1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core
40 # Set path to fallback-tool for dependency-resolution.
42  set(CMAKE_OBJDUMP "/usr/sbin/objdump")
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkPVVTKExtensionsCore-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkPVVTKExtensionsCore-hierarchy.txt")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime" OR NOT CMAKE_INSTALL_COMPONENT)
50  foreach(file
51  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv6.2.so.6.2"
52  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv6.2.so.1"
53  )
54  if(EXISTS "${file}" AND
55  NOT IS_SYMLINK "${file}")
56  file(RPATH_CHECK
57  FILE "${file}"
58  RPATH "\$ORIGIN")
59  endif()
60  endforeach()
61  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
62  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsCore-pv6.2.so.6.2"
63  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsCore-pv6.2.so.1"
64  )
65  foreach(file
66  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv6.2.so.6.2"
67  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv6.2.so.1"
68  )
69  if(EXISTS "${file}" AND
70  NOT IS_SYMLINK "${file}")
71  file(RPATH_CHANGE
72  FILE "${file}"
73  OLD_RPATH "\$ORIGIN:"
74  NEW_RPATH "\$ORIGIN")
75  if(CMAKE_INSTALL_DO_STRIP)
76  execute_process(COMMAND "/usr/sbin/strip" "${file}")
77  endif()
78  endif()
79  endforeach()
80 endif()
81
83  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsCore-pv6.2.so")
84 endif()
85
86 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
87 endif()
88
89 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2" TYPE FILE FILES
91  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkMemberFunctionCommand.h"
92  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkCLIOptions.h"
93  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkCommunicationErrorCatcher.h"
94  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkDistributedTrivialProducer.h"
95  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkEmulatedTimeAlgorithm.h"
96  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkFileSequenceParser.h"
97  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkLogRecorder.h"
98  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVCellCenters.h"
99  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVCompositeDataPipeline.h"
100  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVDataUtilities.h"
101  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVFeatureEdges.h"
102  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVInformationKeys.h"
103  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVLogger.h"
104  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVNullSource.h"
105  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVPostFilter.h"
106  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVPostFilterExecutive.h"
107  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVTestUtilities.h"
108  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVTrivialProducer.h"
109  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVXMLElement.h"
110  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVXMLParser.h"
111  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkStringList.h"
112  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkUndoElement.h"
113  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkUndoSet.h"
114  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkUndoStack.h"
115  )
116 endif()
117
118 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
119  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2" TYPE FILE FILES
120  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVStringFormatter.h"
121  "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/Core/vtkPVVTKExtensionsCoreModule.h"
122  )
123 endif()
124
125 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
126  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/Core/vtkPVVTKExtensionsCore.spdx")
127 endif()
128
129 string(REPLACE ";" "\n" CMAKE_INSTALL_MANIFEST_CONTENT
130  "${CMAKE_INSTALL_MANIFEST_FILES}")
131 if(CMAKE_INSTALL_LOCAL_ONLY)
132  file(WRITE "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/Core/install_local_manifest.txt"
133  "${CMAKE_INSTALL_MANIFEST_CONTENT}")
134 endif()
unit undo-redo-able operation.
Executive supporting post filters.
helper class to catch errors from vtkMultiProcessController and vtkCommunicator.
Post Filter for on demand conversion.
undo/redo stack.
Definition: vtkUndoStack.h:35
defines various logging categories for ParaView
Definition: vtkPVLogger.h:40
Feature Edges filter that delegates to type specific implementations.
Provide a base API for a emulated real time LiveSource.
Parses out the base file name of a file sequence and also the specific index of the given file...
command line options manager
Definition: vtkCLIOptions.h:46
source for NULL data.
data utility functions
specialized subclass of vtkTrivialProducer that preserves the information about the whole extent of t...
Maintains a collection of vtkUndoElement that can be undone/redone in a single step.
Definition: vtkUndoSet.h:30
Utility class used for string formatting.
A class to facilitate common test operations.
Record log messages at or below a given verbosity on a particular ParaView process/rank.
executive to add support for vtkPVPostFilter in ParaView data pipelines.
This is a subclass of vtkXMLParser that constructs a representation of parsed XML using vtkPVXMLEleme...
Call a class member method in response to a VTK event.
Cell centers filter that delegates to typen specific implementations.
Extend vtkPVTrivialProducer to allow distributed code to easily populate a trivial producer with loca...
Manages allocation and freeing for a string list.
Definition: vtkStringList.h:20
