vtkLegacyParticleTracerBase Class Referenceabstract
A particle tracer for vector fields. More...
#include <vtkLegacyParticleTracerBase.h>
Inheritance diagram for vtkLegacyParticleTracerBase:
Collaboration diagram for vtkLegacyParticleTracerBase:
enum  Solvers {
  RUNGE_KUTTA2, RUNGE_KUTTA4, RUNGE_KUTTA45, NONE,
  UNKNOWN
enum  MeshOverTimeTypes { DIFFERENT = 0, STATIC = 1, LINEAR_TRANSFORMATION = 2, SAME_TOPOLOGY = 3 }
 Types of Variance of Mesh over time. More...
enum  { INTERPOLATOR_WITH_DATASET_POINT_LOCATOR, INTERPOLATOR_WITH_CELL_LOCATOR }
typedef vtkPolyDataAlgorithm Superclass
- Public Types inherited from vtkPolyDataAlgorithm
enum  DesiredOutputPrecision
void PrintParticleHistories ()
void SetIntegrator (vtkInitialValueProblemSolver *)
virtual vtkInitialValueProblemSolver * GetIntegrator ()
void SetIntegratorType (int type)
int GetIntegratorType ()
void SetInterpolatorType (int interpolatorType)
 Set the type of the velocity field interpolator to determine whether INTERPOLATOR_WITH_DATASET_POINT_LOCATOR or INTERPOLATOR_WITH_CELL_LOCATOR is employed for locating cells during streamline integration. More...
void SetInterpolatorTypeToDataSetPointLocator ()
 Set the velocity field interpolator type to one that uses a point locator to perform local spatial searching. More...
void SetInterpolatorTypeToCellLocator ()
 Set the velocity field interpolator type to one that uses a cell locator to perform spatial searching. More...
virtual bool GetComputeVorticity ()
 Turn on/off vorticity computation at streamline points (necessary for generating proper stream-ribbons using the vtkRibbonFilter. More...
void SetComputeVorticity (bool)
virtual double GetTerminalSpeed ()
 Specify the terminal speed value, below which integration is terminated. More...
void SetTerminalSpeed (double)
virtual double GetRotationScale ()
 This can be used to scale the rate with which the streamribbons twist. More...
void SetRotationScale (double)
virtual void SetIgnorePipelineTime (vtkTypeBool)
 To get around problems with the Paraview Animation controls we can just animate the time step and ignore the TIME_ requests. More...
virtual vtkTypeBool GetIgnorePipelineTime ()
virtual void IgnorePipelineTimeOn ()
virtual void IgnorePipelineTimeOff ()
virtual int GetForceReinjectionEveryNSteps ()
 When animating particles, it is nice to inject new ones every Nth step to produce a continuous flow. More...
void SetForceReinjectionEveryNSteps (int)
void SetTerminationTime (double t)
 Setting TerminationTime to a positive value will cause particles to terminate when the time is reached. More...
virtual double GetTerminationTime ()
virtual double GetStartTime ()
 Set the time value for particle tracing to begin. More...
void SetStartTime (double t)
virtual void SetStaticSeeds (vtkTypeBool)
 if StaticSeeds is set and the mesh is static, then every time particles are injected we can re-use the same injection information. More...
virtual vtkTypeBool GetStaticSeeds ()
virtual void SetMeshOverTime (int meshOverTime)
virtual int GetMeshOverTimeMinValue ()
virtual int GetMeshOverTimeMaxValue ()
void SetMeshOverTimeToDifferent ()
void SetMeshOverTimeToStatic ()
void SetMeshOverTimeToLinearTransformation ()
void SetMeshOverTimeToSameTopology ()
virtual int GetMeshOverTime ()
virtual void SetStaticMesh (vtkTypeBool staticMesh)
 if StaticMesh is set, many optimizations for cell caching can be assumed. More...
virtual vtkTypeBool GetStaticMesh ()
virtual void SetParticleWriter (vtkAbstractParticleWriter *pw)
 Set/Get the Writer associated with this Particle Tracer Ideally a parallel IO capable vtkH5PartWriter should be used which will collect particles from all parallel processes and write them to a single HDF5 file. More...
virtual vtkAbstractParticleWriter * GetParticleWriter ()
 vtkSetFilePathMacro (ParticleFileName)
 Set/Get the filename to be used with the particle writer when dumping particles to disk. More...
 vtkGetFilePathMacro (ParticleFileName)
virtual void SetEnableParticleWriting (vtkTypeBool)
virtual vtkTypeBool GetEnableParticleWriting ()
virtual void EnableParticleWritingOn ()
virtual void EnableParticleWritingOff ()
virtual void SetDisableResetCache (vtkTypeBool)
 Set/Get the flag to disable cache This is off by default and turned on in special circumstances such as in a coprocessing workflow. More...
virtual vtkTypeBool GetDisableResetCache ()
virtual void DisableResetCacheOn ()
virtual void DisableResetCacheOff ()
void AddSourceConnection (vtkAlgorithmOutput *input)
 Provide support for multiple seed sources. More...
void RemoveAllSources ()
virtual bool GetForceSerialExecution ()
 Force the filter to run particle tracer in serial. More...
virtual void SetForceSerialExecution (bool)
virtual void ForceSerialExecutionOn ()
virtual void ForceSerialExecutionOff ()
- Public Member Functions inherited from vtkPolyDataAlgorithm
vtkPolyDataAlgorithm * NewInstance () const
vtkDataObject * GetInput ()
vtkPolyData * GetPolyDataInput (int port)
vtkPolyData * GetOutput ()
vtkPolyData * GetOutput (int)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkLegacyParticleTracerBase * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPolyDataAlgorithm
static vtkPolyDataAlgorithm * New ()
static vtkPolyDataAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkLegacyParticleTracerBase ()
 ~vtkLegacyParticleTracerBase () override
vtkTypeBool ProcessRequest (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
int RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
virtual int ProcessInput (vtkInformationVector **inputVector)
virtual vtkPolyData * Execute (vtkInformationVector **inputVector)
virtual void Initialize ()
virtual int OutputParticles (vtkPolyData *poly)=0
virtual void Finalize ()
virtual std::vector< vtkDataSet * > GetSeedSources (vtkInformationVector *inputVector, int timeStep)
 Method to get the data set seed sources. More...
int InitializeInterpolator ()
int UpdateDataCache (vtkDataObject *td)
void TestParticles (vtkLegacyParticleTracerBaseNamespace::ParticleVector &candidates, vtkLegacyParticleTracerBaseNamespace::ParticleVector &passed, int &count)
 inside our data. More...
void TestParticles (vtkLegacyParticleTracerBaseNamespace::ParticleVector &candidates, std::vector< int > &passed)
virtual void AssignSeedsToProcessors (double time, vtkDataSet *source, int sourceID, int ptId, vtkLegacyParticleTracerBaseNamespace::ParticleVector &localSeedPoints, int &localAssignedCount)
 all the injection/seed points according to which processor they belong to. More...
virtual void AssignUniqueIds (vtkLegacyParticleTracerBaseNamespace::ParticleVector &localSeedPoints)
 give each one a unique ID. More...
void UpdateParticleList (vtkLegacyParticleTracerBaseNamespace::ParticleVector &candidates)
 and sending between processors, into a list, which is used as the master list on this processor More...
virtual bool UpdateParticleListFromOtherProcesses ()
 this is used during classification of seed points and also between iterations of the main loop as particles leave each processor domain. More...
void IntegrateParticle (vtkLegacyParticleTracerBaseNamespace::ParticleListIterator &it, double currentTime, double targetTime, vtkInitialValueProblemSolver *integrator, vtkTemporalInterpolatedVelocityField *interpolator, vtkDoubleArray *cellVectors, std::atomic< vtkIdType > &particleCount, std::mutex &eraseMutex, bool sequential)
 particle between the two times supplied. More...
virtual bool SendParticleToAnotherProcess (vtkLegacyParticleTracerBaseNamespace::ParticleInformation &, vtkLegacyParticleTracerBaseNamespace::ParticleInformation &, vtkPointData *)
bool ComputeDomainExitLocation (double pos[4], double p2[4], double intersection[4], vtkGenericCell *cell)
 This is an old routine kept for possible future use. More...
void CreateProtoPD (vtkDataObject *input)
vtkFloatArray * GetParticleAge (vtkPointData *)
vtkIntArray * GetParticleIds (vtkPointData *)
vtkSignedCharArray * GetParticleSourceIds (vtkPointData *)
vtkIntArray * GetInjectedPointIds (vtkPointData *)
vtkIntArray * GetInjectedStepIds (vtkPointData *)
vtkIntArray * GetErrorCodeArr (vtkPointData *)
vtkFloatArray * GetParticleVorticity (vtkPointData *)
vtkFloatArray * GetParticleRotation (vtkPointData *)
vtkFloatArray * GetParticleAngularVel (vtkPointData *)
bool InsideBounds (double point[])
void CalculateVorticity (vtkGenericCell *cell, double pcoords[3], vtkDoubleArray *cellVectors, double vorticity[3])
double GetCacheDataTime (int i)
double GetCacheDataTime ()
virtual void ResetCache ()
void SetParticle (vtkLegacyParticleTracerBaseNamespace::ParticleInformation &info, double *velocity, vtkTemporalInterpolatedVelocityField *interpolator, vtkIdType particleId, vtkDoubleArray *cellVectors)
virtual int GetReinjectionCounter ()
virtual double GetCurrentTimeValue ()
void ResizeArrays (vtkIdType numTuples)
virtual void InitializeExtraPointDataArrays (vtkPointData *vtkNotUsed(outputPD))
 Methods to append values to existing point data arrays that may only be desired on specific concrete derived classes. More...
virtual void SetToExtraPointDataArrays (vtkIdType, vtkLegacyParticleTracerBaseNamespace::ParticleInformation &)
vtkTemporalInterpolatedVelocityField * GetInterpolator ()
virtual void AddRestartSeeds (vtkInformationVector **)
 For restarts of particle paths, we add in the ability to add in particles from a previous computation that we will still advect. More...
virtual void RenameGhostArray (vtkPointData *pd)
 Recover the ghost array in provided point data and rename it by adding "Original_" in front of it, if available. More...
virtual bool IsPointDataValid (vtkDataObject *input)
 Methods that check that the input arrays are ordered the same on all data sets. More...
bool IsPointDataValid (vtkCompositeDataSet *input, std::vector< std::string > &arrayNames)
void GetPointDataArrayNames (vtkDataSet *input, std::vector< std::string > &names)
- Protected Member Functions inherited from vtkPolyDataAlgorithm
 vtkPolyDataAlgorithm ()
 ~vtkPolyDataAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkSmartPointer< vtkPolyData > Output
bool ForceSerialExecution
vtkSmartPointer< vtkPointData > ProtoPD
 ProtoPD is used just to keep track of the input array names and number of components for copy allocating from other vtkPointDatas where the data is really stored. More...
vtkIdType UniqueIdCounter
vtkLegacyParticleTracerBaseNamespace::ParticleDataList ParticleHistories
vtkSmartPointer< vtkPointData > ParticlePointData
vtkTypeBool IgnorePipelineTime
vtkTypeBool DisableResetCache
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
Friends
struct vtkLegacyParticleTracerBaseNamespace::ParticleTracerFunctor
class vtkLegacyPParticlePathFilter
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkLegacyParticleTracerBase is the base class for filters that advect particles in a vector field. Note that the input vtkPointData structure must be identical on all datasets.
See also
vtkRibbonFilter vtkRuledSurfaceFilter vtkInitialValueProblemSolver vtkRungeKutta2 vtkRungeKutta4 vtkRungeKutta45 vtkStreamTracer
Definition at line 92 of file vtkLegacyParticleTracerBase.h.
Definition at line 106 of file vtkLegacyParticleTracerBase.h.
◆ Solvers
Enumerator
RUNGE_KUTTA2
RUNGE_KUTTA4
RUNGE_KUTTA45
NONE
UNKNOWN
Definition at line 97 of file vtkLegacyParticleTracerBase.h.
◆ MeshOverTimeTypes
Enumerator
DIFFERENT
STATIC
SAME_TOPOLOGY
Definition at line 204 of file vtkLegacyParticleTracerBase.h.
◆ anonymous enum
anonymous enum
Enumerator
Definition at line 250 of file vtkLegacyParticleTracerBase.h.
◆ vtkLegacyParticleTracerBase()
vtkLegacyParticleTracerBase::vtkLegacyParticleTracerBase ( )
◆ ~vtkLegacyParticleTracerBase()
vtkLegacyParticleTracerBase::~vtkLegacyParticleTracerBase ( )
virtual const char* vtkLegacyParticleTracerBase::GetClassName ( )
static int vtkLegacyParticleTracerBase::IsTypeOf ( const char *  type)
virtual int vtkLegacyParticleTracerBase::IsA ( const char *  type)
static vtkLegacyParticleTracerBase* vtkLegacyParticleTracerBase::SafeDownCast ( vtkObject *  o)
void vtkLegacyParticleTracerBase::PrintSelf ( ostream &  os,
◆ PrintParticleHistories()
void vtkLegacyParticleTracerBase::PrintParticleHistories ( )
◆ GetComputeVorticity()
virtual bool vtkLegacyParticleTracerBase::GetComputeVorticity ( )
◆ SetComputeVorticity()
void vtkLegacyParticleTracerBase::SetComputeVorticity ( bool  )
◆ GetTerminalSpeed()
virtual double vtkLegacyParticleTracerBase::GetTerminalSpeed ( )
◆ SetTerminalSpeed()
void vtkLegacyParticleTracerBase::SetTerminalSpeed ( double  )
◆ GetRotationScale()
virtual double vtkLegacyParticleTracerBase::GetRotationScale ( )
The default is 1.
◆ SetRotationScale()
void vtkLegacyParticleTracerBase::SetRotationScale ( double  )
The default is 1.
◆ SetIgnorePipelineTime()
virtual void vtkLegacyParticleTracerBase::SetIgnorePipelineTime ( vtkTypeBool  )
◆ GetIgnorePipelineTime()
virtual vtkTypeBool vtkLegacyParticleTracerBase::GetIgnorePipelineTime ( )
◆ IgnorePipelineTimeOn()
virtual void vtkLegacyParticleTracerBase::IgnorePipelineTimeOn ( )
◆ IgnorePipelineTimeOff()
virtual void vtkLegacyParticleTracerBase::IgnorePipelineTimeOff ( )
◆ GetForceReinjectionEveryNSteps()
virtual int vtkLegacyParticleTracerBase::GetForceReinjectionEveryNSteps ( )
Setting ForceReinjectionEveryNSteps to a non zero value will cause the particle source to reinject particles every Nth step even if it is otherwise unchanged. Note that if the particle source is also animated, this flag will be redundant as the particles will be reinjected whenever the source changes anyway
◆ SetForceReinjectionEveryNSteps()
void vtkLegacyParticleTracerBase::SetForceReinjectionEveryNSteps ( int  )
◆ SetTerminationTime()
void vtkLegacyParticleTracerBase::SetTerminationTime ( double  t)
Use a vlue of zero to disable termination. The units of time should be consistent with the primary time variable.
◆ GetTerminationTime()
virtual double vtkLegacyParticleTracerBase::GetTerminationTime ( )
◆ SetIntegrator()
void vtkLegacyParticleTracerBase::SetIntegrator ( vtkInitialValueProblemSolver *  )
◆ GetIntegrator()
virtual vtkInitialValueProblemSolver* vtkLegacyParticleTracerBase::GetIntegrator ( )
◆ SetIntegratorType()
void vtkLegacyParticleTracerBase::SetIntegratorType ( int  type)
◆ GetIntegratorType()
int vtkLegacyParticleTracerBase::GetIntegratorType ( )
◆ GetStartTime()
virtual double vtkLegacyParticleTracerBase::GetStartTime ( )
◆ SetStartTime()
void vtkLegacyParticleTracerBase::SetStartTime ( double  t)
◆ SetStaticSeeds()
virtual void vtkLegacyParticleTracerBase::SetStaticSeeds ( vtkTypeBool  )
We classify particles according to processor just once before start. If StaticSeeds is set and a moving seed source is specified the motion will be ignored and results will not be as expected. The default is that StaticSeeds is 0.
◆ GetStaticSeeds()
virtual vtkTypeBool vtkLegacyParticleTracerBase::GetStaticSeeds ( )
◆ SetMeshOverTime()
virtual void vtkLegacyParticleTracerBase::SetMeshOverTime ( int  meshOverTime)
◆ GetMeshOverTimeMinValue()
virtual int vtkLegacyParticleTracerBase::GetMeshOverTimeMinValue ( )
inlinevirtual
Definition at line 222 of file vtkLegacyParticleTracerBase.h.
◆ GetMeshOverTimeMaxValue()
virtual int vtkLegacyParticleTracerBase::GetMeshOverTimeMaxValue ( )
inlinevirtual
Definition at line 223 of file vtkLegacyParticleTracerBase.h.
◆ SetMeshOverTimeToDifferent()
void vtkLegacyParticleTracerBase::SetMeshOverTimeToDifferent ( )
inline
Definition at line 224 of file vtkLegacyParticleTracerBase.h.
◆ SetMeshOverTimeToStatic()
void vtkLegacyParticleTracerBase::SetMeshOverTimeToStatic ( )
inline
Definition at line 225 of file vtkLegacyParticleTracerBase.h.
◆ SetMeshOverTimeToLinearTransformation()
void vtkLegacyParticleTracerBase::SetMeshOverTimeToLinearTransformation ( )
inline
Definition at line 226 of file vtkLegacyParticleTracerBase.h.
◆ SetMeshOverTimeToSameTopology()
void vtkLegacyParticleTracerBase::SetMeshOverTimeToSameTopology ( )
inline
Definition at line 227 of file vtkLegacyParticleTracerBase.h.
◆ GetMeshOverTime()
virtual int vtkLegacyParticleTracerBase::GetMeshOverTime ( )
◆ SetStaticMesh()
virtual void vtkLegacyParticleTracerBase::SetStaticMesh ( vtkTypeBool  staticMesh)
inlinevirtual
if StaticMesh is not set, the algorithm will attempt to find out if optimizations can be used, but setting it to true will force all optimizations. Do not Set StaticMesh to true if a dynamic mesh is being used as this will invalidate all results. The default is that StaticMesh is 0.
Definition at line 242 of file vtkLegacyParticleTracerBase.h.
◆ GetStaticMesh()
virtual vtkTypeBool vtkLegacyParticleTracerBase::GetStaticMesh ( )
inlinevirtual
Definition at line 247 of file vtkLegacyParticleTracerBase.h.
◆ SetInterpolatorType()
void vtkLegacyParticleTracerBase::SetInterpolatorType ( int  interpolatorType)
The latter (adopting vtkAbstractCellLocator sub-classes such as vtkCellLocator and vtkModifiedBSPTree) is more robust than the former (through vtkDataSet / vtkPointSet::FindCell() coupled with vtkPointLocator). However the former can be much faster and produce adequate results.
Default is INTERPOLATOR_WITH_CELL_LOCATOR (to maintain backwards compatibility).
◆ SetInterpolatorTypeToDataSetPointLocator()
void vtkLegacyParticleTracerBase::SetInterpolatorTypeToDataSetPointLocator ( )
Typically a point locator is faster than searches with a cell locator, but it may not always find the correct cells enclosing a point. This is particularly true with meshes that are disjoint at seams, or abut meshes in an incompatible manner.
◆ SetInterpolatorTypeToCellLocator()
void vtkLegacyParticleTracerBase::SetInterpolatorTypeToCellLocator ( )
Using a cell locator should always return the correct results, but it can be much slower that point locator-based searches. * By default a cell locator is used.
◆ SetParticleWriter()
virtual void vtkLegacyParticleTracerBase::SetParticleWriter ( vtkAbstractParticleWriter *  pw)
◆ GetParticleWriter()
virtual vtkAbstractParticleWriter* vtkLegacyParticleTracerBase::GetParticleWriter ( )
◆ vtkSetFilePathMacro()
vtkLegacyParticleTracerBase::vtkSetFilePathMacro ( ParticleFileName  )
◆ vtkGetFilePathMacro()
vtkLegacyParticleTracerBase::vtkGetFilePathMacro ( ParticleFileName  )
◆ SetEnableParticleWriting()
virtual void vtkLegacyParticleTracerBase::SetEnableParticleWriting ( vtkTypeBool  )
◆ GetEnableParticleWriting()
virtual vtkTypeBool vtkLegacyParticleTracerBase::GetEnableParticleWriting ( )
◆ EnableParticleWritingOn()
virtual void vtkLegacyParticleTracerBase::EnableParticleWritingOn ( )
◆ EnableParticleWritingOff()
virtual void vtkLegacyParticleTracerBase::EnableParticleWritingOff ( )
◆ SetDisableResetCache()
virtual void vtkLegacyParticleTracerBase::SetDisableResetCache ( vtkTypeBool  )
◆ GetDisableResetCache()
virtual vtkTypeBool vtkLegacyParticleTracerBase::GetDisableResetCache ( )
◆ DisableResetCacheOn()
virtual void vtkLegacyParticleTracerBase::DisableResetCacheOn ( )
◆ DisableResetCacheOff()
virtual void vtkLegacyParticleTracerBase::DisableResetCacheOff ( )
◆ AddSourceConnection()
void vtkLegacyParticleTracerBase::AddSourceConnection ( vtkAlgorithmOutput *  input)
◆ RemoveAllSources()
void vtkLegacyParticleTracerBase::RemoveAllSources ( )
◆ GetForceSerialExecution()
virtual bool vtkLegacyParticleTracerBase::GetForceSerialExecution ( )
This affects the filter only if more than 100 particles is to be generated.
◆ SetForceSerialExecution()
virtual void vtkLegacyParticleTracerBase::SetForceSerialExecution ( bool  )
◆ ForceSerialExecutionOn()
virtual void vtkLegacyParticleTracerBase::ForceSerialExecutionOn ( )
◆ ForceSerialExecutionOff()
virtual void vtkLegacyParticleTracerBase::ForceSerialExecutionOff ( )
◆ FillInputPortInformation()
int vtkLegacyParticleTracerBase::FillInputPortInformation ( int  port,
vtkInformation *  info
overrideprotectedvirtual
Reimplemented from vtkPolyDataAlgorithm.
◆ ProcessRequest()
vtkTypeBool vtkLegacyParticleTracerBase::ProcessRequest ( vtkInformation *  request,
◆ RequestInformation()
int vtkLegacyParticleTracerBase::RequestInformation ( vtkInformation *  request,
Reimplemented in vtkLegacyPParticlePathFilter.
◆ RequestUpdateExtent()
int vtkLegacyParticleTracerBase::RequestUpdateExtent ( vtkInformation *  request,
Reimplemented in vtkLegacyPParticleTracerBase.
◆ RequestData()
int vtkLegacyParticleTracerBase::RequestData ( vtkInformation *  request,
◆ ProcessInput()
virtual int vtkLegacyParticleTracerBase::ProcessInput ( vtkInformationVector **  inputVector)
protectedvirtual
◆ Execute()
virtual vtkPolyData* vtkLegacyParticleTracerBase::Execute ( vtkInformationVector **  inputVector)
protectedvirtual
◆ Initialize()
virtual void vtkLegacyParticleTracerBase::Initialize ( void  )
inlineprotectedvirtual
Definition at line 412 of file vtkLegacyParticleTracerBase.h.
◆ OutputParticles()
virtual int vtkLegacyParticleTracerBase::OutputParticles ( vtkPolyData *  poly)
protectedpure virtual
◆ Finalize()
virtual void vtkLegacyParticleTracerBase::Finalize ( void  )
Definition at line 414 of file vtkLegacyParticleTracerBase.h.
◆ GetSeedSources()
virtual std::vector<vtkDataSet*> vtkLegacyParticleTracerBase::GetSeedSources ( vtkInformationVector *  inputVector,
int  timeStep
protectedvirtual
For in situ we want to override how the seed sources are made available.
Reimplemented in vtkInSituPParticlePathFilter.
◆ InitializeInterpolator()
int vtkLegacyParticleTracerBase::InitializeInterpolator ( )
◆ UpdateDataCache()
int vtkLegacyParticleTracerBase::UpdateDataCache ( vtkDataObject *  td)
◆ TestParticles() [1/2]
void vtkLegacyParticleTracerBase::TestParticles ( vtkLegacyParticleTracerBaseNamespace::ParticleVector &  candidates,
vtkLegacyParticleTracerBaseNamespace::ParticleVector &  passed,
int &  count
inside our data.
Add good ones to passed list and set count to the number that passed
◆ TestParticles() [2/2]
std::vector< int > &  passed
◆ AssignSeedsToProcessors()
virtual void vtkLegacyParticleTracerBase::AssignSeedsToProcessors ( double  time,
vtkDataSet *  source,
int  sourceID,
int  ptId,
vtkLegacyParticleTracerBaseNamespace::ParticleVector &  localSeedPoints,
int &  localAssignedCount
protectedvirtual
This saves us retesting at every injection time providing 1) The volumes are static, 2) the seed points are static If either are non static, then this step is skipped.
Reimplemented in vtkInSituPParticlePathFilter, and vtkLegacyPParticleTracerBase.
◆ AssignUniqueIds()
virtual void vtkLegacyParticleTracerBase::AssignUniqueIds ( vtkLegacyParticleTracerBaseNamespace::ParticleVector &  localSeedPoints)
protectedvirtual
We need to use MPI to find out who is using which numbers.
◆ UpdateParticleList()
void vtkLegacyParticleTracerBase::UpdateParticleList ( vtkLegacyParticleTracerBaseNamespace::ParticleVector &  candidates)
◆ UpdateParticleListFromOtherProcesses()
virtual bool vtkLegacyParticleTracerBase::UpdateParticleListFromOtherProcesses ( )
Returns true if particles moved between processes and false otherwise.
Definition at line 463 of file vtkLegacyParticleTracerBase.h.
◆ IntegrateParticle()
void vtkLegacyParticleTracerBase::IntegrateParticle ( vtkLegacyParticleTracerBaseNamespace::ParticleListIterator &  it,
double  currentTime,
double  targetTime,
vtkInitialValueProblemSolver *  integrator,
vtkTemporalInterpolatedVelocityField *  interpolator,
vtkDoubleArray *  cellVectors,
std::atomic< vtkIdType > &  particleCount,
std::mutex &  eraseMutex,
bool  sequential
◆ SendParticleToAnotherProcess()
virtual bool vtkLegacyParticleTracerBase::SendParticleToAnotherProcess ( vtkLegacyParticleTracerBaseNamespace::ParticleInformation &  ,
vtkPointData *
Definition at line 475 of file vtkLegacyParticleTracerBase.h.
◆ ComputeDomainExitLocation()
bool vtkLegacyParticleTracerBase::ComputeDomainExitLocation ( double  pos[4],
double  p2[4],
vtkGenericCell *  cell
In dynamic meshes, particles might leave the domain and need to be extrapolated across a gap between the meshes before they re-renter another domain dodgy rotating meshes need special care....
◆ CreateProtoPD()
void vtkLegacyParticleTracerBase::CreateProtoPD ( vtkDataObject *  input)
◆ GetParticleAge()
vtkFloatArray* vtkLegacyParticleTracerBase::GetParticleAge ( vtkPointData *  )
◆ GetParticleIds()
vtkIntArray* vtkLegacyParticleTracerBase::GetParticleIds ( vtkPointData *  )
◆ GetParticleSourceIds()
vtkSignedCharArray* vtkLegacyParticleTracerBase::GetParticleSourceIds ( vtkPointData *  )
◆ GetInjectedPointIds()
vtkIntArray* vtkLegacyParticleTracerBase::GetInjectedPointIds ( vtkPointData *  )
◆ GetInjectedStepIds()
vtkIntArray* vtkLegacyParticleTracerBase::GetInjectedStepIds ( vtkPointData *  )
◆ GetErrorCodeArr()
vtkIntArray* vtkLegacyParticleTracerBase::GetErrorCodeArr ( vtkPointData *  )
◆ GetParticleVorticity()
vtkFloatArray* vtkLegacyParticleTracerBase::GetParticleVorticity ( vtkPointData *  )
◆ GetParticleRotation()
vtkFloatArray* vtkLegacyParticleTracerBase::GetParticleRotation ( vtkPointData *  )
◆ GetParticleAngularVel()
vtkFloatArray* vtkLegacyParticleTracerBase::GetParticleAngularVel ( vtkPointData *  )
◆ InsideBounds()
bool vtkLegacyParticleTracerBase::InsideBounds ( double  point[])
◆ CalculateVorticity()
void vtkLegacyParticleTracerBase::CalculateVorticity ( vtkGenericCell *  cell,
double  pcoords[3],
double  vorticity[3]
◆ GetCacheDataTime() [1/2]
double vtkLegacyParticleTracerBase::GetCacheDataTime ( int  i)
◆ GetCacheDataTime() [2/2]
double vtkLegacyParticleTracerBase::GetCacheDataTime ( )
◆ ResetCache()
virtual void vtkLegacyParticleTracerBase::ResetCache ( )
protectedvirtual
◆ SetParticle()
void vtkLegacyParticleTracerBase::SetParticle ( vtkLegacyParticleTracerBaseNamespace::ParticleInformation &  info,
double *  velocity,
◆ IsPointDataValid() [1/2]
virtual bool vtkLegacyParticleTracerBase::IsPointDataValid ( vtkDataObject *  input)
protectedvirtual
This needs to be true for all blocks in a composite data set as well as across all processes.
◆ IsPointDataValid() [2/2]
bool vtkLegacyParticleTracerBase::IsPointDataValid ( vtkCompositeDataSet *  input,
std::vector< std::string > &  arrayNames
◆ GetPointDataArrayNames()
void vtkLegacyParticleTracerBase::GetPointDataArrayNames ( vtkDataSet *  input,
std::vector< std::string > &  names
◆ GetReinjectionCounter()
virtual int vtkLegacyParticleTracerBase::GetReinjectionCounter ( )
protectedvirtual
◆ GetCurrentTimeValue()
virtual double vtkLegacyParticleTracerBase::GetCurrentTimeValue ( )
protectedvirtual
◆ ResizeArrays()
void vtkLegacyParticleTracerBase::ResizeArrays ( vtkIdType  numTuples)
◆ InitializeExtraPointDataArrays()
virtual void vtkLegacyParticleTracerBase::InitializeExtraPointDataArrays ( vtkPointData *  vtkNotUsedoutputPD)
Definition at line 542 of file vtkLegacyParticleTracerBase.h.
◆ SetToExtraPointDataArrays()
virtual void vtkLegacyParticleTracerBase::SetToExtraPointDataArrays ( vtkIdType  ,
Definition at line 544 of file vtkLegacyParticleTracerBase.h.
◆ GetInterpolator()
vtkTemporalInterpolatedVelocityField* vtkLegacyParticleTracerBase::GetInterpolator ( )
◆ AddRestartSeeds()
virtual void vtkLegacyParticleTracerBase::AddRestartSeeds ( vtkInformationVector **  )
Definition at line 555 of file vtkLegacyParticleTracerBase.h.
◆ RenameGhostArray()
virtual void vtkLegacyParticleTracerBase::RenameGhostArray ( vtkPointData *  pd)
protectedvirtual
◆ vtkLegacyParticleTracerBaseNamespace::ParticleTracerFunctor
friend struct vtkLegacyParticleTracerBaseNamespace::ParticleTracerFunctor
friend
Definition at line 96 of file vtkLegacyParticleTracerBase.h.
◆ vtkLegacyPParticlePathFilter
friend class vtkLegacyPParticlePathFilter
friend
Definition at line 661 of file vtkLegacyParticleTracerBase.h.
◆ Output
vtkSmartPointer<vtkPolyData> vtkLegacyParticleTracerBase::Output
Definition at line 342 of file vtkLegacyParticleTracerBase.h.
◆ ProtoPD
vtkSmartPointer<vtkPointData> vtkLegacyParticleTracerBase::ProtoPD
Definition at line 351 of file vtkLegacyParticleTracerBase.h.
◆ UniqueIdCounter
vtkIdType vtkLegacyParticleTracerBase::UniqueIdCounter
Definition at line 352 of file vtkLegacyParticleTracerBase.h.
◆ ParticleHistories
vtkLegacyParticleTracerBaseNamespace::ParticleDataList vtkLegacyParticleTracerBase::ParticleHistories
Definition at line 353 of file vtkLegacyParticleTracerBase.h.
◆ ParticlePointData
vtkSmartPointer<vtkPointData> vtkLegacyParticleTracerBase::ParticlePointData
Definition at line 354 of file vtkLegacyParticleTracerBase.h.
vtkTypeBool vtkLegacyParticleTracerBase::IgnorePipelineTime
Definition at line 357 of file vtkLegacyParticleTracerBase.h.
◆ DisableResetCache
vtkTypeBool vtkLegacyParticleTracerBase::DisableResetCache
Definition at line 358 of file vtkLegacyParticleTracerBase.h.
bool vtkLegacyParticleTracerBase::ForceSerialExecution
Definition at line 362 of file vtkLegacyParticleTracerBase.h.
