vtkSMViewProxy.h
20 #ifndef vtkSMViewProxy_h
21 #define vtkSMViewProxy_h
22
23 #include "vtkCommand.h" // needed for vtkCommand.
24 #include "vtkRemotingViewsModule.h" //needed for exports
25 #include "vtkSMProxy.h"
26
27 class vtkImageData;
28 class vtkRenderer;
29 class vtkRenderWindow;
33 class vtkSMSourceProxy;
34 class vtkView;
35
37 {
38 class WindowToImageFilter;
39 class CaptureHelper;
40 }
41
43 {
44 public:
45  static vtkSMViewProxy* New();
46  vtkTypeMacro(vtkSMViewProxy, vtkSMProxy);
47  void PrintSelf(ostream& os, vtkIndent indent) override;
48
50
53  vtkSetMacro(Enable, bool);
54  vtkGetMacro(Enable, bool);
55  vtkBooleanMacro(Enable, bool);
57
61  virtual void StillRender();
62
66  virtual void InteractiveRender();
67
71  virtual void Update();
72
78  virtual bool CanDisplayData(vtkSMSourceProxy* producer, int outputPort);
79
88  virtual vtkSMRepresentationProxy* CreateDefaultRepresentation(vtkSMProxy*, int);
89
99  virtual const char* GetRepresentationType(vtkSMSourceProxy* producer, int outputPort);
100
105  virtual vtkSMRepresentationProxy* FindRepresentation(vtkSMSourceProxy* producer, int outputPort);
106
108
116  vtkImageData* CaptureWindow(int magnification)
117  {
118  return this->CaptureWindow(magnification, magnification);
119  }
121  vtkImageData* CaptureWindow(int magnificationX, int magnificationY);
123
126  vtkView* GetClientSideView();
127
132  int WriteImage(const char* filename, const char* writerName, int magnification = 1);
133  int WriteImage(
134  const char* filename, const char* writerName, int magnificationX, int magnificationY);
135
141  virtual bool HasDirtyRepresentation() { return this->GetNeedsUpdate(); }
142
151  virtual vtkRenderWindow* GetRenderWindow() { return nullptr; }
152
158  virtual vtkRenderWindowInteractor* GetInteractor() { return nullptr; }
159
169  virtual void SetupInteractor(vtkRenderWindowInteractor* iren) { (void)iren; }
170
178  virtual bool MakeRenderWindowInteractor(bool quiet = false);
179
181
184  static void SetTransparentBackground(bool val);
185  static bool GetTransparentBackground();
187
189
198  virtual bool HideOtherRepresentationsIfNeeded(vtkSMProxy* repr);
200  {
201  return self ? self->HideOtherRepresentationsIfNeeded(repr) : false;
202  }
204
206
219  virtual void RepresentationVisibilityChanged(vtkSMProxy* repr, bool new_visibility);
221  vtkSMViewProxy* self, vtkSMProxy* repr, bool new_visibility)
222  {
223  if (self)
224  {
225  self->RepresentationVisibilityChanged(repr, new_visibility);
226  }
227  }
229
233  static vtkSMViewProxy* FindView(vtkSMProxy* repr, const char* reggroup = "views");
234
235  enum
236  {
241  PrepareContextForRendering = vtkCommand::UserEvent + 1,
242  };
243
244 protected:
245  vtkSMViewProxy();
246  ~vtkSMViewProxy() override;
247
258  virtual vtkImageData* CaptureWindowInternal(int magnificationX, int magnificationY);
259
264  virtual void RenderForImageCapture() { this->StillRender(); }
265
276  virtual vtkTypeUInt32 PreRender(bool vtkNotUsed(interactive)) { return this->GetLocation(); }
277
278  virtual void PostRender(bool vtkNotUsed(interactive)) {}
279
289  virtual bool IsContextReadyForRendering();
290
294  void CreateVTKObjects() override;
295
299  int ReadXMLAttributes(vtkSMSessionProxyManager* pm, vtkPVXMLElement* element) override;
300
305  bool GetLocalProcessSupportsInteraction();
306
310  vtkGetObjectMacro(DeliveryManager, vtkSMDataDeliveryManagerProxy);
311
312  vtkSetStringMacro(DefaultRepresentationName);
314
315  bool Enable;
316
317 private:
318  vtkSMViewProxy(const vtkSMViewProxy&) = delete;
319  void operator=(const vtkSMViewProxy&) = delete;
320
321  bool InRender;
322
323  vtkSMDataDeliveryManagerProxy* DeliveryManager;
324  static bool TransparentBackground;
325
326  // Actual logic for taking a screenshot.
327  vtkImageData* CaptureWindowSingle(int magnificationX, int magnificationY);
328
329  friend class vtkSMViewProxyNS::WindowToImageFilter;
330  friend class vtkSMViewProxyNS::CaptureHelper;
331 };
332
333 #endif
Proxy for a representations.
Superclass for all view proxies.
char * DefaultRepresentationName
virtual vtkRenderWindow * GetRenderWindow()
Return the vtkRenderWindow used by this view, if any.
virtual vtkRenderWindowInteractor * GetInteractor()
Returns the interactor.
This method is called before executing code that could cause a render on the underlying vtkPVView...
This method is called whenever the view wants to render to during image capture.
proxy for a VTK source on a server
The vtkSMSessionProxyManager is esponsible for creating and managing proxies for a given session...
static bool HideOtherRepresentationsIfNeeded(vtkSMViewProxy *self, vtkSMProxy *repr)
Method used to hide other representations if the view has a <ShowOneRepresentationAtATime/> hint...
#define VTK_NEWINSTANCE
Return true any internal representation is dirty.
VTK_NEWINSTANCE vtkImageData * CaptureWindow(int magnification)
Captures a image from this view.
Definition: vtkSMProxy.h:140
server-manager class for vtkPVDataDeliveryManager.
virtual void SetupInteractor(vtkRenderWindowInteractor *iren)
A client process need to set the interactor to enable interactivity.
static void RepresentationVisibilityChanged(vtkSMViewProxy *self, vtkSMProxy *repr, bool new_visibility)
Certain views maintain properties (or other state) that should be updated when visibility of represen...
