vtkSMDataDeliveryManagerProxy Class Reference
server-manager class for vtkPVDataDeliveryManager. More...
#include <vtkSMDataDeliveryManagerProxy.h>
Inheritance diagram for vtkSMDataDeliveryManagerProxy:
Collaboration diagram for vtkSMDataDeliveryManagerProxy:
typedef vtkSMProxy Superclass
void SetViewProxy (vtkSMViewProxy *)
 Get/Set the view proxy for whom we are delivering the data. More...
void Deliver (bool interactive)
 Called to request delivery of the geometry. More...
bool DeliverStreamedPieces ()
 EXPERIMEMTAL: Delivery when streaming is enabled. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
vtkSMProxyGetParentProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMDataDeliveryManagerProxyNew ()
static vtkSMDataDeliveryManagerProxySafeDownCast (vtkObject *o)
static vtkSMProxyNew ()
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMDataDeliveryManagerProxy ()
 ~vtkSMDataDeliveryManagerProxy () override
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkWeakPointer< vtkSMViewProxyViewProxy
std::map< int, vtkTimeStampDeliveryTimestamps
std::map< int, vtkTimeStampDeliveryTimestampsLOD
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElementXMLElement
vtkSMMessageState
int InMarkModified
vtkSMProxyInternalsInternals
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMDataDeliveryManagerProxy is the server-manager wrapper for vtkPVDataDeliveryManager. It manages calling on methods on instances of vtkPVDataDeliveryManager. Before every render call, vtkSMRenderViewProxy calls vtkSMDataDeliveryManagerProxy::Deliver() to ensure that any geometries that need to be delivered are explicitly delivered. This separating into Update-Deliver-Render calls ensures makes it possible to extend the framework for streaming, in future.
The streaming components of this class are experimental and will be changed.
Definition at line 29 of file vtkSMDataDeliveryManagerProxy.h.
Definition at line 33 of file vtkSMDataDeliveryManagerProxy.h.
◆ vtkSMDataDeliveryManagerProxy()
vtkSMDataDeliveryManagerProxy::vtkSMDataDeliveryManagerProxy ( )
◆ ~vtkSMDataDeliveryManagerProxy()
vtkSMDataDeliveryManagerProxy::~vtkSMDataDeliveryManagerProxy ( )
static vtkSMDataDeliveryManagerProxy* vtkSMDataDeliveryManagerProxy::New ( )
virtual const char* vtkSMDataDeliveryManagerProxy::GetClassName ( )
static int vtkSMDataDeliveryManagerProxy::IsTypeOf ( const char *  type)
virtual int vtkSMDataDeliveryManagerProxy::IsA ( const char *  type)
static vtkSMDataDeliveryManagerProxy* vtkSMDataDeliveryManagerProxy::SafeDownCast ( vtkObject o)
void vtkSMDataDeliveryManagerProxy::PrintSelf ( ostream &  os,
◆ SetViewProxy()
void vtkSMDataDeliveryManagerProxy::SetViewProxy ( vtkSMViewProxy )
◆ Deliver()
void vtkSMDataDeliveryManagerProxy::Deliver ( bool  interactive)
This checks the client-side vtkPVDataDeliveryManager instance to see if any geometries need to be delivered and then requests delivery for those.
◆ DeliverStreamedPieces()
bool vtkSMDataDeliveryManagerProxy::DeliverStreamedPieces ( )
Returns true when some new data was streamed. When this returns false, it implies that there is no more data to stream or streaming is not enabled.
◆ ViewProxy
vtkWeakPointer<vtkSMViewProxy> vtkSMDataDeliveryManagerProxy::ViewProxy
Definition at line 59 of file vtkSMDataDeliveryManagerProxy.h.
◆ DeliveryTimestamps
std::map<int, vtkTimeStamp> vtkSMDataDeliveryManagerProxy::DeliveryTimestamps
Definition at line 60 of file vtkSMDataDeliveryManagerProxy.h.
◆ DeliveryTimestampsLOD
std::map<int, vtkTimeStamp> vtkSMDataDeliveryManagerProxy::DeliveryTimestampsLOD
Definition at line 61 of file vtkSMDataDeliveryManagerProxy.h.
