An In Situ Particle tracer for unsteady vector fields. More...
#include <vtkInSituPParticlePathFilter.h>
| typedef vtkLegacyPParticlePathFilter | Superclass |
Public Types inherited from vtkLegacyPParticlePathFilter | |
| typedef vtkLegacyPParticleTracerBase | Superclass |
Public Types inherited from vtkLegacyPParticleTracerBase | |
| typedef vtkLegacyParticleTracerBase | Superclass |
Public Types inherited from vtkLegacyParticleTracerBase | |
| enum | Solvers { RUNGE_KUTTA2, RUNGE_KUTTA4, RUNGE_KUTTA45, NONE, UNKNOWN } |
| enum | MeshOverTimeTypes { DIFFERENT = 0, STATIC = 1, LINEAR_TRANSFORMATION = 2, SAME_TOPOLOGY = 3 } |
| Types of Variance of Mesh over time. More... | |
| enum | { INTERPOLATOR_WITH_DATASET_POINT_LOCATOR, INTERPOLATOR_WITH_CELL_LOCATOR } |
| typedef vtkPolyDataAlgorithm | Superclass |
Public Types inherited from vtkPolyDataAlgorithm | |
| typedef vtkAlgorithm | Superclass |
Public Types inherited from vtkAlgorithm | |
| enum | DesiredOutputPrecision |
| void | SetClearCache (bool) |
| Set whether or not to clear out cache of previous time steps. More... | |
| void | AddRestartConnection (vtkAlgorithmOutput *input) |
| Provide support pre-pending previously computed particle paths. More... | |
| void | RemoveAllRestarts () |
| virtual void | SetRestartedSimulation (bool) |
| Set/Get if the simulation has been restarted. More... | |
| virtual bool | GetRestartedSimulation () |
| virtual void | SetFirstTimeStep (int) |
| Specify the first time step that particle paths are computed. More... | |
| virtual int | GetFirstTimeStep () |
Public Member Functions inherited from vtkLegacyPParticlePathFilter | |
Public Member Functions inherited from vtkLegacyPParticleTracerBase | |
| virtual void | SetController (vtkMultiProcessController *controller) |
| Set/Get the controller used when sending particles between processes The controller must be an instance of vtkMPIController. More... | |
| virtual vtkMultiProcessController * | GetController () |
Public Member Functions inherited from vtkLegacyParticleTracerBase | |
| void | PrintParticleHistories () |
| void | SetIntegrator (vtkInitialValueProblemSolver *) |
| virtual vtkInitialValueProblemSolver * | GetIntegrator () |
| void | SetIntegratorType (int type) |
| int | GetIntegratorType () |
| void | SetInterpolatorType (int interpolatorType) |
| Set the type of the velocity field interpolator to determine whether INTERPOLATOR_WITH_DATASET_POINT_LOCATOR or INTERPOLATOR_WITH_CELL_LOCATOR is employed for locating cells during streamline integration. More... | |
| void | SetInterpolatorTypeToDataSetPointLocator () |
| Set the velocity field interpolator type to one that uses a point locator to perform local spatial searching. More... | |
| void | SetInterpolatorTypeToCellLocator () |
| Set the velocity field interpolator type to one that uses a cell locator to perform spatial searching. More... | |
| virtual bool | GetComputeVorticity () |
| Turn on/off vorticity computation at streamline points (necessary for generating proper stream-ribbons using the vtkRibbonFilter. More... | |
| void | SetComputeVorticity (bool) |
| virtual double | GetTerminalSpeed () |
| Specify the terminal speed value, below which integration is terminated. More... | |
| void | SetTerminalSpeed (double) |
| virtual double | GetRotationScale () |
| This can be used to scale the rate with which the streamribbons twist. More... | |
| void | SetRotationScale (double) |
| virtual void | SetIgnorePipelineTime (vtkTypeBool) |
| To get around problems with the Paraview Animation controls we can just animate the time step and ignore the TIME_ requests. More... | |
| virtual vtkTypeBool | GetIgnorePipelineTime () |
| virtual void | IgnorePipelineTimeOn () |
| virtual void | IgnorePipelineTimeOff () |
| virtual int | GetForceReinjectionEveryNSteps () |
| When animating particles, it is nice to inject new ones every Nth step to produce a continuous flow. More... | |
| void | SetForceReinjectionEveryNSteps (int) |
| void | SetTerminationTime (double t) |
| Setting TerminationTime to a positive value will cause particles to terminate when the time is reached. More... | |
| virtual double | GetTerminationTime () |
| virtual double | GetStartTime () |
| Set the time value for particle tracing to begin. More... | |
| void | SetStartTime (double t) |
| virtual void | SetStaticSeeds (vtkTypeBool) |
| if StaticSeeds is set and the mesh is static, then every time particles are injected we can re-use the same injection information. More... | |
| virtual vtkTypeBool | GetStaticSeeds () |
| virtual void | SetMeshOverTime (int meshOverTime) |
| virtual int | GetMeshOverTimeMinValue () |
| virtual int | GetMeshOverTimeMaxValue () |
| void | SetMeshOverTimeToDifferent () |
| void | SetMeshOverTimeToStatic () |
| void | SetMeshOverTimeToLinearTransformation () |
| void | SetMeshOverTimeToSameTopology () |
| virtual int | GetMeshOverTime () |
| virtual void | SetStaticMesh (vtkTypeBool staticMesh) |
| if StaticMesh is set, many optimizations for cell caching can be assumed. More... | |
| virtual vtkTypeBool | GetStaticMesh () |
| virtual void | SetParticleWriter (vtkAbstractParticleWriter *pw) |
| Set/Get the Writer associated with this Particle Tracer Ideally a parallel IO capable vtkH5PartWriter should be used which will collect particles from all parallel processes and write them to a single HDF5 file. More... | |
| virtual vtkAbstractParticleWriter * | GetParticleWriter () |
| vtkSetFilePathMacro (ParticleFileName) | |
| Set/Get the filename to be used with the particle writer when dumping particles to disk. More... | |
| vtkGetFilePathMacro (ParticleFileName) | |
| virtual void | SetEnableParticleWriting (vtkTypeBool) |
| virtual vtkTypeBool | GetEnableParticleWriting () |
| virtual void | EnableParticleWritingOn () |
| virtual void | EnableParticleWritingOff () |
| virtual void | SetDisableResetCache (vtkTypeBool) |
| Set/Get the flag to disable cache This is off by default and turned on in special circumstances such as in a coprocessing workflow. More... | |
| virtual vtkTypeBool | GetDisableResetCache () |
| virtual void | DisableResetCacheOn () |
| virtual void | DisableResetCacheOff () |
| void | AddSourceConnection (vtkAlgorithmOutput *input) |
| Provide support for multiple seed sources. More... | |
| void | RemoveAllSources () |
| virtual bool | GetForceSerialExecution () |
| Force the filter to run particle tracer in serial. More... | |
| virtual void | SetForceSerialExecution (bool) |
| virtual void | ForceSerialExecutionOn () |
| virtual void | ForceSerialExecutionOff () |
Public Member Functions inherited from vtkPolyDataAlgorithm | |
| vtkPolyDataAlgorithm * | NewInstance () const |
| vtkPolyData * | GetPolyDataInput (int port) |
| vtkPolyData * | GetOutput () |
| vtkPolyData * | GetOutput (int) |
Public Member Functions inherited from vtkAlgorithm | |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
Public Attributes inherited from vtkAlgorithm | |
| SINGLE_PRECISION | |
| DOUBLE_PRECISION | |
| DEFAULT_PRECISION | |
| int | AbortExecute |
Protected Types inherited from vtkLegacyPParticleTracerBase | |
| typedef std::vector< RemoteParticleInfo > | RemoteParticleVector |
Static Protected Member Functions inherited from vtkAlgorithm | |
| static vtkInformationIntegerKey * | PORT_REQUIREMENTS_FILLED () |
Protected Attributes inherited from vtkLegacyPParticlePathFilter | |
| ParticlePathFilterInternal | It |
| vtkDoubleArray * | SimulationTime |
| vtkIntArray * | SimulationTimeStep |
Protected Attributes inherited from vtkLegacyPParticleTracerBase | |
| vtkMultiProcessController * | Controller |
| RemoteParticleVector | MPISendList |
| RemoteParticleVector | Tail |
Protected Attributes inherited from vtkLegacyParticleTracerBase | |
| vtkSmartPointer< vtkPolyData > | Output |
| bool | ForceSerialExecution |
| vtkSmartPointer< vtkPointData > | ProtoPD |
| ProtoPD is used just to keep track of the input array names and number of components for copy allocating from other vtkPointDatas where the data is really stored. More... | |
| vtkIdType | UniqueIdCounter |
| vtkLegacyParticleTracerBaseNamespace::ParticleDataList | ParticleHistories |
| vtkSmartPointer< vtkPointData > | ParticlePointData |
| vtkTypeBool | IgnorePipelineTime |
| vtkTypeBool | DisableResetCache |
Protected Attributes inherited from vtkAlgorithm | |
| vtkInformation * | Information |
| double | Progress |
| char * | ProgressText |
| vtkProgressObserver * | ProgressObserver |
| unsigned long | ErrorCode |
Static Protected Attributes inherited from vtkAlgorithm | |
| static vtkExecutive * | DefaultExecutivePrototype |
vtkInSituPParticlePathFilter is a filter that integrates a vector field to generate particle paths. It is intended for in situ use. The additions to the parallel particle path filter is that the particle locations at previous time steps can be cleared out (ClearCache data member) and restarted connection can be used to continue advecting particles from a restarted simulation.
Definition at line 23 of file vtkInSituPParticlePathFilter.h.
Definition at line 27 of file vtkInSituPParticlePathFilter.h.
Reimplemented from vtkLegacyPParticlePathFilter.
Reimplemented from vtkPolyDataAlgorithm.
| void vtkInSituPParticlePathFilter::SetClearCache | ( | bool | ) |
Default value is false. Clearing the cache is aimed towards in situ use.
| void vtkInSituPParticlePathFilter::AddRestartConnection | ( | vtkAlgorithmOutput * | input | ) |
| void vtkInSituPParticlePathFilter::RemoveAllRestarts | ( | ) |
If it is a restarted simulation we may not necessarily want to inject/reinject particles on the first time step. The default is False.
This is useful for restarted simulations or when the simulation's first time step isn't 0. The default is 0.
overrideprotectedvirtual |
Overriding this method allows us to inject the seeds as some point other than the first time step.
This is needed for restarted simulations where the restart step may not coincide with an injection step. Even if it did, the seeds probably were already reinjected before the restart files were written.
Reimplemented from vtkLegacyParticleTracerBase.
We add in a third, optional port for adding in particles for a restarted simulation.
These particles are only added at the first time step.
For restarts of particle paths, we add in the ability to add in particles from a previous computation that we will still advect.
Before starting the particle trace, classify all the injection/seed points according to which processor they belong to.
This saves us retesting at every injection time providing 1) The volumes are static, 2) the seed points are static If either are non static, then this step is skipped. This takes into account that the "seeds" may just be restarted particles.
