| void | CreateVTKObjects () override |
| virtual bool | GetNeedsUpdate () |
| | Returns if the underlying VTK object needs to be updated or not. More...
| bool | IsDeprecated () |
| | Returns true if the proxy has a deprecation tag. More...
| bool | GetIsSubProxy () |
| | Return the property names that have values different from the otherProxy argument. More...
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMRecolorableImageExtractWriterProxy () |
| | ~vtkSMRecolorableImageExtractWriterProxy () override |
| bool | WriteInternal (vtkSMExtractsController *extractor, const SummaryParametersT ¶ms=SummaryParametersT{}) override |
| | Called in Write(). More...
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| virtual void | ExecuteStream (const vtkClientServerStream &msg, bool ignore_errors=false, vtkTypeUInt32 location=0) |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | This is called by PostUpdateData to only update state for this proxy without iterative over producers. More...
| | If a proxy need to ensure a plugin is loaded, make sure it is. More...
| | Set the "EnsurePluginLoaded" XML element that is used in LoadPluginIfEnsured. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
extractor for recolorable images.
vtkSMRecolorableImageExtractWriterProxy is an extractors that saves out recolorable images instead of standard PNGs from views. Recolorable images are obtained from vtkPVRenderView by rendering and capturing the raw data array values instead of mapping them through a lookup table. The implementation uses vtkValuePass.
Currently, this is only supported in client-only (builtin) and parallel pvbatch (or insitu) modes. Any client-server configuration is not supported.
Definition at line 22 of file vtkSMRecolorableImageExtractWriterProxy.h.
