Public Types | Public Member Functions | Static Public Member Functions | Protected Types | Protected Member Functions | Protected Attributes | Friends | List of all members
vtkSpreadSheetView Class Reference
vtkSpreadSheetView is a vtkPVView subclass for a view used to show any data as a spreadsheet. More...
#include <vtkSpreadSheetView.h>
Inheritance diagram for vtkSpreadSheetView:
Collaboration diagram for vtkSpreadSheetView:
typedef vtkPVView Superclass
- Public Types inherited from vtkPVView
typedef vtkView Superclass
- Public Types inherited from vtkView
void StillRender () override
 Triggers a high-resolution render. More...
void InteractiveRender () override
 Triggers a interactive render. More...
void Update () override
 Overridden to identify and locate the active-representation. More...
virtual vtkIdType GetNumberOfColumns ()
 Get the number of columns. More...
virtual vtkIdType GetNumberOfRows ()
 Get the number of rows. More...
virtual const char * GetColumnName (vtkIdType index)
 Returns the name for the column. More...
vtkIdType GetColumnByName (const char *columnName)
 Returns the column index for a column given its name. More...
virtual bool GetColumnVisibility (vtkIdType index)
 Returns the visibility for the column at the given index. More...
virtual bool IsRowSelected (vtkIdType row)
 Returns true if the row is selected. More...
virtual bool IsAvailable (vtkIdType row)
 Returns true is the data for the particular row is locally available. More...
virtual bool IsDataValid (vtkIdType row, vtkIdType col)
 Returns true of the data at the given row and column is valid. More...
void SetColumnNameToSort (const char *)
 Get/Set the column name to sort by. More...
void SetColumnNameToSort ()
void SetInvertSortOrder (bool)
 Get/Set whether the sort order must be Max to Min rather than Min to Max. More...
void SetBlockSize (vtkIdType val)
 Set the block size. More...
virtual bool Export (vtkCSVExporter *exporter)
 Export the contents of this view using the exporter. More...
void ClearCache ()
 Allow user to clear the cache if he needs to. More...
vtkTableFetchBlockCallback (vtkIdType blockindex)
virtual void SetIdentifier (vtkTypeUInt32)
 A unique identifier for this vtkSpreadSheetView across all processes. More...
virtual vtkTypeUInt32 GetIdentifier ()
void SetShowExtractedSelection (bool)
 Get/Set if the view shows extracted selection only or the actual data. More...
virtual void ShowExtractedSelectionOn ()
virtual void ShowExtractedSelectionOff ()
virtual bool GetShowExtractedSelection ()
virtual void SetGenerateCellConnectivity (bool)
 Allow user to enable/disable cell connectivity generation. More...
virtual bool GetGenerateCellConnectivity ()
virtual void GenerateCellConnectivityOn ()
virtual void GenerateCellConnectivityOff ()
virtual void SetShowFieldData (bool)
 Allow user to enable/disable field data visibility. More...
virtual bool GetShowFieldData ()
virtual void ShowFieldDataOn ()
virtual void ShowFieldDataOff ()
virtual void SetFieldAssociation (int)
 Specify the field association for the data to be shown in the view. More...
void OrderColumnsByList (bool enable)
 Specify sorting method that we want to use, when it's enabled, columns will be sorted internally by a given array, this array will be cached in OrderedColumnList. More...
void InitializeOrderedColumnList ()
std::vector< std::stringGetOrderedColumnList ()
void SetOrderedColumnList (std::vector< std::string > list)
void ClearOrderedColumnList ()
void HideColumnByName (const char *columnName)
 This API enables the users to hide columns that should be shown. More...
bool IsColumnHiddenByName (const char *columnName)
void ClearHiddenColumnsByName ()
void HideColumnByLabel (const char *columnLabel)
bool IsColumnHiddenByLabel (const std::string &columnLabel)
void ClearHiddenColumnsByLabel ()
virtual bool IsColumnInternal (vtkIdType index)
 Returns true if the column is internal. More...
virtual bool IsColumnInternal (const char *columnName)
virtual std::string GetColumnLabel (vtkIdType index)
 Returns the user-friendly label to use for the column in the spreadsheet view. More...
virtual std::string GetColumnLabel (const char *columnName)
virtual vtkVariant GetValue (vtkIdType row, vtkIdType col)
 Returns the value at given location. More...
virtual vtkVariant GetValueByName (vtkIdType row, const char *columnName)
- Public Member Functions inherited from vtkPVView
virtual void SetPPI (int)
 Description: Set the screen PPI. More...
virtual int GetPPI ()
virtual bool GetViewTimeValid ()
 Get ViewTimeValid. More...
bool InTileDisplayMode ()
 Returns true if the application is currently in tile display mode. More...
bool InCaveDisplayMode ()
 Returns true if the application is currently in cave/immersive display mode. More...
bool GetLocalProcessSupportsInteraction ()
 Returns true if the local process can support interaction. More...
vtkRenderWindowGetRenderWindow ()
 If this view needs a render window (not all views may use one), this method can be used to get the render window associated with this view on the current process. More...
virtual void ScaleRendererViewports (const double viewport[4])
 vtkViewLayout calls this method to update the total viewport available for this view. More...
vtkMTimeType GetUpdateTimeStamp ()
 Provides access to the time when Update() was last called. More...
virtual void Deliver (int use_lod, unsigned int size, unsigned int *representation_ids)
 Called on all processes to request data-delivery for the list of representations. More...
virtual bool IsCached (vtkPVDataRepresentation *)
 Called in vtkPVDataRepresentation::ProcessViewRequest to check if the representation already has cached data. More...
virtual void ClearCache (vtkPVDataRepresentation *)
 Called by vtkPVDataRepresentation whenever vtkPVDataRepresentation::MarkModified is called. More...
virtual void SetPosition (int, int)
 Set the position on this view in the multiview configuration. More...
virtual intGetPosition ()
virtual void GetPosition (int &, int &)
virtual void GetPosition (int [2])
virtual void SetSize (int, int)
 Set the size of this view in the multiview configuration. More...
virtual intGetSize ()
virtual void GetSize (int &, int &)
virtual void GetSize (int [2])
virtual void SetViewTime (double value)
 Get/Set the time this view is showing. More...
virtual double GetViewTime ()
virtual void SetCacheKey (double)
 Get/Set the cache key. More...
virtual double GetCacheKey ()
virtual void SetUseCache (bool)
 Get/Set whether caching is enabled. More...
virtual bool GetUseCache ()
virtual void PrepareForScreenshot ()
 These methods are used to setup the view for capturing screen shots. More...
virtual void CleanupAfterScreenshot ()
void SetTileScale (int x, int y)
 When saving screenshots with tiling, these methods get called. More...
void SetTileViewport (double x0, double y0, double x1, double y1)
const std::stringGetLogName () const
void SetDeliveryManager (vtkPVDataDeliveryManager *)
 Provides access to data delivery & cache manager for this view. More...
virtual vtkPVDataDeliveryManagerGetDeliveryManager ()
- Public Member Functions inherited from vtkView
vtkViewNewInstance () const
void AddRepresentation (vtkDataRepresentation *rep)
void SetRepresentation (vtkDataRepresentation *rep)
vtkDataRepresentationAddRepresentationFromInputConnection (vtkAlgorithmOutput *conn)
vtkDataRepresentationSetRepresentationFromInputConnection (vtkAlgorithmOutput *conn)
vtkDataRepresentationAddRepresentationFromInput (vtkDataObject *input)
vtkDataRepresentationSetRepresentationFromInput (vtkDataObject *input)
void RemoveRepresentation (vtkDataRepresentation *rep)
void RemoveRepresentation (vtkAlgorithmOutput *rep)
void RemoveAllRepresentations ()
int GetNumberOfRepresentations ()
vtkDataRepresentationGetRepresentation (int index=0)
bool IsRepresentationPresent (vtkDataRepresentation *rep)
vtkCommandGetObserver ()
void RegisterProgress (vtkObject *algorithm, const char *message=NULL)
void UnRegisterProgress (vtkObject *algorithm)
static vtkSpreadSheetViewNew ()
static vtkSpreadSheetViewSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPVView
static vtkPVViewSafeDownCast (vtkObject *o)
static void SetEnableStreaming (bool)
static bool GetEnableStreaming ()
static vtkInformationObjectBaseKeyVIEW ()
 Key used to pass the vtkPVView pointer to the representation during any of the view passes such as REQUEST_UPDATE(), REQUEST_UPDATE_LOD(), REQUEST_RENDER(), etc. More...
static vtkInformationRequestKeyREQUEST_UPDATE ()
 This is a Update-Data pass. More...
static vtkInformationRequestKeyREQUEST_UPDATE_LOD ()
 This is a Update-LOD-Data pass. More...
static vtkInformationRequestKeyREQUEST_RENDER ()
 This is a render pass. More...
static void SetPiece (vtkInformation *info, vtkPVDataRepresentation *repr, vtkDataObject *data, unsigned long trueSize=0, int port=0)
static vtkDataObjectGetPiece (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static vtkDataObjectGetDeliveredPiece (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static void SetPieceLOD (vtkInformation *info, vtkPVDataRepresentation *repr, vtkDataObject *data, unsigned long trueSize=0, int port=0)
static vtkDataObjectGetPieceLOD (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static vtkDataObjectGetDeliveredPieceLOD (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static void SetUseGenericOpenGLRenderWindow (bool val)
 Use this to indicate that the process should use vtkGenericOpenGLRenderWindow rather than vtkRenderWindow when creating an new render window. More...
static bool GetUseGenericOpenGLRenderWindow ()
- Static Public Member Functions inherited from vtkView
static vtkViewNew ()
static vtkViewSafeDownCast (vtkObjectBase *o)
static vtkObjectNew ()
static vtkObjectBaseNew ()
Protected Types
enum  { FETCH_BLOCK_TAG = 394732 }
 vtkSpreadSheetView ()
 ~vtkSpreadSheetView () override
int StreamToClient ()
 On render streams all the data from the processes to the client. More...
void OnRepresentationUpdated ()
virtual vtkTableFetchBlock (vtkIdType blockindex)
- Protected Member Functions inherited from vtkPVView
 vtkPVView (bool create_render_window=true)
 ~vtkPVView () override
vtkRenderWindowNewRenderWindow ()
 Subclasses should use this method to create new render windows instead of directly creating a new one. More...
void SetRenderWindow (vtkRenderWindow *)
 Subclasses can use this method to set the render window created for this view. More...
void AllReduce (const vtkBoundingBox &source, vtkBoundingBox &dest)
 Reduce bounding box between all participating processes. More...
void AllReduce (vtkTypeUInt64 source, vtkTypeUInt64 &dest, int operation, bool skip_data_server=false)
 Reduce between all participating processes using the operation (vtkCommunicator::StandardOperations) specified. More...
vtkPVSessionGetSession ()
virtual bool GetInCaptureScreenshot ()
 Flag set to true between calls to PrepareForScreenshot and CleanupAfterScreenshot. More...
void SynchronizeRepresentationTemporalPipelineStates ()
 Called in Update() to sync HasTemporalPipeline flags between representations on all processes. More...
void AddRepresentationInternal (vtkDataRepresentation *rep) override
 Overridden to assign IDs to each representation. More...
void RemoveRepresentationInternal (vtkDataRepresentation *rep) override
int CallProcessViewRequest (vtkInformationRequestKey *passType, vtkInformation *request, vtkInformationVector *reply)
 Subclasses can use this method to trigger a pass on all representations. More...
- Protected Member Functions inherited from vtkView
 vtkView ()
 ~vtkView ()
virtual vtkDataRepresentationCreateDefaultRepresentation (vtkAlgorithmOutput *conn)
virtual void AddRepresentationInternal (vtkDataRepresentation *vtkNotUsed(rep))
virtual void RemoveRepresentationInternal (vtkDataRepresentation *vtkNotUsed(rep))
virtual void SetReuseSingleRepresentation (bool)
virtual bool GetReuseSingleRepresentation ()
virtual void ReuseSingleRepresentationOn ()
virtual void ReuseSingleRepresentationOff ()
bool ShowExtractedSelection = false
bool GenerateCellConnectivity = false
bool ShowFieldData = false
vtkSortedTableStreamerTableStreamer
vtkMarkSelectedRowsTableSelectionMarker
vtkReductionFilterReductionFilter
vtkClientServerMoveDataDeliveryFilter
vtkIdType NumberOfRows
unsigned long CRMICallbackTag
unsigned long PRMICallbackTag
vtkTypeUInt32 Identifier
- Protected Attributes inherited from vtkPVView
bool InProcessViewRequest = false
 Guards against reentrant calls to CallProcessViewRequest(). More...
double ViewTime
double CacheKey
bool UseCache
int Size [2]
int Position [2]
int PPI
vtkTimeStamp UpdateTimeStamp
 Keeps track of the time when vtkPVRenderView::Update() was called. More...
vtkInformationRequestInformation
 These are passed as arguments to vtkDataRepresentation::ProcessViewRequest(). More...
vtkInformationVectorReplyInformationVector
- Protected Attributes inherited from vtkView
bool ReuseSingleRepresentation
Friends
class vtkInternals
- Static Protected Member Functions inherited from vtkPVView
static vtkPVDataDeliveryManagerGetDeliveryManager (vtkInformation *info)
This view can only show one representation at a time. If more than one representation is added to this view, only the first visible representation will be shown.
Definition at line 28 of file vtkSpreadSheetView.h.
Definition at line 32 of file vtkSpreadSheetView.h.
◆ anonymous enum
anonymous enum
Enumerator
FETCH_BLOCK_TAG
Definition at line 273 of file vtkSpreadSheetView.h.
◆ vtkSpreadSheetView()
vtkSpreadSheetView::vtkSpreadSheetView ( )
◆ ~vtkSpreadSheetView()
vtkSpreadSheetView::~vtkSpreadSheetView ( )
static vtkSpreadSheetView* vtkSpreadSheetView::New ( )
virtual const char* vtkSpreadSheetView::GetClassName ( )
Reimplemented from vtkPVView.
static int vtkSpreadSheetView::IsTypeOf ( const char *  type)
virtual int vtkSpreadSheetView::IsA ( const char *  type)
static vtkSpreadSheetView* vtkSpreadSheetView::SafeDownCast ( vtkObject o)
void vtkSpreadSheetView::PrintSelf ( ostream &  os,
◆ SetIdentifier()
virtual void vtkSpreadSheetView::SetIdentifier ( vtkTypeUInt32  )
◆ GetIdentifier()
virtual vtkTypeUInt32 vtkSpreadSheetView::GetIdentifier ( )
◆ StillRender()
void vtkSpreadSheetView::StillRender ( )
inlineoverridevirtual
Note
CallOnAllProcesses
Implements vtkPVView.
Definition at line 48 of file vtkSpreadSheetView.h.
◆ InteractiveRender()
void vtkSpreadSheetView::InteractiveRender ( )
Based on the settings on the view, this may result in a low-resolution rendering or a simplified geometry rendering.
Note
CallOnAllProcesses
Definition at line 55 of file vtkSpreadSheetView.h.
◆ Update()
void vtkSpreadSheetView::Update ( )
◆ SetShowExtractedSelection()
void vtkSpreadSheetView::SetShowExtractedSelection ( bool  )
false by default.
Note
CallOnAllProcesses
◆ ShowExtractedSelectionOn()
virtual void vtkSpreadSheetView::ShowExtractedSelectionOn ( )
false by default.
Note
CallOnAllProcesses
◆ ShowExtractedSelectionOff()
virtual void vtkSpreadSheetView::ShowExtractedSelectionOff ( )
false by default.
Note
CallOnAllProcesses
◆ GetShowExtractedSelection()
virtual bool vtkSpreadSheetView::GetShowExtractedSelection ( )
false by default.
Note
CallOnAllProcesses
◆ SetGenerateCellConnectivity()
virtual void vtkSpreadSheetView::SetGenerateCellConnectivity ( bool  )
◆ GetGenerateCellConnectivity()
virtual bool vtkSpreadSheetView::GetGenerateCellConnectivity ( )
◆ GenerateCellConnectivityOn()
virtual void vtkSpreadSheetView::GenerateCellConnectivityOn ( )
◆ GenerateCellConnectivityOff()
virtual void vtkSpreadSheetView::GenerateCellConnectivityOff ( )
◆ SetShowFieldData()
virtual void vtkSpreadSheetView::SetShowFieldData ( bool  )
Default to false.
◆ GetShowFieldData()
virtual bool vtkSpreadSheetView::GetShowFieldData ( )
Default to false.
◆ ShowFieldDataOn()
virtual void vtkSpreadSheetView::ShowFieldDataOn ( )
Default to false.
◆ ShowFieldDataOff()
virtual void vtkSpreadSheetView::ShowFieldDataOff ( )
Default to false.
◆ SetFieldAssociation()
virtual void vtkSpreadSheetView::SetFieldAssociation ( int  )
This is passed on to the vtkSpreadSheetRepresentation in Update pass.
◆ GetFieldAssociation()
virtual int vtkSpreadSheetView::GetFieldAssociation ( )
◆ OrderColumnsByList()
void vtkSpreadSheetView::OrderColumnsByList ( bool  enable)
Default of OrderedColumnList will be the list of each visible columns visible in the current SpreadSheetView.
Default is false.
◆ InitializeOrderedColumnList()
void vtkSpreadSheetView::InitializeOrderedColumnList ( )
Default is false.
◆ GetOrderedColumnList()
std::vector<std::string> vtkSpreadSheetView::GetOrderedColumnList ( )
Default is false.
◆ SetOrderedColumnList()
void vtkSpreadSheetView::SetOrderedColumnList ( std::vector< std::string list)
Default is false.
◆ ClearOrderedColumnList()
void vtkSpreadSheetView::ClearOrderedColumnList ( )
Default is false.
◆ HideColumnByName()
void vtkSpreadSheetView::HideColumnByName ( const char *  columnName)
Columns can be hidden using their names or labels.
◆ IsColumnHiddenByName()
bool vtkSpreadSheetView::IsColumnHiddenByName ( const char *  columnName)
◆ ClearHiddenColumnsByName()
void vtkSpreadSheetView::ClearHiddenColumnsByName ( )
◆ HideColumnByLabel()
void vtkSpreadSheetView::HideColumnByLabel ( const char *  columnLabel)
◆ IsColumnHiddenByLabel()
bool vtkSpreadSheetView::IsColumnHiddenByLabel ( const std::string columnLabel)
◆ ClearHiddenColumnsByLabel()
void vtkSpreadSheetView::ClearHiddenColumnsByLabel ( )
◆ GetNumberOfColumns()
virtual vtkIdType vtkSpreadSheetView::GetNumberOfColumns ( )
Note
CallOnClient
◆ GetNumberOfRows()
virtual vtkIdType vtkSpreadSheetView::GetNumberOfRows ( )
Note
CallOnClient
◆ GetColumnName()
virtual const char* vtkSpreadSheetView::GetColumnName ( vtkIdType  index)
Note
CallOnClient
◆ IsColumnInternal() [1/2]
virtual bool vtkSpreadSheetView::IsColumnInternal ( vtkIdType  index)
◆ IsColumnInternal() [2/2]
virtual bool vtkSpreadSheetView::IsColumnInternal ( const char *  columnName)
◆ GetColumnLabel() [1/2]
virtual std::string vtkSpreadSheetView::GetColumnLabel ( vtkIdType  index)
If this->IsColumnInternal(..) is true for the chosen column. Then this method will return nullptr.
Note
CallOnClient
◆ GetColumnLabel() [2/2]
virtual std::string vtkSpreadSheetView::GetColumnLabel ( const char *  columnName)
Note
CallOnClient
◆ GetColumnByName()
vtkIdType vtkSpreadSheetView::GetColumnByName ( const char *  columnName)
May return -1 is name is not valid or present.
◆ GetColumnVisibility()
virtual bool vtkSpreadSheetView::GetColumnVisibility ( vtkIdType  index)
◆ GetValue()
virtual vtkVariant vtkSpreadSheetView::GetValue ( vtkIdType  row,
vtkIdType  col
This may result in collective operations is data is not available locally. This method can only be called on the CLIENT process for now.
Note
CallOnClient
◆ GetValueByName()
virtual vtkVariant vtkSpreadSheetView::GetValueByName ( vtkIdType  row,
Note
CallOnClient
◆ IsRowSelected()
virtual bool vtkSpreadSheetView::IsRowSelected ( vtkIdType  row)
◆ IsAvailable()
virtual bool vtkSpreadSheetView::IsAvailable ( vtkIdType  row)
◆ IsDataValid()
virtual bool vtkSpreadSheetView::IsDataValid ( vtkIdType  row,
vtkIdType  col
◆ SetColumnNameToSort() [1/2]
void vtkSpreadSheetView::SetColumnNameToSort ( const char *  )
Note
CallOnAllProcesses
◆ SetColumnNameToSort() [2/2]
void vtkSpreadSheetView::SetColumnNameToSort ( )
inline
Definition at line 216 of file vtkSpreadSheetView.h.
◆ SetInvertSortOrder()
void vtkSpreadSheetView::SetInvertSortOrder ( bool  )
Note
CallOnAllProcesses
◆ SetBlockSize()
void vtkSpreadSheetView::SetBlockSize ( vtkIdType  val)
Set the block size.
Note
CallOnAllProcesses
◆ Export()
virtual bool vtkSpreadSheetView::Export ( vtkCSVExporter exporter)
◆ ClearCache()
void vtkSpreadSheetView::ClearCache ( )
◆ FetchBlockCallback()
vtkTable* vtkSpreadSheetView::FetchBlockCallback ( vtkIdType  blockindex)
◆ StreamToClient()
int vtkSpreadSheetView::StreamToClient ( )
Returns 0 on failure. Note: Was removed from update because you can't call update() while in an update
◆ OnRepresentationUpdated()
void vtkSpreadSheetView::OnRepresentationUpdated ( )
◆ FetchBlock()
virtual vtkTable* vtkSpreadSheetView::FetchBlock ( vtkIdType  blockindex)
protectedvirtual
◆ vtkInternals
friend class vtkInternals
friend
Definition at line 282 of file vtkSpreadSheetView.h.
bool vtkSpreadSheetView::ShowExtractedSelection = false
Definition at line 260 of file vtkSpreadSheetView.h.
bool vtkSpreadSheetView::GenerateCellConnectivity = false
Definition at line 261 of file vtkSpreadSheetView.h.
◆ ShowFieldData
bool vtkSpreadSheetView::ShowFieldData = false
Definition at line 262 of file vtkSpreadSheetView.h.
◆ TableStreamer
vtkSortedTableStreamer* vtkSpreadSheetView::TableStreamer
Definition at line 263 of file vtkSpreadSheetView.h.
◆ TableSelectionMarker
vtkMarkSelectedRows* vtkSpreadSheetView::TableSelectionMarker
Definition at line 264 of file vtkSpreadSheetView.h.
◆ ReductionFilter
vtkReductionFilter* vtkSpreadSheetView::ReductionFilter
Definition at line 265 of file vtkSpreadSheetView.h.
◆ DeliveryFilter
vtkClientServerMoveData* vtkSpreadSheetView::DeliveryFilter
Definition at line 266 of file vtkSpreadSheetView.h.
◆ NumberOfRows
vtkIdType vtkSpreadSheetView::NumberOfRows
Definition at line 267 of file vtkSpreadSheetView.h.
◆ CRMICallbackTag
unsigned long vtkSpreadSheetView::CRMICallbackTag
Definition at line 269 of file vtkSpreadSheetView.h.
◆ PRMICallbackTag
unsigned long vtkSpreadSheetView::PRMICallbackTag
Definition at line 270 of file vtkSpreadSheetView.h.
◆ Identifier
vtkTypeUInt32 vtkSpreadSheetView::Identifier
Definition at line 271 of file vtkSpreadSheetView.h.
