| void | CopyFromObject (vtkObject *object) override |
| | Transfer information about a single object into this object. More...
| virtual void | SetInspectCells (bool) |
| | Flag to ask for deeper cell inspection. More...
| void | Initialize () |
| | Initializes and clears all values updated in CopyFromObject. More...
| void | DeepCopy (vtkPVDataInformation *info) |
| | Simply copies from another vtkPVDataInformation. More...
| vtkPVArrayInformation * | GetArrayInformation (const char *arrayname, int attributeType) const |
| | Finds and returns array information associated with the chosen array. More...
| virtual int | GetDataSetType () |
| | Returns the data set type. More...
| virtual int | GetCompositeDataSetType () |
| | Returns the type flag for composite datasets. More...
| bool | IsCompositeDataSet () const |
| | Returns true if the data information corresponds to a composite dataset. More...
| bool | IsNull () const |
| | Returns true if the data information is empty or invalid. More...
| vtkTypeInt64 | GetNumberOfElements (int elementType) const |
| | Returns number of elements of the chosen type in the data. More...
| virtual vtkTypeInt64 | GetNumberOfAMRLevels () |
| | For vtkUniformGridAMR and subclasses, this returns the number of levels. More...
| vtkTypeInt64 | GetNumberOfAMRDataSets (vtkTypeInt64 level) const |
| | For vtkUniformGridAMR and subclasses, this returns the number of datasets at each level. More...
| virtual vtkTypeInt64 | GetNumberOfDataSets () |
| | This is count of non-null non-composite datasets. More...
| virtual vtkTypeInt64 | GetMemorySize () |
| | Returns the memory size as reported by vtkDataObject::GetActualMemorySize. More...
| virtual double * | GetBounds () |
| | Returns bounds for the dataset. More...
| virtual void | GetBounds (double &, double &, double &, double &, double &, double &) |
| virtual void | GetBounds (double [6]) |
| virtual vtkPVArrayInformation * | GetPointArrayInformation () |
| | For a vtkPointSet and subclasses, this provides information about the vtkPoints array. More...
| bool | IsDataStructured () const |
| | Returns true if the data is structured i.e. More...
| bool | HasStructuredData () const |
| | Returns true if the data has structured data. More...
| bool | HasUnstructuredData () const |
| | Returns true if the data has unstructured data. More...
| bool | IsAttributeValid (int attributeType) const |
| | Returns true if provided attributeType is valid for this dataset, false otherwise. More...
| virtual vtkTypeUInt64 | GetFirstLeafCompositeIndex () |
| | Until multiblock dataset is deprecated, applications often want to locate the composite-index for the first leaf node. More...
| std::string | GetBlockName (vtkTypeUInt64 cid) const |
| | Given a composite index, return the blockname, if any. More...
| std::vector< std::string > | GetBlockNames (const std::vector< std::string > &selectors, const char *assemblyName) const |
| | Given a collection of selectors, returns all block names for chosen blocks. More...
| unsigned int | ComputeCompositeIndexForAMR (unsigned int level, unsigned int index) const |
| | A helper method to convert an AMR level-index to a flat index. More...
| const std::vector< unsigned char > & | GetUniqueCellTypes () const |
| | Return a list of unique cell types (see vtkCellType.h). More...
| virtual void | SetPortNumber (int) |
| | Indicates which output port of an algorithm this data should information should be / has been collected from. More...
| virtual int | GetPortNumber () |
| virtual void | SetRank (int) |
| | Indicates which rank to gather the information from. More...
| virtual int | GetRank () |
| virtual char * | GetSubsetSelector () |
| | Path if non-null, used to limit blocks from a composite dataset. More...
| virtual void | SetSubsetSelector (const char *) |
| virtual void | SetSubsetAssemblyName (const char *) |
| | Get/Set the assembly to use for subsetting. More...
| virtual char * | GetSubsetAssemblyName () |
| void | SetSubsetAssemblyNameToHierarchy () |
| void | AddInformation (vtkPVInformation *info) override |
| | vtkPVInformation API implementation. More...
| void | CopyToStream (vtkClientServerStream *) override |
| void | CopyFromStream (const vtkClientServerStream *) override |
| void | CopyParametersToStream (vtkMultiProcessStream &) override |
| void | CopyParametersFromStream (vtkMultiProcessStream &) override |
| const std::vector< int > & | GetUniqueBlockTypes () const |
| | For a composite dataset, returns a list of unique data set types for all non-null leaf nodes. More...
| unsigned int | GetNumberOfUniqueBlockTypes () const |
| int | GetUniqueBlockType (unsigned int index) const |
| bool | DataSetTypeIsA (const char *classname) const |
| | Returns true if the type is of the requested classname (or typeId). More...
| bool | DataSetTypeIsA (int typeId) const |
| bool | HasDataSetType (const char *classname) const |
| | Similar to DataSetTypeIsA except, in case of composite datasets, returns true if any of the leaf nodes match the requested type. More...
| bool | HasDataSetType (int typeId) const |
| vtkTypeInt64 | GetNumberOfPoints () const |
| | Convenience methods that simply call GetNumberOfElements with appropriate element type. More...
| vtkTypeInt64 | GetNumberOfCells () const |
| vtkTypeInt64 | GetNumberOfVertices () const |
| vtkTypeInt64 | GetNumberOfEdges () const |
| vtkTypeInt64 | GetNumberOfRows () const |
| virtual vtkTypeInt64 | GetNumberOfTrees () |
| | vtkHyperTreeGrid / vtkUniformHyperTreeGrid specific properties. More...
| virtual vtkTypeInt64 | GetNumberOfLeaves () |
| virtual int * | GetExtent () |
| | Returns structured extents for the data. More...
| virtual void | GetExtent (int &, int &, int &, int &, int &, int &) |
| virtual void | GetExtent (int [6]) |
| int | GetNumberOfAttributeTypes () const |
| | Get vtkPVDataSetAttributesInformation information for the given association. More...
| std::vector< int > | GetAttributeTypes () const |
| std::vector< std::string > | GetAttributeNames () const |
| std::string | GetAttributeName (int attributeType) const |
| vtkPVDataSetAttributesInformation * | GetAttributeInformation (int attributeType) const |
| vtkPVDataSetAttributesInformation * | GetPointDataInformation () const |
| | Convenience methods to get vtkPVDataSetAttributesInformation for specific attribute type. More...
| vtkPVDataSetAttributesInformation * | GetCellDataInformation () const |
| vtkPVDataSetAttributesInformation * | GetVertexDataInformation () const |
| vtkPVDataSetAttributesInformation * | GetEdgeDataInformation () const |
| vtkPVDataSetAttributesInformation * | GetRowDataInformation () const |
| vtkPVDataSetAttributesInformation * | GetFieldDataInformation () const |
| virtual bool | GetHasTime () |
| | Returns DATA_TIME_STEP, if any, provided by the information object associated with data. More...
| virtual double | GetTime () |
| virtual double * | GetTimeRange () |
| | Strictly speaking, these are not data information since these cannot be obtained from the data but from the pipeline producing the data. More...
| virtual void | GetTimeRange (double &, double &) |
| virtual void | GetTimeRange (double [2]) |
| virtual std::string | GetTimeLabel () |
| const std::set< double > & | GetTimeSteps () const |
| vtkTypeInt64 | GetNumberOfTimeSteps () const |
| vtkDataAssembly * | GetHierarchy () const |
| | For composite datasets, this provides access to the information about the dataset hierarchy and any data assembly associated with it. More...
| vtkDataAssembly * | GetDataAssembly () const |
| vtkDataAssembly * | GetDataAssembly (const char *assemblyName) const |
| const char * | GetDataSetTypeAsString () const |
| | Returns a string for the given type. More...
| const char * | GetDataClassName () const |
| const char * | GetCompositeDataClassName () const |
| const char * | GetPrettyDataTypeString () const |
| | Returns a user-friendly string describing the datatype. More...
| virtual int | GetRootOnly () |
| | Set/get whether to gather information only from the root. More...
