| void | AddSelector (const char *selector) |
| void | ClearSelectors () |
| virtual void | SetActiveAssemblyForSelectors (const char *) |
| | Get/Set the name of the assembly you use together with the selectors to subset. More...
| virtual char * | GetActiveAssemblyForSelectors () |
| virtual void | SetGenerateCellConnectivity (bool) |
| | Allow user to enable/disable cell connectivity generation in the datamodel. More...
| virtual bool | GetGenerateCellConnectivity () |
| virtual void | SetFieldAssociation (int) |
| | Select the attribute type. More...
| virtual int | GetFieldAssociation () |
| virtual void | SetSplitComponents (int) |
| | Flatten the table, i.e. More...
| virtual int | GetSplitComponents () |
| virtual void | SetSplitComponentsNamingMode (int) |
| | Corresponds to vtkSplitColumnComponents::NamingMode. More...
| virtual int | GetSplitComponentsNamingMode () |
| virtual void | SetGenerateOriginalIds (bool) |
| | When set (default) the vtkOriginalIndices array will be added to the output. More...
| virtual bool | GetGenerateOriginalIds () |
| vtkDataObjectAlgorithm * | NewInstance () const |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkDataTabulator () |
| | ~vtkDataTabulator () override |
| int | FillOutputPortInformation (int port, vtkInformation *info) override |
| vtkSmartPointer< vtkDataObject > | Transform (vtkDataObject *data) |
| | vtkDataObjectAlgorithm () |
| | ~vtkDataObjectAlgorithm () |
| virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
converts input data to a table (or composite-data of tables)
vtkDataTabulator is intended for use by representations that primarily work with tabular data. It converts input data to table. This is done by selecting which type of data is to be extracted e.g. cell data, point data, field data etc. The filter also supports adding meta-data to the output to encode information in the input that'd potentially be lost by this conversion.
Definition at line 28 of file vtkDataTabulator.h.
