Public Types | Public Slots | Signals | Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Member Functions | List of all members
pqLoadDataReaction Class Reference
Reaction for open data files. More...
#include <pqLoadDataReaction.h>
Inheritance diagram for pqLoadDataReaction:
Collaboration diagram for pqLoadDataReaction:
typedef QPair< QString, QString > ReaderPair
typedef QSet< ReaderPair > ReaderSet
Public Slots
void updateEnableState () override
 Updates the enabled state. More...
Signals
void loadedData (pqPipelineSource *)
 Fired when a dataset is loaded by this reaction. More...
 pqLoadDataReaction (QAction *parent)
 Constructor. More...
- Public Member Functions inherited from pqReaction
 pqReaction (QAction *parent, Qt::ConnectionType type=Qt::AutoConnection)
 ~pqReaction () override
QAction * parentAction () const
 Provides access to the parent action. More...
static pqPipelineSource * loadData (const QList< QStringList > &files, const QString &readergroup=QString(), const QString &readername=QString(), pqServer *server=nullptr)
 Loads multiple data files. More...
static pqPipelineSource * loadData (const QStringList &files, const QString &readergroup=QString(), const QString &readername=QString(), pqServer *server=nullptr)
 Loads data files. More...
static QVector< pqPipelineSource * > loadFilesForSupportedTypes (QList< QStringList > files)
 Called when the file dialog filter was on "Supported Types" or when dropping a file. More...
static QList< pqPipelineSource * > loadData (const ReaderSet &readerSet, bool groupFiles=true)
 Convenience static method that shows a file dialog, let user select files and opens the selected files. More...
static QList< pqPipelineSource * > loadData (bool groupFiles=true)
void onTriggered () override
 Called when the action is triggered. More...
static bool TestFileReadability (const QString &file, pqServer *server, vtkSMReaderFactory *factory)
static bool DetermineFileReader (const QString &filename, pqServer *server, vtkSMReaderFactory *factory, QPair< QString, QString > &readerInfo)
static pqPipelineSource * LoadFile (const QStringList &files, pqServer *server, const QPair< QString, QString > &readerInfo)
static QVector< pqPipelineSource * > loadFilesForAllTypes (QList< QStringList > files, pqServer *server, vtkSMReaderFactory *readerFactory)
 Called when the file dialog filter was on "All Types" Lists all existing readers for the user to choose. More...
static void addReaderToDefaults (QString const &readerName, pqServer *server, vtkSMReaderFactory *readerFactory, QString const &customPattern="")
 Adds the reader to the defaults readers settings. More...
- Protected Slots inherited from pqReaction
virtual void updateEnableState ()
virtual void updateMasterEnableState (bool)
- Protected Attributes inherited from pqReaction
bool IsMaster
Definition at line 20 of file pqLoadDataReaction.h.
◆ ReaderPair
typedef QPair<QString, QString> pqLoadDataReaction::ReaderPair
Definition at line 65 of file pqLoadDataReaction.h.
◆ ReaderSet
Definition at line 66 of file pqLoadDataReaction.h.
◆ pqLoadDataReaction()
pqLoadDataReaction::pqLoadDataReaction ( QAction *  parent)
Constructor.
Parent cannot be nullptr.
◆ loadData() [1/4]
static pqPipelineSource* pqLoadDataReaction::loadData ( const QList< QStringList > &  files,
const QString &  readergroup = QString(),
const QString &  readername = QString(),
pqServer *  server = nullptr
Uses reader factory to determine what reader are supported. If a file requires user input the reader of choice, it will use that reader for all other files of that type. Returns the reader is creation successful, otherwise returns nullptr. Note that this method is static. Applications can simply use this without having to create a reaction instance.
If readergroup and readername are non empty, then they are assumed to be the type of the reader to use and reader factory is not used.
If server is nullptr, active server is used.
◆ loadData() [2/4]
static pqPipelineSource* pqLoadDataReaction::loadData ( const QStringList &  files,
Loads data files.
Uses reader factory to determine what reader are supported. Returns the reader is creation successful, otherwise returns nullptr. Note that this method is static. Applications can simply use this without having to create a reaction instance.
◆ loadData() [3/4]
static QList<pqPipelineSource*> pqLoadDataReaction::loadData ( const ReaderSet &  readerSet,
bool  groupFiles = true
readerSet is a set of readergroup, readername pair to restrict the proposed types of files shown to the user, not using it let the user choose between all files. Returns the list of opened file in the pipeline. Set groupFiles to false to disable automatic file group mechanisms
◆ loadData() [4/4]
static QList<pqPipelineSource*> pqLoadDataReaction::loadData ( bool  groupFiles = true)
◆ loadFilesForSupportedTypes()
static QVector<pqPipelineSource*> pqLoadDataReaction::loadFilesForSupportedTypes ( QList< QStringList >  files)
First search for a matching reader in the default readers settings, and if none is found use the standard method to choose a reader.
◆ updateEnableState
void pqLoadDataReaction::updateEnableState ( )
overrideslot
◆ loadedData
void pqLoadDataReaction::loadedData ( pqPipelineSource *  )
signal
◆ onTriggered()
void pqLoadDataReaction::onTriggered ( )
inlineoverrideprotectedvirtual
Definition at line 104 of file pqLoadDataReaction.h.
◆ TestFileReadability()
static bool pqLoadDataReaction::TestFileReadability ( const QString &  file,
pqServer *  server,
vtkSMReaderFactory *  factory
staticprotected
◆ DetermineFileReader()
static bool pqLoadDataReaction::DetermineFileReader ( const QString &  filename,
pqServer *  server,
vtkSMReaderFactory *  factory,
QPair< QString, QString > &  readerInfo
staticprotected
◆ LoadFile()
static pqPipelineSource* pqLoadDataReaction::LoadFile ( const QStringList &  files,
pqServer *  server,
const QPair< QString, QString > &  readerInfo
staticprotected
◆ loadFilesForAllTypes()
static QVector<pqPipelineSource*> pqLoadDataReaction::loadFilesForAllTypes ( QList< QStringList >  files,
pqServer *  server,
vtkSMReaderFactory *  readerFactory
staticprotected
If the user clicks "Set reader as default", this lets the user choose the pattern they want to add to the setting for this reader.
◆ addReaderToDefaults()
static void pqLoadDataReaction::addReaderToDefaults ( QString const &  readerName,
pqServer *  server,
vtkSMReaderFactory *  readerFactory,
QString const &  customPattern = ""
staticprotected
If customPattern is empty, the reader pattern will be used.
