| void | UpdateValue (double currenttime, vtkPVAnimationCue *cue, vtkPVKeyFrame *next) override |
| | This method will do the actual interpolation. More...
| virtual void | SetPhase (double) |
| | Get/Set the phase for the sine wave. More...
| virtual double | GetPhase () |
| virtual void | SetFrequency (double) |
| | Get/Set the frequency for the sine wave in number of cycles for the entire length of this keyframe i.e. More...
| virtual double | GetFrequency () |
| virtual void | SetOffset (double) |
| | Get/Set the Wave offset. More...
| virtual double | GetOffset () |
| virtual void | RemoveAllKeyValues () |
| | Removes all key values. More...
| virtual void | SetKeyTime (double) |
| | Key time is the time at which this key frame is associated. More...
| virtual double | GetKeyTime () |
| virtual void | SetKeyValue (double val) |
| | Get/Set the animated value at this key frame. More...
| virtual void | SetKeyValue (unsigned int index, double val) |
| double | GetKeyValue () |
| double | GetKeyValue (unsigned int index) |
| unsigned int | GetNumberOfKeyValues () |
| | Set/Get the number of key values this key frame currently stores. More...
| virtual void | SetNumberOfKeyValues (unsigned int num) |
Interplates a sinusoid.
At any given time t, the resultant value obtained from this keyframe is given by : value = this->Offset + (Key Value) * Sin (2*pi*theta); where theta = this->Frequency*t + (this->Phase/360). As is clear from the equation, the amplitude of the wave is obtained from the value of the keyframe.
Definition at line 19 of file vtkPVSinusoidKeyFrame.h.
