| virtual void | SetNormalizationScheme (int) |
| virtual int | GetNormalizationScheme () |
| virtual void | SetBasisScheme (int) |
| virtual int | GetBasisScheme () |
| virtual void | SetFixedBasisSize (int) |
| virtual int | GetFixedBasisSize () |
| virtual void | SetFixedBasisEnergy (double) |
| virtual double | GetFixedBasisEnergy () |
| virtual void | SetRobustPCA (bool) |
| virtual bool | GetRobustPCA () |
| virtual void | RobustPCAOn () |
| virtual void | RobustPCAOff () |
| int | GetNumberOfAttributeArrays () |
| | Return the number of columns available for the current value of AttributeMode. More...
| const char * | GetAttributeArrayName (int n) |
| | Get the name of the n-th array ffor the current value of AttributeMode. More...
| int | GetAttributeArrayStatus (const char *arrName) |
| | Get the status of the specified array (i.e., whether or not it is a column of interest). More...
| vtkInformationIntegerKey * | MULTIPLE_MODELS () |
| | A key used to mark the output model data object (output port 0) when it is a partitioned dataset collection holding multiple models as opposed to a partitationed dataset collection containing a single model. More...
| virtual int | GetAttributeMode () |
| | Set/get the type of field attribute (cell, point, field) More...
| virtual void | SetAttributeMode (int) |
| void | EnableAttributeArray (const char *arrName) |
| | An alternate interface for preparing a selection of arrays in ParaView. More...
| void | ClearAttributeArrays () |
| virtual void | SetTrainingFraction (double) |
| | Set/get the amount of data to be used for training. More...
| virtual double | GetTrainingFraction () |
| virtual void | SetController (vtkMultiProcessController *) |
| | Get/Set the multiprocess controller. More...
| virtual vtkMultiProcessController * | GetController () |
| virtual void | SetTask (int) |
| | Set/get whether this filter should create a model of the input or assess the input or both. More...
| virtual int | GetTask () |
| virtual void | SetGlobalModel (vtkTypeBool) |
| | Set/get whether to produce a single model for the entire input or (when given a partitioned dataset collection) to produce a model per partitioned dataset. More...
| virtual vtkTypeBool | GetGlobalModel () |
| virtual void | GlobalModelOn () |
| virtual void | GlobalModelOff () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPSciVizPCAStats () |
| | ~vtkPSciVizPCAStats () override |
| bool | PrepareAlgorithm (vtkGenerateStatistics *filter) override |
| | Subclasses must override this method and configure filter by calling filter->SetStatisticsAlgorithm(). More...
| | vtkSciVizStatistics () |
| | ~vtkSciVizStatistics () override |
| virtual bool | PrepareInputArrays (vtkDataObject *inData, vtkGenerateStatistics *filter) |
| | Configure the vtkGenerateStatistics instance on each rank with identical model requests. More...
| int | FillOutputPortInformation (int port, vtkInformation *info) override |
| int | RequestData (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output) override |
| virtual int | RequestUpdateTime (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
Perform PCA on data and/or project data into a subspace defined by the PCA.
This filter either computes a statistical model of a dataset or takes such a model as its second input. Then, the model (however it is obtained) may optionally be used to assess the input dataset.
This filter performs additional analysis above and beyond the vtkPSciVizMultiCorrelativeStats filter. It computes the eigenvalues and eigenvectors of the covariance matrix from the multicorrelative filter. Data is then assessed by projecting the original tuples into a possibly lower-dimensional space.
Since the PCA filter uses the multicorrelative filter's analysis, it shares the same raw covariance table specified in the multicorrelative documentation. The second table in the partitioned dataset collection comprising the model output is an expanded version of the multicorrelative version.
As with the multicorrlative filter, the second model table contains the mean values, the upper-triangular portion of the symmetric covariance matrix, and the non-zero lower-triangular portion of the Cholesky decomposition of the covariance matrix. Below these entries are the eigenvalues of the covariance matrix (in the column labeled "Mean") and the eigenvectors (as row vectors) in an additional NxN matrix.
Definition at line 40 of file vtkPSciVizPCAStats.h.
