Derive contingency tables and use them to assess the likelihood of associations.
| int | GetNumberOfAttributeArrays () |
| | Return the number of columns available for the current value of AttributeMode. More...
| const char * | GetAttributeArrayName (int n) |
| | Get the name of the n-th array ffor the current value of AttributeMode. More...
| int | GetAttributeArrayStatus (const char *arrName) |
| | Get the status of the specified array (i.e., whether or not it is a column of interest). More...
| vtkInformationIntegerKey * | MULTIPLE_MODELS () |
| | A key used to mark the output model data object (output port 0) when it is a partitioned dataset collection holding multiple models as opposed to a partitationed dataset collection containing a single model. More...
| virtual int | GetAttributeMode () |
| | Set/get the type of field attribute (cell, point, field) More...
| virtual void | SetAttributeMode (int) |
| void | EnableAttributeArray (const char *arrName) |
| | An alternate interface for preparing a selection of arrays in ParaView. More...
| void | ClearAttributeArrays () |
| virtual void | SetTrainingFraction (double) |
| | Set/get the amount of data to be used for training. More...
| virtual double | GetTrainingFraction () |
| virtual void | SetController (vtkMultiProcessController *) |
| | Get/Set the multiprocess controller. More...
| virtual vtkMultiProcessController * | GetController () |
| virtual void | SetTask (int) |
| | Set/get whether this filter should create a model of the input or assess the input or both. More...
| virtual int | GetTask () |
| virtual void | SetGlobalModel (vtkTypeBool) |
| | Set/get whether to produce a single model for the entire input or (when given a partitioned dataset collection) to produce a model per partitioned dataset. More...
| virtual vtkTypeBool | GetGlobalModel () |
| virtual void | GlobalModelOn () |
| virtual void | GlobalModelOff () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPSciVizContingencyStats () |
| | ~vtkPSciVizContingencyStats () override |
| bool | PrepareAlgorithm (vtkGenerateStatistics *filter) override |
| | Subclasses must override this method and configure filter by calling filter->SetStatisticsAlgorithm(). More...
| | vtkSciVizStatistics () |
| | ~vtkSciVizStatistics () override |
| virtual bool | PrepareInputArrays (vtkDataObject *inData, vtkGenerateStatistics *filter) |
| | Configure the vtkGenerateStatistics instance on each rank with identical model requests. More...
| int | FillOutputPortInformation (int port, vtkInformation *info) override |
| int | RequestData (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output) override |
| virtual int | RequestUpdateTime (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
This filter either computes a statistical model of a dataset or takes such a model as its second input. Then, the model (however it is obtained) may optionally be used to assess the input dataset.
This filter computes contingency tables between pairs of attributes. This result is a tabular bivariate probability distribution which serves as a Bayesian-style prior model. Data is assessed by computing
the probability of observing both variables simultaneously;
the probability of each variable conditioned on the other (the two values need not be identical); and
the pointwise mutual information (PMI).
Finally, the summary statistics include the information entropy of the observations.
Definition at line 32 of file vtkPSciVizContingencyStats.h.
