| virtual void | SetFieldAssociation (int) |
| | Select the field to process. More...
| virtual int | GetFieldAssociation () |
| vtkDataObjectAlgorithm * | NewInstance () const |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkMarkSelectedRows () |
| | ~vtkMarkSelectedRows () override |
| int | FillOutputPortInformation (int port, vtkInformation *info) override |
| | vtkDataObjectAlgorithm () |
| | ~vtkDataObjectAlgorithm () |
| virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
mark rows that are selected as such.
vtkMarkSelectedRows is an internal filter used by vtkSpreadSheetView. It takes two inputs, both of which are generated by vtkDataTabulator. At index 0, we get the raw tabular data, while at input index 1 is the tabular data corresponding to the extracted selection corresponding to the data on input 0. This filter generates an output which is same as the input expect with a new array named "__vtkIsSelected__" which is set to 1 for all rows that are present in the extracted selection input as well. "__vtkIsSelected__" may not be added at all if the extracted selection input is missing or empty.
This only works with vtkPartitionedDataSet inputs.
- See also
- vtkDataTabulator
Definition at line 29 of file vtkMarkSelectedRows.h.
