vtkSMViewLayoutProxy.h
28 #ifndef vtkSMViewLayoutProxy_h
29 #define vtkSMViewLayoutProxy_h
30
31 #include "vtkRemotingViewsModule.h" //needed for exports
32 #include "vtkSMProxy.h"
33 #include "vtkVector.h" // needed for vtkVector2i
34 #include <vector> // needed for std::vector.
35
36 class vtkSMViewProxy;
37 class vtkImageData;
38
40 {
41 public:
42  static vtkSMViewLayoutProxy* New();
44  void PrintSelf(ostream& os, vtkIndent indent) override;
45
46  enum Direction
47  {
50  HORIZONTAL
51  };
52
62  int Split(int location, int direction, double fraction);
63  int SplitVertical(int location, double fraction)
64  {
65  return this->Split(location, VERTICAL, fraction);
66  }
67  int SplitHorizontal(int location, double fraction)
68  {
69  return this->Split(location, HORIZONTAL, fraction);
70  }
71
76  bool AssignView(int location, vtkSMViewProxy* view);
77
87  int AssignViewToAnyCell(vtkSMViewProxy* view, int location_hint);
88
90
94  int RemoveView(vtkSMViewProxy* view);
95  bool RemoveView(int index);
97
104  bool Collapse(int location);
105
110  bool SwapCells(int location1, int location2);
111
116  bool SetSplitFraction(int location, double fraction);
117
121  bool EqualizeViews();
122
126  bool EqualizeViews(Direction direction);
127
134  bool MaximizeCell(int location);
135
139  void RestoreMaximizedState();
140
142
146  vtkGetMacro(MaximizedCell, int);
148
152  bool IsSplitCell(int location);
153
157  Direction GetSplitDirection(int location);
158
162  double GetSplitFraction(int location);
163
168  static int GetFirstChild(int location) { return 2 * location + 1; }
169
174  static int GetSecondChild(int location) { return 2 * location + 2; }
175
179  static int GetParent(int location) { return (location > 0 ? ((location - 1) / 2) : -1); }
180
184  vtkSMViewProxy* GetView(int location);
185
190  int GetViewLocation(vtkSMViewProxy*);
191
193
196  bool ContainsView(vtkSMViewProxy* view) { return this->GetViewLocation(view) != -1; }
197  bool ContainsView(vtkSMProxy* view);
199
205  void UpdateViewPositions();
206
212  void ShowViewsOnTileDisplay();
213
215
218  vtkImageData* CaptureWindow(int magnification)
219  {
220  return this->CaptureWindow(magnification, magnification);
221  }
222  vtkImageData* CaptureWindow(int magnificationX, int magnificationY);
224
229  {
230  return this->Superclass::SaveXMLState(root);
231  }
233
237  int LoadXMLState(vtkPVXMLElement* element, vtkSMProxyLocator* locator) override;
238
242  void Reset();
243
247  void GetLayoutExtent(int extent[4]);
248
250
255  void SetSize(const int size[2]);
256  void SetSize(int width, int height)
257  {
258  const int size[] = { width, height };
259  this->SetSize(size);
260  }
262
267  {
268  int extent[4];
269  this->GetLayoutExtent(extent);
270  return vtkVector2i(extent[1] - extent[0] + 1, extent[3] - extent[2] + 1);
271  }
272
277  static vtkSMViewLayoutProxy* FindLayout(vtkSMViewProxy*, const char* reggroup = "layouts");
278
282  std::vector<vtkSMViewProxy*> GetViews();
283
285
291  void SaveAsPNG(int rank, const char* fname);
293
294 protected:
296  ~vtkSMViewLayoutProxy() override;
297
301  void LoadState(const vtkSMMessage* message, vtkSMProxyLocator* locator) override;
302
308  virtual void UpdateState();
309
315  int GetEmptyCell(int root);
316
320  int GetSplittableCell(int root, Direction& suggested_direction);
321
326  int ComputeSteadySplitFraction(int location, Direction direction);
327
329
330 private:
332  void operator=(const vtkSMViewLayoutProxy&) = delete;
333
334  class vtkInternals;
335  vtkInternals* Internals;
336
337  bool SetBlockUpdate(bool new_value)
338  {
339  bool temp = this->BlockUpdate;
340  this->BlockUpdate = new_value;
341  return temp;
342  }
343
344  bool BlockUpdate;
345
346  bool SetBlockUpdateViewPositions(bool val)
347  {
348  bool temp = this->BlockUpdateViewPositions;
349  this->BlockUpdateViewPositions = val;
350  return temp;
351  }
352  bool BlockUpdateViewPositions;
353 };
354
355 #endif
Returns the parent index.
direction
location
Returns the index for the first child of the given location.
vtkImageData * CaptureWindow(int magnification)
Captures an image from the layout (including all the views in the layout.
Superclass for all view proxies.
bool ContainsView(vtkSMViewProxy *view)
Returns if a view is contained in this layout.
Update the size for all the views in the layout assuming the new size provided for the whole layout...
vtkPVXMLElement * SaveXMLState(vtkPVXMLElement *root) override
Overridden to save custom XML state.
size
void LoadState(const vtkSMMessage *msg, vtkSMProxyLocator *locator) override
This method is used to initialise the object to the given state If the definitionOnly Flag is set to ...
vtkSMViewLayoutProxy is used by ParaView to layout multiple views in a 2D KD-Tree layout...
static vtkSMProxy * New()
virtual int LoadXMLState(vtkPVXMLElement *element, vtkSMProxyLocator *locator)
Loads the proxy state from the XML element.
Definition: vtkSMProxy.h:140
void operator=(const vtkSMProxy &)=delete
vtkSMProxyInternals * Internals
Definition: vtkSMProxy.h:1029
virtual vtkPVXMLElement * SaveXMLState(vtkPVXMLElement *root)
Saves the state of the proxy.
extent
index
Returns the index for the second child of the given location.
vtkVector2i GetSize()
Returns the current size.
iterates over the properties of a proxy
