vtkPVGeneralSettings Class Reference
object for general options. More...
#include <vtkPVGeneralSettings.h>
Inheritance diagram for vtkPVGeneralSettings:
Collaboration diagram for vtkPVGeneralSettings:
enum  { DEFAULT_TIME_STEP_UNCHANGED, DEFAULT_TIME_STEP_FIRST, DEFAULT_TIME_STEP_LAST }
 Enum for DefaultTimeStep. More...
enum  RealNumberNotation { MIXED = 0, SCIENTIFIC, FIXED, FULL }
enum  { ALL_IN_ONE = 0, SEPARATE_DISPLAY_PROPERTIES = 1, SEPARATE_VIEW_PROPERTIES = 2, ALL_SEPARATE = 3 }
virtual void SetAutoConvertProperties (bool)
 Automatically convert data arrays as needed by filters including converting cell arrays to point arrays, or vice versa, and extracting single components from multi-component arrays. More...
virtual bool GetAutoConvertProperties ()
virtual void AutoConvertPropertiesOn ()
virtual void AutoConvertPropertiesOff ()
virtual int GetBlockColorsDistinctValues ()
 Determines the number of distinct values in vtkBlockColors. More...
virtual void SetBlockColorsDistinctValues (int)
virtual bool GetAutoApply ()
 Automatically apply changes in the 'Properties' panel. More...
virtual void SetAutoApply (bool)
virtual int GetAutoApplyDelay ()
 Get/Set delay for auto apply. More...
virtual void SetAutoApplyDelay (int)
virtual bool GetAutoApplyActiveOnly ()
virtual void SetAutoApplyActiveOnly (bool)
virtual bool GetPreservePropertyValues ()
 Preserve applied properties values for next use. More...
virtual void SetPreservePropertyValues (bool)
virtual std::string GetDefaultViewType ()
 } More...
virtual void SetDefaultViewType (std::string)
virtual std::string GetInterfaceLanguage ()
 Get/Set the default interface language. More...
virtual void SetInterfaceLanguage (std::string)
virtual void SetCacheGeometryForAnimation (bool)
 Set when animation geometry caching is enabled. More...
virtual bool GetCacheGeometryForAnimation ()
virtual void CacheGeometryForAnimationOn ()
virtual void CacheGeometryForAnimationOff ()
virtual void SetAnimationGeometryCacheLimit (unsigned long)
 Set the animation cache limit in KBs. More...
virtual unsigned long GetAnimationGeometryCacheLimit ()
virtual void SetAnimationTimeNotation (int)
 Set the notation for the animation time toolbar. More...
virtual int GetAnimationTimeNotation ()
virtual void SetAnimationTimeShortestAccuratePrecision (bool)
 Get/Set the usage of shortest accurate precision instead of actual precision for animation time. More...
virtual bool GetAnimationTimeShortestAccuratePrecision ()
virtual void SetAnimationTimePrecision (int)
 Set the precision of the animation time toolbar. More...
virtual int GetAnimationTimePrecision ()
virtual void SetShowAnimationShortcuts (bool)
 Set when animation shortcuts are shown. More...
virtual bool GetShowAnimationShortcuts ()
virtual void ShowAnimationShortcutsOn ()
virtual void ShowAnimationShortcutsOff ()
virtual void SetResetDisplayEmptyViews (bool)
 Set whether to reset display when showing a representation in an empty view. More...
virtual bool GetResetDisplayEmptyViews ()
virtual void ResetDisplayEmptyViewsOn ()
virtual void ResetDisplayEmptyViewsOff ()
virtual void SetRealNumberDisplayedNotation (int)
 Get/Set the notation of real number displayed in widgets or views. More...
virtual int GetRealNumberDisplayedNotation ()
virtual void SetRealNumberDisplayedShortestAccuratePrecision (bool)
 Get/Set the usage of shortest accurate precision instead of actual precision for real numbers. More...
virtual bool GetRealNumberDisplayedShortestAccuratePrecision ()
virtual void SetRealNumberDisplayedPrecision (int)
 Get/Set the precision of real number displayed in widgets or views. More...
virtual int GetRealNumberDisplayedPrecision ()
virtual void SetFullNotationLowExponent (int)
 Get/Set the low exponent used with full notation. More...
virtual int GetFullNotationLowExponent ()
virtual void SetFullNotationHighExponent (int)
 Get/Set the high exponent used with full notation. More...
virtual int GetFullNotationHighExponent ()
virtual void SetInheritRepresentationProperties (bool)
 Forwarded for vtkSMParaViewPipelineControllerWithRendering. More...
virtual bool GetInheritRepresentationProperties ()
virtual void InheritRepresentationPropertiesOn ()
virtual void InheritRepresentationPropertiesOff ()
virtual void SetIgnoreNegativeLogAxisWarning (bool)
 Description: When plotting data with nonpositive values, ignore the standard warning and draw only the data with positive values. More...
virtual bool GetIgnoreNegativeLogAxisWarning ()
virtual void IgnoreNegativeLogAxisWarningOn ()
virtual void IgnoreNegativeLogAxisWarningOff ()
virtual void SetPropertiesPanelMode (int)
 Properties panel configuration. More...
virtual int GetPropertiesPanelMode ()
virtual void SetLockPanels (bool)
 Set whether to dock widgets into place. More...
virtual bool GetLockPanels ()
virtual void SetLoadAllVariables (bool)
 Load all variables when loading a data set. More...
virtual bool GetLoadAllVariables ()
virtual void LoadAllVariablesOn ()
virtual void LoadAllVariablesOff ()
virtual void SetLoadNoChartVariables (bool)
 Load no variables when showing a 2D chart. More...
virtual bool GetLoadNoChartVariables ()
virtual void LoadNoChartVariablesOn ()
virtual void LoadNoChartVariablesOff ()
virtual void SetGUIFontSize (int)
 Get/Set the GUI font size. More...
virtual int GetGUIFontSize ()
virtual void SetGUIOverrideFont (bool)
 Get/Set whether the GUIFontSize should be used. More...
virtual bool GetGUIOverrideFont ()
virtual void SetColorByBlockColorsOnApply (bool)
 Automatically color by vtkBlockColors if array is present on Apply. More...
virtual bool GetColorByBlockColorsOnApply ()
virtual void SetEnableStreaming (bool)
 Turn on streamed rendering. More...
virtual bool GetEnableStreaming ()
virtual void EnableStreamingOn ()
virtual void EnableStreamingOff ()
void SetUseAcceleratedFilters (bool)
 Enable use of accelerated filters where available. More...
bool GetUseAcceleratedFilters ()
virtual void UseAcceleratedFiltersOn ()
virtual void UseAcceleratedFiltersOff ()
virtual bool GetSelectOnClickMultiBlockInspector ()
 ActiveSelection is hooked up in the MultiBlock Inspector such that a click on a/multiple block(s) selects it/them. More...
virtual void SetSelectOnClickMultiBlockInspector (bool)
static vtkPVGeneralSettingsNew ()
static vtkPVGeneralSettingsSafeDownCast (vtkObject *o)
static vtkPVGeneralSettingsGetInstance ()
 Access the singleton. More...
static int GetNumberOfCallbackThreads ()
 Sets the number of threads that are used for vtkPVSession::ThreadedCallbackQueue. More...
static void SetNumberOfCallbackThreads (int)
static int GetNumberOfSMPThreads ()
 Sets the number of threads that are used by vtkSMPTools. More...
static void SetNumberOfSMPThreads (int)
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPVGeneralSettings ()=default
 ~vtkPVGeneralSettings () override=default
enum  { AUTOMATICALLY_SHOW_AND_HIDE_SCALAR_BARS = 0, AUTOMATICALLY_HIDE_SCALAR_BARS = 1, MANUAL_SCALAR_BARS = 2 }
 Enum for ScalarBarMode. More...
virtual void SetScalarBarMode (int)
virtual int GetScalarBarMode ()
vtkPVGeneralSettings keeps track of general options in a ParaView application. This is a singleton. All calls to vtkPVGeneralSettings::New() return a pointer to the same global instance (with reference count incremented as expected).
Definition at line 23 of file vtkPVGeneralSettings.h.
Definition at line 27 of file vtkPVGeneralSettings.h.
◆ anonymous enum
anonymous enum
Enumerator
Definition at line 116 of file vtkPVGeneralSettings.h.
◆ anonymous enum
anonymous enum
Enumerator
MANUAL_SCALAR_BARS
Definition at line 127 of file vtkPVGeneralSettings.h.
◆ RealNumberNotation
Enumerator
MIXED
SCIENTIFIC
FIXED
FULL
Definition at line 154 of file vtkPVGeneralSettings.h.
◆ anonymous enum
anonymous enum
Enumerator
ALL_IN_ONE
ALL_SEPARATE
Definition at line 266 of file vtkPVGeneralSettings.h.
◆ vtkPVGeneralSettings()
vtkPVGeneralSettings::vtkPVGeneralSettings ( )
protecteddefault
◆ ~vtkPVGeneralSettings()
vtkPVGeneralSettings::~vtkPVGeneralSettings ( )
overrideprotecteddefault
static vtkPVGeneralSettings* vtkPVGeneralSettings::New ( )
virtual const char* vtkPVGeneralSettings::GetClassName ( )
static int vtkPVGeneralSettings::IsTypeOf ( const char *  type)
virtual int vtkPVGeneralSettings::IsA ( const char *  type)
static vtkPVGeneralSettings* vtkPVGeneralSettings::SafeDownCast ( vtkObject o)
void vtkPVGeneralSettings::PrintSelf ( ostream &  os,
◆ GetInstance()
static vtkPVGeneralSettings* vtkPVGeneralSettings::GetInstance ( )
◆ SetAutoConvertProperties()
virtual void vtkPVGeneralSettings::SetAutoConvertProperties ( bool  )
◆ GetAutoConvertProperties()
virtual bool vtkPVGeneralSettings::GetAutoConvertProperties ( )
◆ AutoConvertPropertiesOn()
virtual void vtkPVGeneralSettings::AutoConvertPropertiesOn ( )
◆ AutoConvertPropertiesOff()
virtual void vtkPVGeneralSettings::AutoConvertPropertiesOff ( )
◆ GetBlockColorsDistinctValues()
virtual int vtkPVGeneralSettings::GetBlockColorsDistinctValues ( )
This array is added to each block if the dataset is a composite dataset. The array has one value set to (blockIndex % BlockColorsDistinctValues)
◆ SetBlockColorsDistinctValues()
virtual void vtkPVGeneralSettings::SetBlockColorsDistinctValues ( int  )
◆ GetAutoApply()
virtual bool vtkPVGeneralSettings::GetAutoApply ( )
Default is false.
◆ SetAutoApply()
virtual void vtkPVGeneralSettings::SetAutoApply ( bool  )
Default is false.
◆ GetAutoApplyDelay()
virtual int vtkPVGeneralSettings::GetAutoApplyDelay ( )
Not exposed in the UI. Default is 0.
◆ SetAutoApplyDelay()
virtual void vtkPVGeneralSettings::SetAutoApplyDelay ( int  )
◆ GetAutoApplyActiveOnly()
virtual bool vtkPVGeneralSettings::GetAutoApplyActiveOnly ( )
Default is false.
◆ SetAutoApplyActiveOnly()
virtual void vtkPVGeneralSettings::SetAutoApplyActiveOnly ( bool  )
Default is false.
◆ GetPreservePropertyValues()
virtual bool vtkPVGeneralSettings::GetPreservePropertyValues ( )
This is intended to be used for pipeline sources, and acts as "save current values as default" on each Apply. Default is false.
◆ SetPreservePropertyValues()
virtual void vtkPVGeneralSettings::SetPreservePropertyValues ( bool  )
◆ GetDefaultViewType()
virtual std::string vtkPVGeneralSettings::GetDefaultViewType ( )
Get/Set the default view type.
◆ SetDefaultViewType()
virtual void vtkPVGeneralSettings::SetDefaultViewType ( std::string  )
◆ GetInterfaceLanguage()
virtual std::string vtkPVGeneralSettings::GetInterfaceLanguage ( )
Default is en
◆ SetInterfaceLanguage()
virtual void vtkPVGeneralSettings::SetInterfaceLanguage ( std::string  )
Default is en
◆ SetScalarBarMode()
virtual void vtkPVGeneralSettings::SetScalarBarMode ( int  )
◆ GetScalarBarMode()
virtual int vtkPVGeneralSettings::GetScalarBarMode ( )
◆ SetCacheGeometryForAnimation()
virtual void vtkPVGeneralSettings::SetCacheGeometryForAnimation ( bool  )
◆ GetCacheGeometryForAnimation()
virtual bool vtkPVGeneralSettings::GetCacheGeometryForAnimation ( )
◆ CacheGeometryForAnimationOn()
virtual void vtkPVGeneralSettings::CacheGeometryForAnimationOn ( )
◆ CacheGeometryForAnimationOff()
virtual void vtkPVGeneralSettings::CacheGeometryForAnimationOff ( )
◆ SetAnimationGeometryCacheLimit()
virtual void vtkPVGeneralSettings::SetAnimationGeometryCacheLimit ( unsigned  long)
◆ GetAnimationGeometryCacheLimit()
virtual unsigned long vtkPVGeneralSettings::GetAnimationGeometryCacheLimit ( )
◆ SetAnimationTimeNotation()
virtual void vtkPVGeneralSettings::SetAnimationTimeNotation ( int  )
Accepted values are MIXED, SCIENTIFIC, and FIXED.
◆ GetAnimationTimeNotation()
virtual int vtkPVGeneralSettings::GetAnimationTimeNotation ( )
◆ SetAnimationTimeShortestAccuratePrecision()
virtual void vtkPVGeneralSettings::SetAnimationTimeShortestAccuratePrecision ( bool  )
◆ GetAnimationTimeShortestAccuratePrecision()
virtual bool vtkPVGeneralSettings::GetAnimationTimeShortestAccuratePrecision ( )
◆ SetAnimationTimePrecision()
virtual void vtkPVGeneralSettings::SetAnimationTimePrecision ( int  )
◆ GetAnimationTimePrecision()
virtual int vtkPVGeneralSettings::GetAnimationTimePrecision ( )
◆ SetShowAnimationShortcuts()
virtual void vtkPVGeneralSettings::SetShowAnimationShortcuts ( bool  )
◆ GetShowAnimationShortcuts()
virtual bool vtkPVGeneralSettings::GetShowAnimationShortcuts ( )
◆ ShowAnimationShortcutsOn()
virtual void vtkPVGeneralSettings::ShowAnimationShortcutsOn ( )
◆ ShowAnimationShortcutsOff()
virtual void vtkPVGeneralSettings::ShowAnimationShortcutsOff ( )
◆ SetResetDisplayEmptyViews()
virtual void vtkPVGeneralSettings::SetResetDisplayEmptyViews ( bool  )
◆ GetResetDisplayEmptyViews()
virtual bool vtkPVGeneralSettings::GetResetDisplayEmptyViews ( )
◆ ResetDisplayEmptyViewsOn()
virtual void vtkPVGeneralSettings::ResetDisplayEmptyViewsOn ( )
◆ ResetDisplayEmptyViewsOff()
virtual void vtkPVGeneralSettings::ResetDisplayEmptyViewsOff ( )
◆ SetRealNumberDisplayedNotation()
virtual void vtkPVGeneralSettings::SetRealNumberDisplayedNotation ( int  )
◆ GetRealNumberDisplayedNotation()
virtual int vtkPVGeneralSettings::GetRealNumberDisplayedNotation ( )
◆ SetRealNumberDisplayedShortestAccuratePrecision()
virtual void vtkPVGeneralSettings::SetRealNumberDisplayedShortestAccuratePrecision ( bool  )
◆ GetRealNumberDisplayedShortestAccuratePrecision()
virtual bool vtkPVGeneralSettings::GetRealNumberDisplayedShortestAccuratePrecision ( )
◆ SetRealNumberDisplayedPrecision()
virtual void vtkPVGeneralSettings::SetRealNumberDisplayedPrecision ( int  )
◆ GetRealNumberDisplayedPrecision()
virtual int vtkPVGeneralSettings::GetRealNumberDisplayedPrecision ( )
◆ SetFullNotationLowExponent()
virtual void vtkPVGeneralSettings::SetFullNotationLowExponent ( int  )
◆ GetFullNotationLowExponent()
virtual int vtkPVGeneralSettings::GetFullNotationLowExponent ( )
◆ SetFullNotationHighExponent()
virtual void vtkPVGeneralSettings::SetFullNotationHighExponent ( int  )
◆ GetFullNotationHighExponent()
virtual int vtkPVGeneralSettings::GetFullNotationHighExponent ( )
◆ SetInheritRepresentationProperties()
virtual void vtkPVGeneralSettings::SetInheritRepresentationProperties ( bool  )
◆ GetInheritRepresentationProperties()
virtual bool vtkPVGeneralSettings::GetInheritRepresentationProperties ( )
◆ InheritRepresentationPropertiesOn()
virtual void vtkPVGeneralSettings::InheritRepresentationPropertiesOn ( )
◆ InheritRepresentationPropertiesOff()
virtual void vtkPVGeneralSettings::InheritRepresentationPropertiesOff ( )
◆ SetIgnoreNegativeLogAxisWarning()
virtual void vtkPVGeneralSettings::SetIgnoreNegativeLogAxisWarning ( bool  )
◆ GetIgnoreNegativeLogAxisWarning()
virtual bool vtkPVGeneralSettings::GetIgnoreNegativeLogAxisWarning ( )
◆ IgnoreNegativeLogAxisWarningOn()
virtual void vtkPVGeneralSettings::IgnoreNegativeLogAxisWarningOn ( )
◆ IgnoreNegativeLogAxisWarningOff()
virtual void vtkPVGeneralSettings::IgnoreNegativeLogAxisWarningOff ( )
◆ SetPropertiesPanelMode()
virtual void vtkPVGeneralSettings::SetPropertiesPanelMode ( int  )
◆ GetPropertiesPanelMode()
virtual int vtkPVGeneralSettings::GetPropertiesPanelMode ( )
◆ SetLockPanels()
virtual void vtkPVGeneralSettings::SetLockPanels ( bool  )
◆ GetLockPanels()
virtual bool vtkPVGeneralSettings::GetLockPanels ( )
◆ SetLoadAllVariables()
virtual void vtkPVGeneralSettings::SetLoadAllVariables ( bool  )
◆ GetLoadAllVariables()
virtual bool vtkPVGeneralSettings::GetLoadAllVariables ( )
◆ LoadAllVariablesOn()
virtual void vtkPVGeneralSettings::LoadAllVariablesOn ( )
◆ LoadAllVariablesOff()
virtual void vtkPVGeneralSettings::LoadAllVariablesOff ( )
◆ SetLoadNoChartVariables()
virtual void vtkPVGeneralSettings::SetLoadNoChartVariables ( bool  )
◆ GetLoadNoChartVariables()
virtual bool vtkPVGeneralSettings::GetLoadNoChartVariables ( )
◆ LoadNoChartVariablesOn()
virtual void vtkPVGeneralSettings::LoadNoChartVariablesOn ( )
◆ LoadNoChartVariablesOff()
virtual void vtkPVGeneralSettings::LoadNoChartVariablesOff ( )
◆ SetGUIFontSize()
virtual void vtkPVGeneralSettings::SetGUIFontSize ( int  )
This is used only if GUIOverrideFont is true.
◆ GetGUIFontSize()
virtual int vtkPVGeneralSettings::GetGUIFontSize ( )
◆ SetGUIOverrideFont()
virtual void vtkPVGeneralSettings::SetGUIOverrideFont ( bool  )
◆ GetGUIOverrideFont()
virtual bool vtkPVGeneralSettings::GetGUIOverrideFont ( )
◆ SetColorByBlockColorsOnApply()
virtual void vtkPVGeneralSettings::SetColorByBlockColorsOnApply ( bool  )
◆ GetColorByBlockColorsOnApply()
virtual bool vtkPVGeneralSettings::GetColorByBlockColorsOnApply ( )
◆ SetEnableStreaming()
virtual void vtkPVGeneralSettings::SetEnableStreaming ( bool  )
◆ GetEnableStreaming()
virtual bool vtkPVGeneralSettings::GetEnableStreaming ( )
◆ EnableStreamingOn()
virtual void vtkPVGeneralSettings::EnableStreamingOn ( )
◆ EnableStreamingOff()
virtual void vtkPVGeneralSettings::EnableStreamingOff ( )
◆ SetUseAcceleratedFilters()
void vtkPVGeneralSettings::SetUseAcceleratedFilters ( bool  )
◆ GetUseAcceleratedFilters()
bool vtkPVGeneralSettings::GetUseAcceleratedFilters ( )
◆ UseAcceleratedFiltersOn()
virtual void vtkPVGeneralSettings::UseAcceleratedFiltersOn ( )
◆ UseAcceleratedFiltersOff()
virtual void vtkPVGeneralSettings::UseAcceleratedFiltersOff ( )
◆ GetSelectOnClickMultiBlockInspector()
virtual bool vtkPVGeneralSettings::GetSelectOnClickMultiBlockInspector ( )
Default is true.
◆ SetSelectOnClickMultiBlockInspector()
virtual void vtkPVGeneralSettings::SetSelectOnClickMultiBlockInspector ( bool  )
Default is true.
◆ GetNumberOfCallbackThreads()
static int vtkPVGeneralSettings::GetNumberOfCallbackThreads ( )
◆ SetNumberOfCallbackThreads()
static void vtkPVGeneralSettings::SetNumberOfCallbackThreads ( int  )
◆ GetNumberOfSMPThreads()
static int vtkPVGeneralSettings::GetNumberOfSMPThreads ( )
◆ SetNumberOfSMPThreads()
static void vtkPVGeneralSettings::SetNumberOfSMPThreads ( int  )
