Classes | Public Types | Public Member Functions | Static Public Member Functions | Protected Types | Protected Member Functions | Protected Attributes | List of all members
vtkLegacyPParticleTracerBase Class Reference
#include <vtkLegacyPParticleTracerBase.h>
Inheritance diagram for vtkLegacyPParticleTracerBase:
Collaboration diagram for vtkLegacyPParticleTracerBase:
struct  RemoteParticleInfo
typedef vtkLegacyParticleTracerBase Superclass
- Public Types inherited from vtkLegacyParticleTracerBase
enum  Solvers {
  RUNGE_KUTTA2, RUNGE_KUTTA4, RUNGE_KUTTA45, NONE,
  UNKNOWN
enum  MeshOverTimeTypes { DIFFERENT = 0, STATIC = 1, LINEAR_TRANSFORMATION = 2, SAME_TOPOLOGY = 3 }
 Types of Variance of Mesh over time. More...
enum  { INTERPOLATOR_WITH_DATASET_POINT_LOCATOR, INTERPOLATOR_WITH_CELL_LOCATOR }
typedef vtkPolyDataAlgorithm Superclass
- Public Types inherited from vtkPolyDataAlgorithm
enum  DesiredOutputPrecision
virtual void SetController (vtkMultiProcessController *controller)
 Set/Get the controller used when sending particles between processes The controller must be an instance of vtkMPIController. More...
- Public Member Functions inherited from vtkLegacyParticleTracerBase
void PrintParticleHistories ()
void SetIntegrator (vtkInitialValueProblemSolver *)
virtual vtkInitialValueProblemSolver * GetIntegrator ()
void SetIntegratorType (int type)
int GetIntegratorType ()
void SetInterpolatorType (int interpolatorType)
 Set the type of the velocity field interpolator to determine whether INTERPOLATOR_WITH_DATASET_POINT_LOCATOR or INTERPOLATOR_WITH_CELL_LOCATOR is employed for locating cells during streamline integration. More...
void SetInterpolatorTypeToDataSetPointLocator ()
 Set the velocity field interpolator type to one that uses a point locator to perform local spatial searching. More...
void SetInterpolatorTypeToCellLocator ()
 Set the velocity field interpolator type to one that uses a cell locator to perform spatial searching. More...
virtual bool GetComputeVorticity ()
 Turn on/off vorticity computation at streamline points (necessary for generating proper stream-ribbons using the vtkRibbonFilter. More...
void SetComputeVorticity (bool)
virtual double GetTerminalSpeed ()
 Specify the terminal speed value, below which integration is terminated. More...
void SetTerminalSpeed (double)
virtual double GetRotationScale ()
 This can be used to scale the rate with which the streamribbons twist. More...
void SetRotationScale (double)
virtual void SetIgnorePipelineTime (vtkTypeBool)
 To get around problems with the Paraview Animation controls we can just animate the time step and ignore the TIME_ requests. More...
virtual vtkTypeBool GetIgnorePipelineTime ()
virtual void IgnorePipelineTimeOn ()
virtual void IgnorePipelineTimeOff ()
virtual int GetForceReinjectionEveryNSteps ()
 When animating particles, it is nice to inject new ones every Nth step to produce a continuous flow. More...
void SetForceReinjectionEveryNSteps (int)
void SetTerminationTime (double t)
 Setting TerminationTime to a positive value will cause particles to terminate when the time is reached. More...
virtual double GetTerminationTime ()
virtual double GetStartTime ()
 Set the time value for particle tracing to begin. More...
void SetStartTime (double t)
virtual void SetStaticSeeds (vtkTypeBool)
 if StaticSeeds is set and the mesh is static, then every time particles are injected we can re-use the same injection information. More...
virtual vtkTypeBool GetStaticSeeds ()
virtual void SetMeshOverTime (int meshOverTime)
virtual int GetMeshOverTimeMinValue ()
virtual int GetMeshOverTimeMaxValue ()
void SetMeshOverTimeToDifferent ()
void SetMeshOverTimeToStatic ()
void SetMeshOverTimeToLinearTransformation ()
void SetMeshOverTimeToSameTopology ()
virtual int GetMeshOverTime ()
virtual void SetStaticMesh (vtkTypeBool staticMesh)
 if StaticMesh is set, many optimizations for cell caching can be assumed. More...
virtual vtkTypeBool GetStaticMesh ()
virtual void SetParticleWriter (vtkAbstractParticleWriter *pw)
 Set/Get the Writer associated with this Particle Tracer Ideally a parallel IO capable vtkH5PartWriter should be used which will collect particles from all parallel processes and write them to a single HDF5 file. More...
virtual vtkAbstractParticleWriter * GetParticleWriter ()
 vtkSetFilePathMacro (ParticleFileName)
 Set/Get the filename to be used with the particle writer when dumping particles to disk. More...
 vtkGetFilePathMacro (ParticleFileName)
virtual void SetEnableParticleWriting (vtkTypeBool)
virtual vtkTypeBool GetEnableParticleWriting ()
virtual void EnableParticleWritingOn ()
virtual void EnableParticleWritingOff ()
virtual void SetDisableResetCache (vtkTypeBool)
 Set/Get the flag to disable cache This is off by default and turned on in special circumstances such as in a coprocessing workflow. More...
virtual vtkTypeBool GetDisableResetCache ()
virtual void DisableResetCacheOn ()
virtual void DisableResetCacheOff ()
void AddSourceConnection (vtkAlgorithmOutput *input)
 Provide support for multiple seed sources. More...
void RemoveAllSources ()
virtual bool GetForceSerialExecution ()
 Force the filter to run particle tracer in serial. More...
virtual void SetForceSerialExecution (bool)
virtual void ForceSerialExecutionOn ()
virtual void ForceSerialExecutionOff ()
- Public Member Functions inherited from vtkPolyDataAlgorithm
vtkPolyDataAlgorithm * NewInstance () const
vtkDataObject * GetInput ()
vtkPolyData * GetPolyDataInput (int port)
vtkPolyData * GetOutput ()
vtkPolyData * GetOutput (int)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkLegacyPParticleTracerBase * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkLegacyParticleTracerBase
static vtkLegacyParticleTracerBase * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPolyDataAlgorithm
static vtkPolyDataAlgorithm * New ()
static vtkPolyDataAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
Protected Types
typedef std::vector< RemoteParticleInfo > RemoteParticleVector
 vtkLegacyPParticleTracerBase ()
 ~vtkLegacyPParticleTracerBase () override
vtkPolyData * Execute (vtkInformationVector **inputVector) override
bool SendParticleToAnotherProcess (vtkLegacyParticleTracerBaseNamespace::ParticleInformation &info, vtkLegacyParticleTracerBaseNamespace::ParticleInformation &previous, vtkPointData *) override
void AssignSeedsToProcessors (double time, vtkDataSet *source, int sourceID, int ptId, vtkLegacyParticleTracerBaseNamespace::ParticleVector &localSeedPoints, int &localAssignedCount) override
 Before starting the particle trace, classify all the injection/seed points according to which processor they belong to. More...
void AssignUniqueIds (vtkLegacyParticleTracerBaseNamespace::ParticleVector &localSeedPoints) override
 give each one a unique ID. More...
bool SendReceiveParticles (RemoteParticleVector &outofdomain, RemoteParticleVector &received)
 this is used during classification of seed points and also between iterations of the main loop as particles leave each processor domain. More...
bool UpdateParticleListFromOtherProcesses () override
bool IsPointDataValid (vtkDataObject *input) override
 Method that checks that the input arrays are ordered the same on all data sets. More...
- Protected Member Functions inherited from vtkLegacyParticleTracerBase
 vtkLegacyParticleTracerBase ()
 ~vtkLegacyParticleTracerBase () override
vtkTypeBool ProcessRequest (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
int RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
virtual int ProcessInput (vtkInformationVector **inputVector)
virtual void Initialize ()
virtual int OutputParticles (vtkPolyData *poly)=0
virtual void Finalize ()
virtual std::vector< vtkDataSet * > GetSeedSources (vtkInformationVector *inputVector, int timeStep)
 Method to get the data set seed sources. More...
int InitializeInterpolator ()
int UpdateDataCache (vtkDataObject *td)
void TestParticles (vtkLegacyParticleTracerBaseNamespace::ParticleVector &candidates, vtkLegacyParticleTracerBaseNamespace::ParticleVector &passed, int &count)
 inside our data. More...
void TestParticles (vtkLegacyParticleTracerBaseNamespace::ParticleVector &candidates, std::vector< int > &passed)
void UpdateParticleList (vtkLegacyParticleTracerBaseNamespace::ParticleVector &candidates)
 and sending between processors, into a list, which is used as the master list on this processor More...
void IntegrateParticle (vtkLegacyParticleTracerBaseNamespace::ParticleListIterator &it, double currentTime, double targetTime, vtkInitialValueProblemSolver *integrator, vtkTemporalInterpolatedVelocityField *interpolator, vtkDoubleArray *cellVectors, std::atomic< vtkIdType > &particleCount, std::mutex &eraseMutex, bool sequential)
 particle between the two times supplied. More...
bool ComputeDomainExitLocation (double pos[4], double p2[4], double intersection[4], vtkGenericCell *cell)
 This is an old routine kept for possible future use. More...
void CreateProtoPD (vtkDataObject *input)
vtkFloatArray * GetParticleAge (vtkPointData *)
vtkIntArray * GetParticleIds (vtkPointData *)
vtkSignedCharArray * GetParticleSourceIds (vtkPointData *)
vtkIntArray * GetInjectedPointIds (vtkPointData *)
vtkIntArray * GetInjectedStepIds (vtkPointData *)
vtkIntArray * GetErrorCodeArr (vtkPointData *)
vtkFloatArray * GetParticleVorticity (vtkPointData *)
vtkFloatArray * GetParticleRotation (vtkPointData *)
vtkFloatArray * GetParticleAngularVel (vtkPointData *)
bool InsideBounds (double point[])
void CalculateVorticity (vtkGenericCell *cell, double pcoords[3], vtkDoubleArray *cellVectors, double vorticity[3])
double GetCacheDataTime (int i)
double GetCacheDataTime ()
virtual void ResetCache ()
void SetParticle (vtkLegacyParticleTracerBaseNamespace::ParticleInformation &info, double *velocity, vtkTemporalInterpolatedVelocityField *interpolator, vtkIdType particleId, vtkDoubleArray *cellVectors)
virtual int GetReinjectionCounter ()
virtual double GetCurrentTimeValue ()
void ResizeArrays (vtkIdType numTuples)
virtual void InitializeExtraPointDataArrays (vtkPointData *vtkNotUsed(outputPD))
 Methods to append values to existing point data arrays that may only be desired on specific concrete derived classes. More...
virtual void SetToExtraPointDataArrays (vtkIdType, vtkLegacyParticleTracerBaseNamespace::ParticleInformation &)
vtkTemporalInterpolatedVelocityField * GetInterpolator ()
virtual void AddRestartSeeds (vtkInformationVector **)
 For restarts of particle paths, we add in the ability to add in particles from a previous computation that we will still advect. More...
virtual void RenameGhostArray (vtkPointData *pd)
 Recover the ghost array in provided point data and rename it by adding "Original_" in front of it, if available. More...
bool IsPointDataValid (vtkCompositeDataSet *input, std::vector< std::string > &arrayNames)
 Methods that check that the input arrays are ordered the same on all data sets. More...
void GetPointDataArrayNames (vtkDataSet *input, std::vector< std::string > &names)
- Protected Member Functions inherited from vtkPolyDataAlgorithm
 vtkPolyDataAlgorithm ()
 ~vtkPolyDataAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
RemoteParticleVector MPISendList
RemoteParticleVector Tail
- Protected Attributes inherited from vtkLegacyParticleTracerBase
vtkSmartPointer< vtkPolyData > Output
bool ForceSerialExecution
vtkSmartPointer< vtkPointData > ProtoPD
 ProtoPD is used just to keep track of the input array names and number of components for copy allocating from other vtkPointDatas where the data is really stored. More...
vtkIdType UniqueIdCounter
vtkLegacyParticleTracerBaseNamespace::ParticleDataList ParticleHistories
vtkSmartPointer< vtkPointData > ParticlePointData
vtkTypeBool IgnorePipelineTime
vtkTypeBool DisableResetCache
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
Definition at line 25 of file vtkLegacyPParticleTracerBase.h.
Definition at line 29 of file vtkLegacyPParticleTracerBase.h.
◆ RemoteParticleVector
Definition at line 49 of file vtkLegacyPParticleTracerBase.h.
◆ vtkLegacyPParticleTracerBase()
vtkLegacyPParticleTracerBase::vtkLegacyPParticleTracerBase ( )
◆ ~vtkLegacyPParticleTracerBase()
vtkLegacyPParticleTracerBase::~vtkLegacyPParticleTracerBase ( )
virtual const char* vtkLegacyPParticleTracerBase::GetClassName ( )
static int vtkLegacyPParticleTracerBase::IsTypeOf ( const char *  type)
virtual int vtkLegacyPParticleTracerBase::IsA ( const char *  type)
static vtkLegacyPParticleTracerBase* vtkLegacyPParticleTracerBase::SafeDownCast ( vtkObject *  o)
void vtkLegacyPParticleTracerBase::PrintSelf ( ostream &  os,
Reimplemented from vtkLegacyParticleTracerBase.
◆ SetController()
virtual void vtkLegacyPParticleTracerBase::SetController ( vtkMultiProcessController *  controller)
◆ GetController()
virtual vtkMultiProcessController* vtkLegacyPParticleTracerBase::GetController ( )
◆ RequestUpdateExtent()
int vtkLegacyPParticleTracerBase::RequestUpdateExtent ( vtkInformation *  request,
overrideprotectedvirtual
◆ Execute()
vtkPolyData* vtkLegacyPParticleTracerBase::Execute ( vtkInformationVector **  inputVector)
◆ SendParticleToAnotherProcess()
bool vtkLegacyPParticleTracerBase::SendParticleToAnotherProcess ( vtkLegacyParticleTracerBaseNamespace::ParticleInformation &  info,
vtkLegacyParticleTracerBaseNamespace::ParticleInformation &  previous,
vtkPointData *
◆ AssignSeedsToProcessors()
void vtkLegacyPParticleTracerBase::AssignSeedsToProcessors ( double  time,
vtkDataSet *  source,
int  sourceID,
int  ptId,
vtkLegacyParticleTracerBaseNamespace::ParticleVector &  localSeedPoints,
int &  localAssignedCount
This saves us retesting at every injection time providing 1) The volumes are static, 2) the seed points are static If either are non static, then this step is skipped.
◆ AssignUniqueIds()
void vtkLegacyPParticleTracerBase::AssignUniqueIds ( vtkLegacyParticleTracerBaseNamespace::ParticleVector &  localSeedPoints)
We need to use MPI to find out who is using which numbers.
◆ SendReceiveParticles()
bool vtkLegacyPParticleTracerBase::SendReceiveParticles ( RemoteParticleVector &  outofdomain,
RemoteParticleVector &  received
Returns true if particles were migrated to any new process.
◆ UpdateParticleListFromOtherProcesses()
bool vtkLegacyPParticleTracerBase::UpdateParticleListFromOtherProcesses ( )
Returns true if particles moved between processes and false otherwise.
◆ IsPointDataValid()
bool vtkLegacyPParticleTracerBase::IsPointDataValid ( vtkDataObject *  input)
This needs to be true for all blocks in a composite data set as well as across all processes.
◆ Controller
vtkMultiProcessController* vtkLegacyPParticleTracerBase::Controller
Definition at line 102 of file vtkLegacyPParticleTracerBase.h.
◆ MPISendList
RemoteParticleVector vtkLegacyPParticleTracerBase::MPISendList
Definition at line 105 of file vtkLegacyPParticleTracerBase.h.
◆ Tail
RemoteParticleVector vtkLegacyPParticleTracerBase::Tail
Definition at line 107 of file vtkLegacyPParticleTracerBase.h.
