Public Slots | Signals | Public Member Functions | Protected Member Functions | List of all members
pqAnimationScene Class Reference
pqAnimationScene is a representation for a vtkSMAnimationScene proxy. More...
#include <pqAnimationScene.h>
Inheritance diagram for pqAnimationScene:
Collaboration diagram for pqAnimationScene:
Public Slots
void play ()
 Play animation. More...
void pause ()
 Pause animation. More...
void setAnimationTime (double time)
 Set the animation time. More...
Signals
void preAddedCue (pqAnimationCue *)
 Fired before a new cue is added to the scene. More...
void addedCue (pqAnimationCue *)
 Fired after a new cue has been added to the scene. More...
void preRemovedCue (pqAnimationCue *)
 Fired before a cue is removed from the scene. More...
void removedCue (pqAnimationCue *)
 Fired after a cue has been removed from the scene. More...
void cuesChanged ()
 Fired after cues have been added/removed. More...
void playModeChanged ()
 Emitted when the play mode changes. More...
void loopChanged ()
 Emitted when the looping state changes on the underlying proxy. More...
void clockTimeRangesChanged ()
 Emitted when the clock time ranges change. More...
void beginPlay ()
void endPlay ()
void beginPlay (vtkObject *caller, unsigned long, void *, void *reversed)
 Emitted when animation starts playing. More...
void endPlay (vtkObject *caller, unsigned long, void *, void *reversed)
 Emitted when animation ends playing. More...
void tick (int percentCompleted)
 Emitted when playing animation. More...
void animationTime (double time)
 Emitted when playing (or when animation time for the scene is set). More...
void frameCountChanged ()
 Emitted when the number of frames changes. More...
void timeStepsChanged ()
 Emitted when the number of timesteps changes. More...
void timeLabelChanged ()
 Emitted when a source is changing the label that should be use for time. More...
- Signals inherited from pqProxy
void nameChanged (pqServerManagerModelItem *)
 Fired when the name of the proxy is changed. More...
void modifiedStateChanged (pqServerManagerModelItem *)
 Fired when the modified status changes for the proxy. More...
 pqAnimationScene (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr)
 ~pqAnimationScene () override
pqAnimationCue * getCue (vtkSMProxy *proxy, const char *propertyname, int index) const
 Returns the cue that animates the given index of the given property on the given proxy, in this scene, if any. More...
void removeCues (vtkSMProxy *proxy)
 Removes all cues which animate the indicated proxy, if any. More...
void removeCue (pqAnimationCue *cue)
 Removes cue. More...
bool contains (pqAnimationCue *) const
 returns true is the cue is present in this scene. More...
QPair< double, double > getClockTimeRange () const
 Get the clock time range set on the animation scene proxy. More...
QSet< pqAnimationCue * > getCues () const
 Get all the cues in this scene. More...
double getAnimationTime () const
 Returns the current animation time. More...
QList< double > getTimeSteps () const
 Returns the timesteps from the timekeeper for the animation scene. More...
pqAnimationCue * createCue (vtkSMProxy *proxy, const char *propertyname, int index)
 Creates and initializes a new cue that can animate the index of the property on the given proxy in this scene. More...
pqAnimationCue * createCue (vtkSMProxy *proxy, const char *propertyname, int index, const QString &cuetype)
pqAnimationCue * createCue (const QString &cuetype)
pqAnimationCue * createCue (const pqAnimatedPropertyInfo &propInfo)
- Public Member Functions inherited from pqProxy
 pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr)
 ~pqProxy () override
pqServer * getServer () const
 Get the server on which this proxy exists. More...
void rename (const QString &newname)
 This is a convenience method. More...
const QString & getSMName ()
 Get the name with which this proxy is registered on the server manager. More...
const QString & getSMGroup ()
vtkSMProxy * getProxy () const
 Get the vtkSMProxy this object stands for. More...
ModifiedState modifiedState () const
 Gets whether or not the source has been modified. More...
void setModifiedState (ModifiedState modified)
 Sets whether or not the source has been modified. More...
vtkPVXMLElement * getHints () const
 Returns the hints for this proxy, if any. More...
QList< vtkSMProxy * > getHelperProxies () const
 Returns a list of all helper proxies. More...
QList< vtkSMProxy * > getHelperProxies (const QString &key) const
 Returns a list of all the helper proxies added with a given key. More...
QList< QString > getHelperKeys () const
 Returns the keys for helper proxies. More...
virtual void addHelperProxy (const QString &key, vtkSMProxy *)
 Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More...
void removeHelperProxy (const QString &key, vtkSMProxy *)
void updateHelperProxies () const
 Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More...
vtkSMSessionProxyManager * proxyManager () const
 Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More...
bool userModifiedSMName ()
 Return whether or not the user has modified the GUI name of the source. More...
- Public Member Functions inherited from pqServerManagerModelItem
 pqServerManagerModelItem (QObject *parent=nullptr)
 ~pqServerManagerModelItem () override
void initializeCue (vtkSMProxy *proxy, const char *propertyname, int index, pqAnimationCue *cue)
 Initializes the newly create animation cue with default keyframes. More...
- Protected Member Functions inherited from pqProxy
void setSMName (const QString &new_name)
 Make this pqProxy take on a new identity. More...
virtual void initialize ()
virtual void addInternalHelperProxy (const QString &key, vtkSMProxy *) const
virtual void removeInternalHelperProxy (const QString &key, vtkSMProxy *) const
- Protected Member Functions inherited from pqServerManagerModelItem
vtkEventQtSlotConnect * getConnector ()
 All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More...
- Public Types inherited from pqProxy
enum  ModifiedState { UNINITIALIZED, MODIFIED, UNMODIFIED }
 The modification state of this proxy. More...
- Static Public Member Functions inherited from pqProxy
static pqProxy * findProxyWithHelper (vtkSMProxy *aproxy, QString &key)
 Returns a pqProxy instance, of any, whose helper proxy is the aproxy. More...
static std::string rstToHtml (const char *rstStr)
 convert proxy documentation from RST to HTML (so that it can be used in Qt) More...
static QString rstToHtml (const QString &rstStr)
- Protected Slots inherited from pqProxy
void onProxyRegistered (const QString &, const QString &, vtkSMProxy *)
void onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *)
It provides API to access AnimationCues in the scene and to the scene times.
Definition at line 22 of file pqAnimationScene.h.
◆ pqAnimationScene()
pqAnimationScene::pqAnimationScene ( const QString &  group,
const QString &  name,
vtkSMProxy *  proxy,
pqServer *  server,
QObject *  parent = nullptr
◆ ~pqAnimationScene()
pqAnimationScene::~pqAnimationScene ( )
override
◆ getCue()
pqAnimationCue* pqAnimationScene::getCue ( vtkSMProxy *  proxy,
const char *  propertyname,
int  index
) const
◆ createCue() [1/4]
pqAnimationCue* pqAnimationScene::createCue ( vtkSMProxy *  proxy,
int  index
This method does not check is such a cue already exists, use getCue() before calling this to avoid duplicates.
◆ createCue() [2/4]
int  index,
const QString &  cuetype
◆ createCue() [3/4]
pqAnimationCue* pqAnimationScene::createCue ( const QString &  cuetype)
◆ createCue() [4/4]
pqAnimationCue* pqAnimationScene::createCue ( const pqAnimatedPropertyInfo &  propInfo)
◆ removeCues()
void pqAnimationScene::removeCues ( vtkSMProxy *  proxy)
◆ removeCue()
void pqAnimationScene::removeCue ( pqAnimationCue *  cue)
Removes cue.
◆ contains()
bool pqAnimationScene::contains ( pqAnimationCue *  ) const
◆ getClockTimeRange()
QPair<double, double> pqAnimationScene::getClockTimeRange ( ) const
◆ getCues()
QSet<pqAnimationCue*> pqAnimationScene::getCues ( ) const
◆ getAnimationTime()
double pqAnimationScene::getAnimationTime ( ) const
◆ getTimeSteps()
QList<double> pqAnimationScene::getTimeSteps ( ) const
◆ preAddedCue
void pqAnimationScene::preAddedCue ( pqAnimationCue *  )
signal
◆ addedCue
void pqAnimationScene::addedCue ( pqAnimationCue *  )
signal
◆ preRemovedCue
void pqAnimationScene::preRemovedCue ( pqAnimationCue *  )
signal
◆ removedCue
void pqAnimationScene::removedCue ( pqAnimationCue *  )
signal
◆ cuesChanged
void pqAnimationScene::cuesChanged ( )
signal
◆ playModeChanged
void pqAnimationScene::playModeChanged ( )
signal
◆ loopChanged
void pqAnimationScene::loopChanged ( )
signal
◆ clockTimeRangesChanged
void pqAnimationScene::clockTimeRangesChanged ( )
signal
◆ beginPlay [1/2]
void pqAnimationScene::beginPlay ( )
signal
Deprecated:
in ParaView 5.11.0
◆ endPlay [1/2]
void pqAnimationScene::endPlay ( )
signal
Deprecated:
in ParaView 5.11.0
◆ beginPlay [2/2]
void pqAnimationScene::beginPlay ( vtkObject *  caller,
unsigned long  ,
void *  ,
void *  reversed
signal
reversed is a pointer to boolean that indicates if the playback direction is backward
◆ endPlay [2/2]
void pqAnimationScene::endPlay ( vtkObject *  caller,
unsigned long  ,
void *  ,
void *  reversed
signal
◆ tick
void pqAnimationScene::tick ( int  percentCompleted)
signal
Argument is the percent of play completed.
◆ animationTime
void pqAnimationScene::animationTime ( double  time)
signal
time is the animation clock time.
◆ frameCountChanged
void pqAnimationScene::frameCountChanged ( )
signal
◆ timeStepsChanged
void pqAnimationScene::timeStepsChanged ( )
signal
◆ timeLabelChanged
void pqAnimationScene::timeLabelChanged ( )
signal
◆ play
void pqAnimationScene::play ( )
slot
Play animation.
◆ pause
void pqAnimationScene::pause ( )
slot
Pause animation.
◆ setAnimationTime
void pqAnimationScene::setAnimationTime ( double  time)
slot
◆ initializeCue()
void pqAnimationScene::initializeCue ( vtkSMProxy *  proxy,
int  index,
