Parses out the base file name of a file sequence and also the specific index of the given file. More...
#include <vtkFileSequenceParser.h>
| bool | ParseFileSequence (const char *file) |
| Extract base file name sequence from the file. More... | |
| virtual char * | GetSequenceName () |
| Getter to use to get the sequence name after calling ParseFileSequence. More... | |
| virtual int | GetSequenceIndex () |
| Getter to use to get the sequence index after calling ParseFileSequence. More... | |
| virtual std::string | GetSequenceIndexString () |
| Getter to use to get the sequence index string after calling ParseFileSequence. More... | |
| static vtkFileSequenceParser * | New () |
| static vtkFileSequenceParser * | SafeDownCast (vtkObject *o) |
| vtkFileSequenceParser () | |
| ~vtkFileSequenceParser () override | |
| virtual void | SetSequenceName (const char *) |
Protected Attributes | |
| std::unique_ptr< vtksys::RegularExpression > | reg_ex |
| std::unique_ptr< vtksys::RegularExpression > | reg_ex2 |
| std::unique_ptr< vtksys::RegularExpression > | reg_ex3 |
| std::unique_ptr< vtksys::RegularExpression > | reg_ex4 |
| std::unique_ptr< vtksys::RegularExpression > | reg_ex5 |
| std::unique_ptr< vtksys::RegularExpression > | reg_ex6 |
| std::unique_ptr< vtksys::RegularExpression > | reg_ex_last |
| int | SequenceIndex |
| char * | SequenceName |
| std::string | SequenceIndexString |
Given a file name (without path). I will extract the base portion of the file name that is common to all the files in the sequence. It will also provide the current sequence index of the provided file name. by several vtkPVUpdateSuppressor objects.
Definition at line 29 of file vtkFileSequenceParser.h.
Definition at line 33 of file vtkFileSequenceParser.h.
| bool vtkFileSequenceParser::ParseFileSequence | ( | const char * | file | ) |
Returns true if a sequence is detected and sets SequenceName and SequenceIndex.
It can be useful when sequence index is duplicated.
protectedvirtual |
Definition at line 66 of file vtkFileSequenceParser.h.
Definition at line 67 of file vtkFileSequenceParser.h.
Definition at line 68 of file vtkFileSequenceParser.h.
Definition at line 69 of file vtkFileSequenceParser.h.
Definition at line 70 of file vtkFileSequenceParser.h.
Definition at line 71 of file vtkFileSequenceParser.h.
Definition at line 72 of file vtkFileSequenceParser.h.
Definition at line 75 of file vtkFileSequenceParser.h.
Definition at line 78 of file vtkFileSequenceParser.h.
Definition at line 79 of file vtkFileSequenceParser.h.
1.8.13 on Sat Oct 10 2026
