vtkSMAnimatedExporterProxy Class Reference
used to export the animated view More...
#include <vtkSMAnimatedExporterProxy.h>
Inheritance diagram for vtkSMAnimatedExporterProxy:
Collaboration diagram for vtkSMAnimatedExporterProxy:
typedef vtkSMExporterProxy Superclass
- Public Types inherited from vtkSMExporterProxy
typedef vtkSMProxy Superclass
void Write () override
 Exports the view. More...
void SetView (vtkSMViewProxy *view) override
 Set the view to export. More...
bool CanExport (vtkSMProxy *) override
 Returns true if the view can be exported. More...
- Public Member Functions inherited from vtkSMExporterProxy
virtual vtkSMViewProxyGetView ()
 Set the view proxy to export. More...
const std::vector< std::string > & GetFileExtensions () const
 Returns the suggested file extensions for this exporter. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
vtkSMProxyGetParentProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMAnimatedExporterProxyNew ()
static vtkSMAnimatedExporterProxySafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMExporterProxy
static vtkSMExporterProxySafeDownCast (vtkObject *o)
static vtkSMProxyNew ()
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMAnimatedExporterProxy ()=default
 ~vtkSMAnimatedExporterProxy () override=default
- Protected Member Functions inherited from vtkSMExporterProxy
 vtkSMExporterProxy ()
 ~vtkSMExporterProxy () override
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMExporterProxy
vtkSMViewProxyView
std::vector< std::stringFileExtensions
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElementXMLElement
vtkSMMessageState
int InMarkModified
vtkSMProxyInternalsInternals
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
It is intended to be associated to a vtkSMAnimationSceneWriter subclass.
In the particular case of vtkSMAnimationSceneSeriesWriter, it expects an "Exporter" SubProxy pointing to an ExporterProxy that will be used to export each animation scene timestep.
See also
Definition at line 22 of file vtkSMAnimatedExporterProxy.h.
Definition at line 26 of file vtkSMAnimatedExporterProxy.h.
◆ vtkSMAnimatedExporterProxy()
vtkSMAnimatedExporterProxy::vtkSMAnimatedExporterProxy ( )
protecteddefault
◆ ~vtkSMAnimatedExporterProxy()
vtkSMAnimatedExporterProxy::~vtkSMAnimatedExporterProxy ( )
overrideprotecteddefault
static vtkSMAnimatedExporterProxy* vtkSMAnimatedExporterProxy::New ( )
virtual const char* vtkSMAnimatedExporterProxy::GetClassName ( )
Reimplemented from vtkSMExporterProxy.
static int vtkSMAnimatedExporterProxy::IsTypeOf ( const char *  type)
virtual int vtkSMAnimatedExporterProxy::IsA ( const char *  type)
static vtkSMAnimatedExporterProxy* vtkSMAnimatedExporterProxy::SafeDownCast ( vtkObject o)
void vtkSMAnimatedExporterProxy::PrintSelf ( ostream &  os,
◆ Write()
void vtkSMAnimatedExporterProxy::Write ( )
Exports the view.
Implements vtkSMExporterProxy.
◆ SetView()
void vtkSMAnimatedExporterProxy::SetView ( vtkSMViewProxy view)
Reimplemented to forward it to the Exporter SubProxy.
◆ CanExport()
bool vtkSMAnimatedExporterProxy::CanExport ( vtkSMProxy )
