List of array info. More...
#include <vtkPVDataSetAttributesInformation.h>
| class | AlphabeticalArrayInformationIterator |
Iterator over a vtkPVDataSetAttributesInformation's arrays; yielding their vtkPVArrayInformation. More... | |
| void | Initialize () |
| Initialize this instances to its default state. More... | |
| int | GetNumberOfArrays () const |
| Returns the number of array informations available in this instance. More... | |
| int | GetMaximumNumberOfTuples () const |
| Returns the maximum number of tuples in all known arrays. More... | |
| vtkPVArrayInformation * | GetAttributeInformation (int attributeType) |
| Returns array information for an array associated with a specific attribute type. More... | |
| int | IsArrayAnAttribute (int arrayIndex) |
| Returns the attribute type if at the array at the given index is an attribute. More... | |
| AlphabeticalArrayInformationIterator * | NewAlphabeticalArrayInformationIterator () |
| Returns a new iterator to traverse array informations alphabetically. More... | |
| virtual int | GetFieldAssociation () |
| Returns the field association to which the instance corresponds to. More... | |
| virtual char * | GetFieldName () |
| vtkPVArrayInformation * | GetArrayInformation (int idx) const |
| Returns array information for the chosen array either by name or by index. More... | |
| vtkPVArrayInformation * | GetArrayInformation (const char *name) const |
| static vtkPVDataSetAttributesInformation * | New () |
| static vtkPVDataSetAttributesInformation * | SafeDownCast (vtkObject *o) |
| vtkPVDataSetAttributesInformation () | |
| ~vtkPVDataSetAttributesInformation () override | |
| void | AddInformation (vtkPVDataSetAttributesInformation *) |
| Combine with another vtkPVDataSetAttributesInformation instance. More... | |
| void | DeepCopy (vtkPVDataSetAttributesInformation *) |
| Copies from another vtkPVDataSetAttributesInformation instance. More... | |
| void | CopyFromDataObject (vtkDataObject *dobj) |
| Initializes this instance using the data object. More... | |
| void | MarkArraysAsGlobal () |
| Marks all arrays in this instance as global (i.e., from the root node of a composite dataset). More... | |
| virtual void | SetFieldAssociation (int) |
| Set field association and name. More... | |
| virtual void | SetFieldName (const char *) |
| void | CopyToStream (vtkClientServerStream *) |
| Manage a serialized version of the information. More... | |
| void | CopyFromStream (const vtkClientServerStream *) |
Friends | |
| class | vtkPVDataInformation |
| class | vtkPVDataInformationAccumulator |
List of array info.
Information associated with vtkDataSetAttributes object (i.e point data). This object does not have any user interface. It is created and destroyed on the fly as needed. It may be possible to add features of this object to vtkDataSetAttributes. That would eliminate all of the "Information" in ParaView.
Definition at line 27 of file vtkPVDataSetAttributesInformation.h.
Definition at line 53 of file vtkPVDataSetAttributesInformation.h.
Returned value can be vtkDataObject::POINT, vtkDataObject::CELL, vtkDataObject::FIELD, etc i.e. vtkDataObject::FieldAssociations or vtkDataObject::AttributeTypes.
For vtkCellGrid, this can be the hash value of the string token of each attribute.
| void vtkPVDataSetAttributesInformation::Initialize | ( | ) |
| int vtkPVDataSetAttributesInformation::GetNumberOfArrays | ( | ) | const |
| int vtkPVDataSetAttributesInformation::GetMaximumNumberOfTuples | ( | ) | const |
| vtkPVArrayInformation* vtkPVDataSetAttributesInformation::GetArrayInformation | ( | int | idx | ) | const |
Note that the index overload is significantly is faster.
| vtkPVArrayInformation* vtkPVDataSetAttributesInformation::GetArrayInformation | ( | const char * | name | ) | const |
| vtkPVArrayInformation* vtkPVDataSetAttributesInformation::GetAttributeInformation | ( | int | attributeType | ) |
Supported attribute types are vtkDataSetAttributes::AttributeTypes.
| AlphabeticalArrayInformationIterator* vtkPVDataSetAttributesInformation::NewAlphabeticalArrayInformationIterator | ( | ) |
This approach is noticeably slower than looping over array indices. Prefer doing so unless you explicitely need the ordered arrays. Caller is responsible for releasing the iterator memory.
protectedvirtual |
protectedvirtual |
Must be called after CopyFromDataObject.
friend |
Definition at line 117 of file vtkPVDataSetAttributesInformation.h.
friend |
Definition at line 118 of file vtkPVDataSetAttributesInformation.h.
1.8.13 on Sat Oct 10 2026
