| virtual void | SetSingleFile (bool) |
| | When true, the delegate exporter is expected to support writing all animation frames into a single file as time samples: "Start" and "Finish" commands bracket the frame sequence and a "TimeValue" property is set before each frame, instead of generating a new filename per frame. More...
| virtual bool | GetSingleFile () |
| virtual void | SingleFileOn () |
| virtual void | SingleFileOff () |
| virtual void | SetAnimationScene (vtkSMProxy *) |
| | Convenience method to set the proxy. More...
| bool | Save () |
| | Begin the saving. More...
| virtual void | SetWriteTimeSteps (bool) |
| | Enable the writing of all timesteps. More...
| virtual bool | GetWriteTimeSteps () |
| virtual void | WriteTimeStepsOn () |
| virtual void | WriteTimeStepsOff () |
| void | SetFrameExporterDelegate (vtkSMExporterProxy *exporter) |
| | Set an exporter to use for single frame export. More...
| virtual void | SetAnimationScene (vtkSMAnimationScene *) |
| | Get/Set the animation scene that this writer will write. More...
| virtual vtkSMAnimationScene * | GetAnimationScene () |
| virtual void | SetFileName (const char *) |
| | Get/Set the filename. More...
| virtual char * | GetFileName () |
| virtual void | SetStartFileCount (int) |
| | Get/Set the start file count. More...
| virtual int | GetStartFileCount () |
| virtual void | SetPlaybackTimeWindow (double, double) |
| | Get/Set time window that we want to write If PlaybackTimeWindow[0] > PlaybackTimeWindow[1] that mean that we want to export the full time range available. More...
| void | SetPlaybackTimeWindow (double [2]) |
| virtual double * | GetPlaybackTimeWindow () |
| virtual void | GetPlaybackTimeWindow (double &, double &) |
| virtual void | GetPlaybackTimeWindow (double [2]) |
| void | SetFrameWindow (int window[2]) |
| | Use window to set PlaybackTimeWindow based on AnimationScene times. More...
| void | SetFrameWindow (int min, int max) |
| virtual void | SetStride (int) |
| | Set/Get The stride which is used to extract the next frame. More...
| virtual int | GetStride () |
helper class to write file series from animated scene
vtkSMAnimationSceneSeriesWriter is a concrete implementation of vtkSMAnimationSceneWriter that can write one file per animation time, using a provided exporter.
As an exporter, it is intended to write the data as displayed in the current view.
Definition at line 22 of file vtkSMAnimationSceneSeriesWriter.h.
