *)
 Fired after a representation has been removed from this view. More...
void beginRender ()
 Fired when the render module fires a vtkCommand::StartEvent signalling the beginning of rendering. More...
void endRender ()
 Fired when the render module fires a vtkCommand::EndEvent signalling the end of rendering. More...
void representationVisibilityChanged (pqRepresentation *repr, bool visible)
 Fired when any representation visibility changes. More...
void canUndoChanged (bool)
 Fired when interaction undo stack status changes. More...
void canRedoChanged (bool)
void selected (pqOutputPort *opport)
 Fired when a selection is made in this view. More...
void picked (pqOutputPort *opport)
 Fired when a port is picked. More...
void beginProgress ()
 Fired before doing any actions that may result in progress events that must be reported by the client. More...
void endProgress ()
 Fired after performing any actions that may result in progress events. More...
void progress (const QString &message, int percent_progress)
 Fired to notify the current execution progress. More...
void multipleSelected (QList< pqOutputPort * > opports)
 Fired when UseMultipleRepresentationSelection is set to on and selection on multiple representations is made in this view. More...
- Signals inherited from pqProxy
void nameChanged (pqServerManagerModelItem *)
 Fired when the name of the proxy is changed. More...
void modifiedStateChanged (pqServerManagerModelItem *)
 Fired when the modified status changes for the proxy. More...
- Protected Attributes inherited from pqRenderView
bool ResetCenterWithCamera
bool UseMultipleRepresentationSelection
Definition at line 14 of file pqComparativeRenderView.h.
◆ pqComparativeRenderView()
pqComparativeRenderView::pqComparativeRenderView ( const QString &  group,
const QString &  name,
vtkSMViewProxy *  renModule,
pqServer *  server,
QObject *  parent = nullptr
◆ ~pqComparativeRenderView()
pqComparativeRenderView::~pqComparativeRenderView ( )
override
◆ comparativeRenderViewType()
static QString pqComparativeRenderView::comparativeRenderViewType ( )
inlinestatic
Definition at line 20 of file pqComparativeRenderView.h.
◆ getComparativeRenderViewProxy()
vtkSMComparativeViewProxy* pqComparativeRenderView::getComparativeRenderViewProxy ( ) const
◆ getRenderViewProxy()
vtkSMRenderViewProxy* pqComparativeRenderView::getRenderViewProxy ( ) const
Reimplemented from pqRenderView.
◆ updateViewWidgets
void pqComparativeRenderView::updateViewWidgets ( QWidget *  container = nullptr)
protectedslot
◆ createWidget()
QWidget* pqComparativeRenderView::createWidget ( )
overrideprotectedvirtual
Default implementation creates a pqQVTKWidgetBase.
Implements pqView.
