composite keyframe. More...
#include <vtkPVCompositeKeyFrame.h>
| enum | { NONE = 0, BOOLEAN = 1, RAMP = 2, EXPONENTIAL = 3, SINUSOID = 4 } |
| typedef vtkPVKeyFrame | Superclass |
Public Types inherited from vtkPVKeyFrame | |
| void | UpdateValue (double currenttime, vtkPVAnimationCue *cue, vtkPVKeyFrame *next) override |
| This method will do the actual interpolation. More... | |
| void | RemoveAllKeyValues () override |
| Overridden to pass on to the internal keyframe proxies. More... | |
| void | SetKeyTime (double time) override |
| void | SetKeyValue (double val) override |
| void | SetKeyValue (unsigned int index, double val) override |
| void | SetNumberOfKeyValues (unsigned int num) override |
| void | SetBase (double val) |
| Passed on to the ExponentialKeyFrame. More... | |
| void | SetStartPower (double val) |
| void | SetEndPower (double val) |
| void | SetPhase (double val) |
| Passed on to the SinusoidKeyFrame. More... | |
| void | SetFrequency (double val) |
| void | SetOffset (double val) |
Public Member Functions inherited from vtkPVKeyFrame | |
| virtual double | GetKeyTime () |
| Key time is the time at which this key frame is associated. More... | |
| double | GetKeyValue () |
| Get/Set the animated value at this key frame. More... | |
| double | GetKeyValue (unsigned int index) |
| unsigned int | GetNumberOfKeyValues () |
| Set/Get the number of key values this key frame currently stores. More... | |
| static vtkPVCompositeKeyFrame * | New () |
| static vtkPVCompositeKeyFrame * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkPVKeyFrame | |
| static vtkPVKeyFrame * | SafeDownCast (vtkObject *o) |
| static vtkPVKeyFrame * | New () |
| vtkPVCompositeKeyFrame () | |
| ~vtkPVCompositeKeyFrame () override | |
Protected Member Functions inherited from vtkPVKeyFrame | |
| vtkPVKeyFrame () | |
| ~vtkPVKeyFrame () override | |
Protected Attributes | |
| int | Type |
| vtkPVBooleanKeyFrame * | BooleanKeyFrame |
| vtkPVRampKeyFrame * | RampKeyFrame |
| vtkPVExponentialKeyFrame * | ExponentialKeyFrame |
| vtkPVSinusoidKeyFrame * | SinusoidKeyFrame |
Protected Attributes inherited from vtkPVKeyFrame | |
| double | KeyTime |
| vtkPVKeyFrameInternals * | Internals |
| static const char * | GetTypeAsString (int) |
| Get/Set the type of keyframe to be used as the active type. More... | |
| static int | GetTypeFromString (const char *string) |
| virtual void | SetType (int) |
| virtual int | GetType () |
| const char * | GetTypeAsString () |
composite keyframe.
There are many different types of keyframes such as vtkPVSinusoidKeyFrame, vtkPVRampKeyFrame etc. This is keyframe that has all different types of keyframes as internal objects and provides API to choose one of them as the active type. This is helpful in GUIs that allow for switching the type of keyframe on the fly without much effort from the GUI.
Definition at line 25 of file vtkPVCompositeKeyFrame.h.
Definition at line 29 of file vtkPVCompositeKeyFrame.h.
| anonymous enum |
| Enumerator | |
| NONE | |
| BOOLEAN | |
| RAMP | |
| EXPONENTIAL | |
| SINUSOID | |
Definition at line 32 of file vtkPVCompositeKeyFrame.h.
Reimplemented from vtkPVKeyFrame.
inlineoverridevirtual |
Definition at line 47 of file vtkPVCompositeKeyFrame.h.
| void vtkPVCompositeKeyFrame::SetBase | ( | double | val | ) |
| void vtkPVCompositeKeyFrame::SetStartPower | ( | double | val | ) |
| void vtkPVCompositeKeyFrame::SetEndPower | ( | double | val | ) |
| void vtkPVCompositeKeyFrame::SetPhase | ( | double | val | ) |
| void vtkPVCompositeKeyFrame::SetFrequency | ( | double | val | ) |
| void vtkPVCompositeKeyFrame::SetOffset | ( | double | val | ) |
Default is RAMP.
Default is RAMP.
Default is RAMP.
Definition at line 77 of file vtkPVCompositeKeyFrame.h.
Default is RAMP.
Default is RAMP.
currenttime is normalized to the time range between this key frame and the next key frame.
Definition at line 93 of file vtkPVCompositeKeyFrame.h.
Definition at line 95 of file vtkPVCompositeKeyFrame.h.
Definition at line 96 of file vtkPVCompositeKeyFrame.h.
Definition at line 97 of file vtkPVCompositeKeyFrame.h.
Definition at line 98 of file vtkPVCompositeKeyFrame.h.
