| void | UpdateValue (double currenttime, vtkPVAnimationCue *cueProxy, vtkPVKeyFrame *next) override |
| | This method will do the actual interpolation. More...
| virtual void | RemoveAllKeyValues () |
| | Removes all key values. More...
| virtual void | SetKeyTime (double) |
| | Key time is the time at which this key frame is associated. More...
| virtual double | GetKeyTime () |
| virtual void | SetKeyValue (double val) |
| | Get/Set the animated value at this key frame. More...
| virtual void | SetKeyValue (unsigned int index, double val) |
| double | GetKeyValue () |
| double | GetKeyValue (unsigned int index) |
| unsigned int | GetNumberOfKeyValues () |
| | Set/Get the number of key values this key frame currently stores. More...
| virtual void | SetNumberOfKeyValues (unsigned int num) |
Empty key frame.
Can be used to toggle boolean properties.
Definition at line 14 of file vtkPVBooleanKeyFrame.h.
