vtkSpreadSheetRepresentation Class Reference
Representation for showing data in a vtkSpreadSheetView. More...
#include <vtkSpreadSheetRepresentation.h>
Inheritance diagram for vtkSpreadSheetRepresentation:
Collaboration diagram for vtkSpreadSheetRepresentation:
enum  DesiredOutputPrecision
 Overridden to update state of GenerateCellConnectivity, ShowFieldData and FieldAssociation which is specified on the view. More...
void MarkModified () override
 Since this has no delivery, just mark ourselves modified. More...
vtkAlgorithmOutputGetDataProducer ()
vtkAlgorithmOutputGetExtractedDataProducer ()
vtkAlgorithmOutputGetSelectionProducer ()
void AddSelector (const char *selector)
 Selectors to extract blocks. More...
void ClearSelectors ()
void SetActiveAssemblyForSelectors (const char *name)
virtual void SetVisibility (bool val)
virtual bool GetVisibility ()
virtual vtkDataObjectGetRenderedDataObject (int vtkNotUsed(port))
double GetCacheKey () const
vtkAlgorithmOutputGetInternalOutputPort () override
vtkAlgorithmOutputGetInternalOutputPort (int port) override
vtkAlgorithmOutputGetInternalOutputPort (int port, int conn) override
vtkViewGetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
const std::stringGetLogName () const
vtkDataRepresentationNewInstance () const
virtual vtkSelectionConvertSelection (vtkView *view, vtkSelection *selection)
vtkAlgorithmOutputGetInputConnection (int port=0, int index=0)
vtkAnnotationLinkGetAnnotationLink ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
virtual vtkAlgorithmOutputGetInternalAnnotationOutputPort ()
virtual vtkAlgorithmOutputGetInternalAnnotationOutputPort (int port)
virtual vtkAlgorithmOutputGetInternalAnnotationOutputPort (int port, int conn)
virtual vtkAlgorithmOutputGetInternalSelectionOutputPort ()
virtual vtkAlgorithmOutputGetInternalSelectionOutputPort (int port)
virtual vtkAlgorithmOutputGetInternalSelectionOutputPort (int port, int conn)
virtual vtkStringArrayGetSelectionArrayNames ()
vtkPassInputTypeAlgorithmNewInstance () const
vtkPolyDataGetPolyDataOutput ()
vtkStructuredPointsGetStructuredPointsOutput ()
vtkImageDataGetImageDataOutput ()
vtkStructuredGridGetStructuredGridOutput ()
vtkUnstructuredGridGetUnstructuredGridOutput ()
vtkRectilinearGridGetRectilinearGridOutput ()
vtkTableGetTableOutput ()
vtkGraphGetGraphOutput ()
vtkDataObjectGetInput ()
vtkDataObjectGetOutput ()
vtkDataObjectGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkSpreadSheetRepresentationNew ()
static vtkSpreadSheetRepresentationSafeDownCast (vtkObject *o)
static vtkPVDataRepresentationSafeDownCast (vtkObject *o)
static vtkDataRepresentationNew ()
static vtkDataRepresentationSafeDownCast (vtkObjectBase *o)
static vtkPassInputTypeAlgorithmNew ()
static vtkPassInputTypeAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSpreadSheetRepresentation ()
 ~vtkSpreadSheetRepresentation () override
void SetGenerateCellConnectivity (bool)
 This is called in ProcessViewRequest during the vtkPVView::REQUEST_UPDATE pass. More...
void SetShowFieldData (bool)
void SetFieldAssociation (int val)
 vtkPVDataRepresentation ()
vtkExecutiveCreateDefaultExecutive () override
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
virtual vtkAnnotationLayersConvertAnnotations (vtkView *view, vtkAnnotationLayers *annotations)
vtkTrivialProducerGetInternalInput (int port, int conn)
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
vtkDataObjectGetInput (int port)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
bool ShowFieldData = false
vtkNew< vtkCleanArrays > CleanArrays
vtkNew< vtkDataTabulatorDataConditioner
vtkNew< vtkCleanArrays > ExtractedCleanArrays
vtkNew< vtkDataTabulatorExtractedDataConditioner
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
vtkStringArraySelectionArrayNames
CommandObserver
vtkAnnotationLinkAnnotationLinkInternal
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
Unlike typical ParaView representations, this one does not do any data movement, it merely updates the input and provides access to the input data objects (rather clones of those). This filer has 3 input ports:
Definition at line 26 of file vtkSpreadSheetRepresentation.h.
Definition at line 30 of file vtkSpreadSheetRepresentation.h.
◆ vtkSpreadSheetRepresentation()
vtkSpreadSheetRepresentation::vtkSpreadSheetRepresentation ( )
◆ ~vtkSpreadSheetRepresentation()
vtkSpreadSheetRepresentation::~vtkSpreadSheetRepresentation ( )
static vtkSpreadSheetRepresentation* vtkSpreadSheetRepresentation::New ( )
virtual const char* vtkSpreadSheetRepresentation::GetClassName ( )
static int vtkSpreadSheetRepresentation::IsTypeOf ( const char *  type)
virtual int vtkSpreadSheetRepresentation::IsA ( const char *  type)
static vtkSpreadSheetRepresentation* vtkSpreadSheetRepresentation::SafeDownCast ( vtkObject o)
void vtkSpreadSheetRepresentation::PrintSelf ( ostream &  os,
◆ ProcessViewRequest()
int vtkSpreadSheetRepresentation::ProcessViewRequest ( vtkInformationRequestKey request_type,
vtkInformation inInfo,
vtkInformation outInfo
◆ MarkModified()
void vtkSpreadSheetRepresentation::MarkModified ( )
inlineoverridevirtual
Definition at line 43 of file vtkSpreadSheetRepresentation.h.
◆ GetDataProducer()
vtkAlgorithmOutput* vtkSpreadSheetRepresentation::GetDataProducer ( )
◆ GetExtractedDataProducer()
vtkAlgorithmOutput* vtkSpreadSheetRepresentation::GetExtractedDataProducer ( )
◆ GetSelectionProducer()
vtkAlgorithmOutput* vtkSpreadSheetRepresentation::GetSelectionProducer ( )
◆ AddSelector()
void vtkSpreadSheetRepresentation::AddSelector ( const char *  selector)
◆ ClearSelectors()
void vtkSpreadSheetRepresentation::ClearSelectors ( )
◆ SetActiveAssemblyForSelectors()
void vtkSpreadSheetRepresentation::SetActiveAssemblyForSelectors ( const char *  name)
◆ SetGenerateCellConnectivity()
void vtkSpreadSheetRepresentation::SetGenerateCellConnectivity ( bool  )
◆ SetShowFieldData()
void vtkSpreadSheetRepresentation::SetShowFieldData ( bool  )
◆ SetFieldAssociation()
void vtkSpreadSheetRepresentation::SetFieldAssociation ( int  val)
◆ FillInputPortInformation()
int vtkSpreadSheetRepresentation::FillInputPortInformation ( int  port,
vtkInformation info
overrideprotectedvirtual
Fill input port information.
◆ RequestData()
int vtkSpreadSheetRepresentation::RequestData ( vtkInformation ,
vtkInformationVector **  ,
Overridden to invoke vtkCommand::UpdateDataEvent.
◆ ShowFieldData
bool vtkSpreadSheetRepresentation::ShowFieldData = false
Definition at line 82 of file vtkSpreadSheetRepresentation.h.
◆ CleanArrays
vtkNew<vtkCleanArrays> vtkSpreadSheetRepresentation::CleanArrays
Definition at line 84 of file vtkSpreadSheetRepresentation.h.
◆ DataConditioner
vtkNew<vtkDataTabulator> vtkSpreadSheetRepresentation::DataConditioner
Definition at line 85 of file vtkSpreadSheetRepresentation.h.
◆ ExtractedCleanArrays
vtkNew<vtkCleanArrays> vtkSpreadSheetRepresentation::ExtractedCleanArrays
Definition at line 87 of file vtkSpreadSheetRepresentation.h.
◆ ExtractedDataConditioner
vtkNew<vtkDataTabulator> vtkSpreadSheetRepresentation::ExtractedDataConditioner
Definition at line 88 of file vtkSpreadSheetRepresentation.h.
