| int | GetNumberOfAttributeArrays () |
| | Return the number of columns available for the current value of AttributeMode. More...
| const char * | GetAttributeArrayName (int n) |
| | Get the name of the n-th array ffor the current value of AttributeMode. More...
| int | GetAttributeArrayStatus (const char *arrName) |
| | Get the status of the specified array (i.e., whether or not it is a column of interest). More...
| vtkInformationIntegerKey * | MULTIPLE_MODELS () |
| | A key used to mark the output model data object (output port 0) when it is a partitioned dataset collection holding multiple models as opposed to a partitationed dataset collection containing a single model. More...
| virtual int | GetAttributeMode () |
| | Set/get the type of field attribute (cell, point, field) More...
| virtual void | SetAttributeMode (int) |
| void | EnableAttributeArray (const char *arrName) |
| | An alternate interface for preparing a selection of arrays in ParaView. More...
| void | ClearAttributeArrays () |
| virtual void | SetTrainingFraction (double) |
| | Set/get the amount of data to be used for training. More...
| virtual double | GetTrainingFraction () |
| virtual void | SetController (vtkMultiProcessController *) |
| | Get/Set the multiprocess controller. More...
| virtual vtkMultiProcessController * | GetController () |
| virtual void | SetTask (int) |
| | Set/get whether this filter should create a model of the input or assess the input or both. More...
| virtual int | GetTask () |
| virtual void | SetGlobalModel (vtkTypeBool) |
| | Set/get whether to produce a single model for the entire input or (when given a partitioned dataset collection) to produce a model per partitioned dataset. More...
| virtual vtkTypeBool | GetGlobalModel () |
| virtual void | GlobalModelOn () |
| virtual void | GlobalModelOff () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkSciVizStatistics () |
| | ~vtkSciVizStatistics () override |
| virtual bool | PrepareInputArrays (vtkDataObject *inData, vtkGenerateStatistics *filter) |
| | Configure the vtkGenerateStatistics instance on each rank with identical model requests. More...
| virtual bool | PrepareAlgorithm (vtkGenerateStatistics *filter)=0 |
| | Subclasses must override this method and configure filter by calling filter->SetStatisticsAlgorithm(). More...
| int | FillOutputPortInformation (int port, vtkInformation *info) override |
| int | RequestData (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output) override |
| virtual int | RequestUpdateTime (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
Abstract base class for computing statistics with vtkStatistics.
This filter either computes a statistical model of a dataset or takes such a model as its second input. Then, the model (however it is obtained) may optionally be used to assess the input dataset.
This class serves as a base class that handles table conversion, interfacing with the array selection in the ParaView user interface, and provides a simplified interface to vtkStatisticsAlgorithm.
- Thanks to David Thompson and Philippe Pebay from Sandia National Laboratories for implementing this class. Updated by Philippe Pebay, Kitware SAS 2012
Definition at line 37 of file vtkSciVizStatistics.h.
