Utility class used for string formatting.
vtkPVStringFormatter is a utility class that defines the API for formatting strings using a stack of argument scopes. Scopes can be created by defining arguments using the fmt library. A string will always be formatted using the top argument scope in the scope stack.
Definition at line 33 of file vtkPVStringFormatter.h.
template<typename... Args>
| static void vtkPVStringFormatter::PushScope |
const char * |
scopeName, |
Args &&... |
args |
inlinestatic |
Pushes arguments using a scope name and arguments in the form of fmt::arg(name, arg) to add a new scope to the scope stack.
E.g. if PushScope("TEST", fmt::arg("test1", test)) is used then the scope the scope will have the following arguments: TEST_test1 and test1, The new scope has as a baseline the top scope of the scope stack.
- Note
- If you want to call this function, scope name MUST be const char*, otherwise the implementation of this function without the scope name will be invoked.
Definition at line 94 of file vtkPVStringFormatter.h.
