Major changes made since ParaView 5.10.1 are listed in this document. The full list of issues addressed by this release is available here.
ParaView's user interface now allows you to define and edit 2-dimensional transfer functions for volume visualization of structured data. 2D transfer functions enable the color and opacity of a data sample to be determined by the value of two separate scalar fields. This enables the visualization to compare and contrast spatial features of the two fields. The new functionality also provides for a special mode where a scalar field can be coupled with its gradient magnitude that enhances "edges" in the scalar values.
To aid in the definition of 2D transfer functions, it is useful to compute a 2D histogram over the two different scalar fields of choice. This histogram helps highlight areas where interesting relationships between the two fields exist.
ParaView has a new filter called ExtractHistogram2D to compute 2D histograms for most types of vtkDataSets over two different data array components or their gradient magnitudes. The output of this filter is a one-component vtkImageData of type double that can be visualized in ParaView's render view as an image slice.
Histogram2D filter
When you enable the Use 2D transfer function checkbox, the color opacity editor switches to the 2D transfer function editor.
The editor displays the 2D histogram of the chosen scalar field with the number of bins defined by the Number of histogram bins property. Changing the number of bins triggers an update to the histogram based on whether or not the Automatic histogram property is enabled.
2D Histogram in ParaView's color opacity editor.
The histogram is displayed as a grayscale image where white indicates the highest density and black indicates lowest density. A legend on the right shows the density range. Hovering over a pixel/point in the histogram shows the data values for the histogrammed arrays as well as the density.
ParaView's new 2D transfer function editor allows you to generate a 2D transfer function via rectangular regions of interest. You can add as many of these regions as you like to customize the transfer function. Each region is assigned a user-specifiable color and opacity which are distributed in the box area as a 2D Gaussian distribution. These regions can be dragged and resized over the 2D histogram to change the overall function.
Once the 2D transfer function editor is activated, a transfer function box can be added by double clicking anywhere inside the bounds of the histogram. The box can then be moved by left-clicking, holding and dragging the mouse cursor anywhere inside the bounds of the box. The box can be resized by holding and dragging any of the four corners of the box. The color and opacity of the box can be changed by activating the color chooser dialog using the new tool button provided on the right hand side of the editor. A box can be deleted by clicking on it to select it and pressing the Delete key on the keyboard.
2D transfer function editor in ParaView showing a 2D histogram of arrays "Pres" vs. "Temp" and three boxes defining 2D Gaussian profiles that define the transfer function.
2D transfer function applied to simulation data.
New Properties that control 2D transfer functions
The new properties are availabe in the Volume rendering section of the Properties panel. They are only visible when the advanced properties option is toggled on. Note that the widget for selecting the Y-axis array is only shown if the option to use gradient is disabled.
Available ParaView tutorials are of two types. The ParaView Classroom Tutorials, are meant for following along with an instructor. The ParaView Self-directed Tutorial has written guidance and background and can be followed independently. Both tutorials are now part of the ParaView Documentation website.
The ParaView Save Screenshot and Save Animation dialogs now allow you to select the resolution from a list of commonly used presets. It is also possible to select the most recently used resolution.
New controls for setting screenshot and animation resolutions
The Save Animation dialog now has a property that lets you define the stride of the output animation frames, i.e., the number of frames to skip when saving out an animation.
Selection Editor is a new panel that enables saving and combining many selections of different types using a boolean expression.
Selection Editor has:
Data producer - a field that is set based on the source of the active selection.Element type - a field that is set based on the element type of the active selection.Expression - a string you can set, but which is also automatically filled while adding new selections.Saved Selections - a table that lists the name assigned to each selection that will be used to define the expression, and the type of the selection. If you choose a selection from the Saved Selections table, and the active view is a render view, the selected selection will be shown. When the chosen selection is unchosen, the previously chosen selection is hidden from the render-view.Add Active Selection - a button that adds the active selection to the list of saved selections.Remove Selected Selection - a button that removes the chosen selection from the list of saved selections.Remove All Selections - a button that removes all saved selections.Activate Combined Selections - a button that sets the combined saved selections as the active selection.An example of a combined selection created using the Selection Editor is shown below.
ParaView now supports arbitrary combinations of multiple selections.
Filters like the Calculator and Python Calculator have a text property that defines an expression to apply. Any one line expression can freely be typed in, but it used to be a strictly manual operation, to be repeated at each filter creation.
ParaView now provides an expression manager to ease this property configuration by storing expressions, and giving quick access to them. Each expression can be named, to help future reuse, and has an associated group so it is easy to filter Python expressions from others.
This feature comes in two parts:
From the Property Panel, the one-line property text entry is augmented with:
The Choose Expression dialog, also accessible from the Tools -> Manage Expressions menu item, is an editable and searchable list of the stored expressions. ParaView keeps track of them through the settings, but they can also be exported to a JSON file for backup and sharing.
Previously, the timeout value for a pvserver instance is set during its launch (example : ./pvserver --timeout=60). The countdown is then handled exclusively by the client, without taking into account possible changes on the server side. ParaView now has a feature that lets you provide a command to the pvserver instance, that will be regularly called on the server side to directly ask it the remaining time available (example : ./pvserver --timeout-command="timeoutCommand").
The current attribute timeout in the XML for the server command has been deprecated and replaced with process_wait. This parameter let you set how long the client will wait for the exec content to be run in a process, in seconds.
It was previously:
It should now be:
A new timeout attribute on the XML of the server is now connected to the timeout spinbox in the UI.
This new parameter let you control how long will the client try to connect to the server, in seconds. Default is 60 for standard connection and infinite for reverse connection.
You can now write:
There is new support for aborting connections in all cases (except catalyst). Previously, aborting connections was limited to reverse connections only.
There is support for connection retry in case of timeout on connection.
Timeouts for reverse connections are now supported on the client side only.
There have been multiple improvements to the server connection.
Server resources can now contains a server name, resulting in the following URI:
When available, this server name is now used to list and open recent files and states, favorites folder and differentiate more generally between servers of the same scheme-host-ports URI. When not available, the behavior stays as it was before.
The server resource concept of session scheme has been removed and related methods have been deprecated.
This causes a small backwards compatibility issue where session recent state files will not be detected. Resetting ParaView's settings (Edit -> Reset to default settings) is a simple fix to that.
You can now delete all macros or scripts or servers in one go.
Macros -> Delete All.Tools -> Python Script Editor), then go to Scripts -> Delete All.ParaView will ask for a confirmation before deleting all items to prevent an accidental wipe of all items.
New "Delete All" button in the Choose Server Configuration dialog.
Two new Render View settings have been added to control whether or not to remove layers when growing selections:
When enabling both, only the last layer is shown.
You can now set the automatic rescale mode for the color transfer function only in the color editor. The confusing equivalent setting in the General group has been removed.
A newly implemented alternative illumination model is based on the physical behavior of light: while traversing a medium, photons can either be absorbed by matter or scattered in another direction. Both types of events are controlled by material-dependent properties. Absorption and out-scattering with the volume’s opacity are associated because both correspond to the light’s extinction inside the volume. In-scattered light is modeled by evaluating the light coming from secondary rays. The existing ray marching algorithm was augmented by adding a single secondary ray. At every sample point, a secondary ray is shot towards each light source and the light transmitted along each ray is estimated. The resulting quantity is integrated at each sample point and scattered using a Henyey-Greenstein phase function.
A new volume rendering property called Global Illumination Reach has been added. It is a value between 0 and 1, and it acts as a trade-off between realism and performance. More precisely, it controls the extent of the secondary ray: a value close to 0 will result in very short secondary rays (less realistic, only ambient occlusion, but faster), whereas a value close to 1 will result in long-extent shadow rays (more realistic, but slower).
> and new volume rendering mode with scattering (right).")
Comparison between the former volume rendering shading model (left) and the new one with scattering (right) on a medical dataset of a human thorax.
Palette backgrounds have been reorganized and a few new palettes have been introduced.
It is now possible to add a logo in a Chart View. Previously, the Logo Source could only be used with Render View and other 3D views.
An example of a logo in a Chart View.
Plots elements now have an opacity property that can be set.
The parameter is exposed in all chart representations based on the vtkXYChartRepresentation class: Line Chart, Point Chart, and Bar Chart representations.
New chart opacity controls.
A new representation has been added that behaves like the Geometry Representation by default and adds three new modes for 2-dimensional Hyper Tree Grid (HTG) datasets:
When using these modes, if the Camera Parallel Projection property is enabled in the view and the HTG is 2-dimensional, the Adaptive Decimation filter is used to map only the part of the HTG that is visible on the screen to enhance rendering performance.
Hyper Tree Grid datasets are supported in more filters:
ParaView now supports overriding certain filters such as Contour, Gradient, Cell Data to Point Data, and Point Data to Cell Data with VTK-m accelerated versions of those filters. A new ParaView General setting Use Accelerated Filters controls whether overrides are enabled.
You can now apply an isometric camera view direction from the camera toolbar in ParaView.
New isometric view button.
Color legends may now have a background drawn behind the color legend components. The color and opacity of the background can be specified, as can padding around the color legend components and the edge of the background.
Additionally, an outline around the scalar bar can now be displayed. The scalar bar outline's color and thickness can be set via newly added properties.
Properties for the new addition have been added to a new Appearance group in the Edit Color Legend Properties dialog. The previously existing properties controlling the thickness and length of the scalar bar have been added to this group as well.
New display properties for color legends. Left: existing display. Middle: scalar bar outline enabled. Right: Background set to black and scalar bar outline enabled.
Controls for new color legend display properties.
The range values of the visible scalar fields can now be displayed on color legends. To do so, click on the "Edit Color Map" icon, then in the new menu, click on the "Edit color legend properties" icon. If the checkbox Show Range is on, then the range will be printed next to the color bar.
The range printed consists of a Min value and a Max value. The Min value (Max value) is the minimum (maximum) value of all combined arrays that share the same name and are visible in the view, i.e., those with an open eyeball in the Pipeline Browser.
A Window Location property has been added to the Logo Representation to position the logo more easily at different locations in the window.
You can now save the materials created in the Material editor using the "Save materials" button. All materials are written in a new single json file. See https://gitlab.kitware.com/paraview/materials/blob/master/ospray_mats.json for an example.
Integration of the project https://github.com/JonasLukasczyk/paraview-node-editor
This plugin contains a node editor for ParaView that makes it convenient to modify filter and view properties, filter input and output connections, as well as control the visibility of outputs in views. The editor is complementary to the existing ParaView widgets such as the Pipeline Browser and the Properties panel. They can be used simultaneously.
A simple pipeline represented in the Node Editor plugin's interface.
The new SpaceMouseInteractor plugin enables ParaView to connect to a SpaceMouse-style device from 3DConnexion if it is available, and use it to manipulate the camera in the active Render View. The 3Dconnexion Settings app provided with the device driver can be used to change the style of interaction from object-centered to camera-centered (flying). This feature works on Windows and Mac only.
This new plugin expose most of parametric surfaces from VTK in a single source called "Parametric Surfaces". The surfaces have many parameters to control the generated surfaces and support to generate texture coordinates.
The CDI reader plugin now uses CDI version 2.0. Also, CDI is now an external dependency so building this plugin requires obtaining libcdi (see https://gitlab.dkrz.de/mpim-sw/libcdi).
Instead of showing the Plugin Manager on connection when plugin requirements are not satisfied, the Plugin Manager will now try to load server plugins if they are available. If not, the behavior is the same as before.
The Looking Glass plugin is now available on Apple Macintosh systems with ARM64 processors.
The Looking Glass plugin now supports portrait devices and target device selection. Target device selection enables you to save quilt images and movies for a different device than the one currently connected, meaning it is possible to make quilts for devices you cannot access directly.n the one currently connected, meaning it is possible to make quilts for devices you cannot access directly.
The Rename Arrays filter allows renaming arrays from any dataset. Data arrays are shallow copied so there is no memory increase using this array (note that string arrays are still deep copied).
Table data inputs are now accepted in the PythonCalculator filter. Basic Python operations can be performed on the columns of one or multiple input table(s). If the Copy Arrays property is enabled when the result of the Python operation happens to be a scalar value, the output will be a column whose values are all set to this scalar result. When using multiple input tables, the data may be accessed using the syntax : inputs[0].RowData["column"].
The Clipping filter has been sped up overall. Box clipping with the Exact property turned on has been significantly sped up using a smart strategy for determining the order of clips to apply.
Compute Connected Surface Properties is a new filter that enables computation of surface area, volume, and centroid of individual objects in an input polygonal dataset.
This new filter enables cell extraction based on cell type (i.e. triangles, hexahedra, etc.). More than one type of cell can be selected for extraction via checkboxes.
A new Generate Time Steps filter that adds time steps on any input data, ignoring input time steps if any. Example usage for this filter is to create timesteps on non-temporal sources to enable use of the Particle Tracer filter.
The Threshold Table filter is now available to perform four different thresholding operations. Its input properties are:
The four different modes are:
These filters have the following improvements:
1) The filters are now multithreaded. Multithreading is used when there is only one MPI process, and the number of particles is greater than 100. 1) They now have an Interpolator Type property which can either use a cell locator (default) or a point locator for interpolation. 1) Instead of the Static Mesh flag, they now have the Mesh Over Time flag which has the following values: 1) "Different": The mesh is different over time. 1) "Static": The mesh is the same over time. 1) "Linear Transformation": The mesh is different over time, but it is a linear transformation of the first time-step's mesh. 1) "Same Topology": The mesh is different over time, but it preserves the same topology (same number of points/cells, same connectivity). 1) For cell locators, this is equivalent to when Mesh Over Time is set to Different. 2) For point locators, this flag internally reuses the same cell links.
ParaView now provides the Extract Particles Over Time filter to extract particles passing through a volume over time.
The filter has two inputs: Particles and Volume. The Particles input should contain points evolving over time and the Volume input is expected to be a volumetric dataset.
The output is a subset of the particles from the input, still temporal.
Slice filters have the following improvements:
vtkHyperTreeGrid and vtkOverlappingAMR inputs.vtkStructuredGrid, vtkRectilinearGrid vtkUnstructuredGrid with 3d linear cells, and vtkPolyData with convex cells.vtkImageData.The Mesh Quality filter now supports wedges and pyramids cell types and has additional metrics for the existing cell types. Moreover, it has been multithreaded.
The new Finite Element Field Distributor filter can be employed to visualize Discontinuous Galerkin (DG) finite element fields of type H(Grad), H(Curl), and H(Div).
Note that all cells must be of the same type and the field data must contain a vtkStringArray describing the DG fields, basis types, and reference cells. Currently, the IOSS Exodus reader is the only one that produces this field data array.
The Temporal Particles Path Lines filter now can compute particles lines when you set the time backward. The new behavior can be activated by checking the Backward Time checkbox (advanced property).
ParaView's file reader selection mechanism now ignores the case of file extensions.
A new VTKHDF file reader specific to VTK datasets is now available. In this version, the VTKHDF reader supports serial and parallel image data and unstructured grid and serial Overlapping AMR support. One format supports both serial and parallel processing and only one extension (.hdf) for all VTK data formats. For HDF AMR datasets, it is possible to select the maximum number of level to read for HDF AMR in the same way the classic .vth file reader.
If the IOSSReader detects the displacements array, you can now scale those displacements by specifying a displacement magnitude. The default value is 1 (no scaling).
You can now toggle the Group Numeric Vector Field Components property from the IOSSReader property panel. You can also specify a string for the Field Suffix Separator property that is interpretted as the string that separates the vector field name from the index of the component the array provides.
When Group Numeric Vector Field Components is
By default, the IOSS reader ignores real[n] fields and the field suffix separator is empty.
Exodus files have block/set ids, in addition to optional custom names. When these custom names were present, it was not clear which name corresponded to which id in the file. To help with this, the IOSS reader now shows block/set ids in the Blocks/Sets selection widgets shown on the Properties Panel.
The Properties Panel now shows block IDs from the IOSS Reader.
An initial version of IOSS writer that uses the IOSS library to write Exodus files is now available. The writer is used when writing files with extensions .exo. The writer is not fully functional yet, for example, it does not support serializing other entity blocks / sets besides element blocks, node sets and side sets. Once these capabilities are added and the writer goes though some aggressive testing, this will replace the Exodus writer for all Exodus files. Until then, the current version should be treated as a beta-release.
Added recognition of .encas file extension for the Ensight Case Gold reader.
Generation of a "GlobalNodeId" array in the parallel versions of the Ensight Gold and Binary readers can lead to duplicate IDs. These duplicate IDs could make some filters, such as the Ghost Cell Generator and Redistribute Dataset, crash afterward.
Because creating global IDs in the readers is not needed anymore, we remove it to resolve the problem.
It is now possible to read either cell or face-centered data arrays in CGNS files describing meshes with 3D cells. This is done by considering the 3D cells or the 2D faces (e.g., one cell versus six faces for a cube), respectively.
Note that the element connectivity in the CGNS file must be defined with element type NGON_n to construct face-based meshes. Data arrays should then be defined with GridLocation_t either set to CellCenter or FaceCenter, respectively. Note: the FaceCenter location is an unofficial extension of the CGNS standard.
The location of the data to read can be selected using the combo box Data Location in the Properties tab when reading a CGNS file. The available options are "Cell Data" or "Face Data", respectively. Note that the default value is "Cell Data", which corresponds to the previous default behavior.
It is now possible to read .vdb files containing grids or point sets. This offers the ability to open volumetric datasets exported from popular animation software such as Blender or Maya.
A new reader adds support for the Nastran Bulk Data file format (.bdf extension). Only a subset of the "free field format" is now supported, including the following keywords: GRID, CTRIA3 and PLOAD2.
Particle time series support was fixed for the openPMD Python module. Previously, when meshes were deselected, particle time updates did not work anymore.
ParaView has a new plane widget which replaces the old plane widget.
The new plane widget defining a slice plane.
When saving VTK XML file writers for multiblock datasets (.vtm), partitioned dataset collections (.vtpc), and uniform grid AMR datasets (.vthb), you can choose which blocks to write with a new block selector in the Configure Writer dialog.
The CSV file writer is now a time-aware writer, and it can write all time steps in a single file or separate files (the default is a single file). Additionally, it can now write a column with the timestep values (the default is off).
The CGNS writer can now handle partitioned datasets that are empty. In addition, the writer can now handle writing all steps of a dataset in different timesteps files which can be read by the CGNS reader.
vtkPointSet.A checkbox is now provided in the Output Messages window to keep it closed when there is a new message available. This can prevent the annoying behavior of the Output Messages window popping up for repeated warnings that can be safely ignored. ParaView disables this checkbox when the Output Messages window is docked and the window remains open regardless of the option's value.
ParaView now clears the contents of the Output Messages window when you reset the session.
When using interactive widgets in the 3D view (Line Source, Plot Over Line, Stream Tracer, etc.) it is now possible to lock the movement of the widget along the X, Y or Z axis by pressing the 'x' , 'y' or 'z' key, respectively, while interacting with the widget.
With the line widget it is also possible to constrain its movement along the vector of its own direction using the l (for **L**ine) key.
When opening some file formats, ParaView needs help to determine which reader to use. A new setting keeps track of the preferred reader to use when reading a file that matches a particular pattern. The preferred reader can be set when choosing the reader in the Open Data With... dialog. This setting is editable in the "Miscellaneous" settings.
You can now change the file of a reader by right-clicking on it in the Pipeline Browser, and then clicking on Change File in the menu.
A Delete Downstream Pipeline option has been added to the context menu and Edit menu. When selected, this will delete the selection and all downstream filters, eliminating the need to delete each filter individually.
The "Delete Downstream Pipeline" and "Change File" items are new options in the Pipeline Browser context menu.
There is now a new toolbar for lighting. This toolbar currently contains only a button to enable/disable the light kit.
The Light Controls toolbar.
New options in the Animation Keyframes editors, leading to:
Camera animation track modes are now available as follows:
Each keyframe defines a control point on a spline for camera position, and an independent one for the camera's focal location. An orbit (i.e. a circle) can be configured from the Animation Keyframes editor instead of upon track creation. By default, the orbit path is defined by points around the selected source from current camera.
The camera is moved so its focal point is set to the center of the data selected in the Pipeline Browser. No keyframes are defined in this mode.
Each keyframe is a camera. The animation interpolates between cameras, either with spline or line depending on whether the Spline Interpolation option is enabled in the Animation Keyframes dialog. Buttons in the Animation Keyframees provide ways to set keyframe positions from the current camera position.
By implementing these new options, it was possible to simplify the camera cue creation menu in the Animation View. The previously available options and the way to create them now are detailed below:
You can now reverse the playback of animations back to the beginning.
Hover selection modes (Hover cells on and Hover points on) now support to copy the content of the tooltip to the clipboard by pressing Ctrl+C.
The "Zoom To Data" actions ("Zoom To Data" and "Zoom Closest To Data") now consider the visibility of the source and its blocks. If only some blocks of the source are visible, then the "Zoom To Data" zooms based on only the bounding box of the visible blocks, only in builtin and remote rendering mode.
In addition, the "Zoom To" button is now disabled when the active source is not visible.
A new setting Select On Click In Multi Block Inspector has been added to ParaView. Turning off this setting changes the behavior of the MultiBlock Inspector (and potentially similar Widgets) so that clicking on a block no longer selects it.
You can now change the direction of the mouse wheel for zooming in and out by enabling the Reverse Mouse Wheel Zoom Direction checkbox in the Camera settings.
You can now use the mouse wheel to zoom in to or out from the projected point under the cursor position without holding down the control key by enabling the Mouse Wheel Zooms To Cursor checkbox in the Settings dialog.
ParaView's status bar now displays the memory status of the server process with the highest memory usage in terms of percentage of total memory. This is similar to what is displayed in the Memory Inspector but is intended to be more visible to more readily identify when the server is under high load.
The MultiBlock Inspector now has a button that adds an Extract Blocks filter that is initialized to the blocks selected in the dialog.
Multi-block Inspector has been renamed to MultiBlock Inspector.
To edit the color of a color transfer function node in the Color Map Editor, press the Enter (or Return) key when the node is selected. The previous bug-prone way to edit the node color involved a mouse double click.
When you save files into directories, ParaView presents a much clearer dialog to select the output directory.
When the file dialog is in directory mode:
Some improvements have been made to the favorites list in file open and saving dialogs:
When opening input file(s) from paraview file dialog, the "Create a new folder" tool button is now no longer shown.
ParaView now has the needed code base to support interactive widgets in context views such as the Line Chart View. One of the first filters using this feature is the Equalizer Filter.
Here is an example of what you can do using the Equalizer Filter in ParaView:
Source data:
After applying the filter:
See the discourse thread for background on the development of this feature.
You can now glob file patterns using the paraview.util package in Python. The function is called paraview.util.Glob(path, rootDir = None). This can be especially useful in a client/server connection to fetch a list of file sequences available on the server that match a wildcard expression.
As an example of its usage, assume that one holds a the list of files file0.png, file1.png in the current working directory.
This script will print
[file0.png, file1.png]
Any expression supported by the Python package fnmatch is supported.
The paraview package now has a __version__ attribute that contains the ParaView version that is loaded. In addition __version_full__ contains the full ParaView version string (including any git information).
ParaView now includes the backward compatibility version when writing Python state files (*.py).
The OpenVR plugin is now named the XRInterface plugin, and the VRPlugin is now called the CAVEInteraction plugin.
The XRInterface plugin now supports the OpenXR and OpenVR standards on Windows using SteamVR and on linux using the Monado OpenXR runtime. Which runtime to use when the "Send To VR" button is clicked is a selectable.
The starting trigger action when launching XR mode has been changed from Probe to Pick.
Additionally, the starting orientation of the scene has been changed so that the View Up direction is now +Y, which is more commonly used e.g. with skyboxes.
Two movement styles for VR interactions are now available in the VR menu. The first one is named "Flying" and was the default style until now. You can move in the scene according to the direction of the controller (the left one by default) by pushing the joystick up or down. The second one is named "Grounded". It allows you to move on the XY (ground) plane using the four directions of the joystick (the left one by default), according to the view direction of the headset. You can also modify the elevation of the scene by pushing the right joystick (by default) up or down.
Catalyst now supports field data on meshes. In the conduit node, fields should be defined under the state/fields node of the mesh. The name of the sub-node will be the name of the field array. String values and numeric arrays, including MCArray Blueprint, are supported.
The VTKExtensions/Conduit module is now part of VTK, as IO/CatalystConduit module. The vtkDataObjectToConduit converter is integrated into this module instead of its prior Clients/InSitu location.
As a side effect, Catalyst (our Conduit provider) is no more a ThirdParty of ParaView but instead an external dependency of VTK.
The CMake option PARAVIEW_ENABLE_CATALYST controls the build of the VTK module and of the ParaView Catalyst implementation (default OFF). A local build of Catalyst should be provided (via cmake -Dcatalyst_DIR).
Catalyst can now use the Fides reader, when using the ADIOS2 Inline engine. Documentation for using ParaView Catalyst with the Fides reader is located in the Fides User Guide.
vtkConduitSource to output MultiBlock datasetsThe vtkConduitSource can optionally convert its output to a vtkMultiBlockDataSet.
The ParaView Conduit Blueprint protocol now supports an optional state/multiblock integer node inside the global or channel nodes. When it exists and set to a integer other than 0, the vtkConduitSource is setup to output multiblock.
A bug that causes a deadlock if catalyst is not used on all MPI ranks has been fixed. This MR fixes the issue: https://gitlab.kitware.com/paraview/paraview/-/issues/21414
ParaView now provides a CGNS extractor to save data to CGNS files.
Extractors now support a trigger type which allows users to invoke Python scripts to determine if the extractor should be activated or not. This allows for more flexible triggers than the simple time or timestep based triggers supported previously.
The Save Extracts dialog now has Frame Window and Frame Stride properties that allow you to limit the timesteps extracted and select how many frames to skip between each frame. These are global settings that apply to all extractors, and are separate from the TimeStep and TimeValue trigger properties of individual extractors.
The cinemasci Python module has been updated to commit e7666713.
readerSet parameter to pqLoadDataReaction::loadDataThe useful pqLoadDataReaction::loadData function now has a readerSet parameter to limit the the proposed types of file readers shown to you.
ParaView client applications may need to trace actions that do not fit the ParaView pattern of simple function calls or proxy methods. Other patterns are now supported using the new TraceText item with the SM_SCOPED_TRACE macro. For example:
ShowLabel hintA ShowLabel hint for StringVectorProperty elements is now available that makes the associated widget display the Label and Documentation of the property.
ParaView now has a widget for manipulating coordinate frames. A coordinate frame is all the information needed to uniquely specify a linear transformation:
If you have a group of properties containing 4 double-vectors, you can add panel_widget="InteractiveFrame" to the group's XML attributes and it will appear in the properties panel as a pqCoordinateFramePropertyWidget.
See this VTK discourse topic for more information about how to use the widget.
New custom applications examples have been added:
SimpleParaView as an example of how to include a pluginDemo2 example that closes the gap between the Demo1 and SimpleParaView examplesSpreadsheet exampleThe following deprecated proxies has been deleted:
1) GlyphLegacy 2) Glyph With Custom Source Legacy 3) plyreader 4) Legacy Resample With Dataset 5) UnstructuredGridBaseRepresentation
The following deprecated proxies will be removed in 5.12:
1) Extract Level (Legacy) 2) Gradient Of Unstructured DataSet 3) ProbeLineLegacy 4) GradientLegacy
Finally, Slice (demand-driven-composite) has been deprecated and will be removed in 5.13.
vtkPVGeometryFilter::UseStripsThe vtkPVGeometryFilter's SetUseStrips and related methods are now deprecated. As of VTK 9.1.0, the backing implementation did nothing anyway.
The PARAVIEW_BUILD_EXAMPLES variable is now named PARAVIEW_ENABLE_EXAMPLES to better indicate that the examples are not directly built.
placeWidget with a signalAll the PropertyWidgets that their placeWidget depend on the bounds of the datasource, now use pqActiveObjects::dataUpdated signal to placeWidget in case the dataset changes (e.g. it's a filter).
Resolution of issue https://gitlab.kitware.com/paraview/paraview/-/issues/20520.
pqApplyBehaviorpqApplyBehavior can now be used without registering any pqPropertiesPanel.pqApplyBehavior is now responsible for the auto apply mechanismvtkPVGeneralSettingspqPropertiesPanelpqPVApplicationCore::applyPipeline lets you apply a pipeline without need to use a pqPropertiesPanelQuickLaunch dialog now supports quick apply by pressing the shift key when selecting a filter or a source to applySome plugins need to invoke a function when they are loaded rather than relying on static initialization. Examples of this include:
This can be accomplished via the pqAutoStartInterface in Qt-based applications or via a Python initializer when building ParaView with Python; however, there was not a way to do this robustly in all build configurations.
Now, the add_paraview_plugin macro accepts two new parameters:
INITIALIZERS, which accepts a list of free functions to invoke when the plugin is loaded; andEXTRA_INCLUDES, which accepts a list of header files to include in the plugin's implementation. (This is useful for ensuring the free functions are declared before they are invoked.)ParaView needs to call pqApplicationComponentsInit() to initialize Qt resources only for static builds. However, if client apps want to re-use ParaView Qt resources for their own menus/toolbars, they need to call pqApplicationComponentsInit() always, even for shared builds. This is now possible.
vtkExtractHistogram has been moved upstream into the VTK project. Hence it has been removed from the paraview project. The vtkPExtractHistogram subclass has been modified to reflect the normalize/accumulate features added to vtkExtractHistogram.
ParaView now enables saving custom default settings when exporting scenes. Before, these settings were shown and set using a custom QDialog. We substitute it with a pqProxyWidgetDialog, which natively provide buttons to save settings as default properties.
ParaView now has a singleton object, pqKeySequences, that can be used to create and manage Qt shortcuts so that there are no collisions between widgets/actions that both want the same keyboard shortcut.
An example of this is when a property panel might wish to use both a handle widget and a line widget. Each of these registers shortcuts for the P and Ctrl+P/Cmd+P keys. Because multiple widgets registered shortcuts for the same key, Qt never signals either widget unambiguously when these keys are pressed.
By registering shortcuts with this class, widgets will have their shortcuts enabled and disabled so that only one is using the shortcut at a time. The user is shown which widgets have shortcuts registered (via a frame highlighted with a thin blue line, the same as the active view's highlighting) and can enable/disable widgets by clicking on the Qt widget's background.
To accomplish the above, several changes to pqPropertyWidget and its subclasses as well as to the pqPointPickingHelper were required:
pqPropertyWidget inherits QFrame instead of QWidget. By default, the frame is configured not to render or take any additional space. However, when shortcuts are registered with pqKeySequences, a new decorator class named pqShortcutDecorator configures the frame to reflect when shortcuts are registered and enabled.pqPointPickingHelper previously accepted any QObject as a parent. However, all occurrences of this class used property widgets as the parent. By forcing parents to be of this type, subclasses of pqInteractivePropertyWidget that used the picking helper do not need to manage visibility changes. (Instead pqShortcutDecorator enables/disables shortcuts to match visibility changes.) If you use pqPointPickingHelper in your code, ensure its parent class is a pqPropertyWidget and remove any usage of the setShortcutEnabled() method.A few tree view widgets, like pqArrayStatusPropertyWidget and pqDataAssemblyPropertyWidget now allow sorting by clicking on the column headers, as well as via the existing triangle menu. This follows standard Qt conventions for sorting tables. Previously clicking the header checked or unchecked all items in the table - this behavior is still available by clicking the checkbox in the header.
vtkGeometryFilter for Rendering/ExtractSurfacevtkPVGeometryFilter and Extract Surface now use vtkGeometryFilter instead of vtkDataSetSurfaceFilter. Due to this change, the Use Geometry Filter flag has been removed. Finally, the Remove Ghost Interfaces flag has been added which allows the removal of ghost interfaces when the surface is extracted.
vtkCLIOptions::GetExtraArguments now returns a reference to a vectorPreviously, vtkCLIOptions::GetExtraArguments() would return a copy of a vector of argument strings. It now returns a const& to a vector rather than forcing a copy onto callers.
ParaView now has the vtkParaViewDeprecation.h header which contains PARAVIEW_DEPRECATED_IN_X_Y_Z() macros to mark APIs as deprecated (where X, Y, and Z are version component numbers).
vtkPVConfig.h deprecationThe vtkPVConfig.h header is deprecated. For version information, use vtkPVVersion.h. For PARAVIEW_USE_QTHELP, use pqQtConfig.h from ParaView::QtCore. For PARAVIEW_USE_QTWEBENGINE, use pqQtWidgetsConfig.h from ParaView::QtWidgets.
1.8.13 on Sun Dec 14 2025
