| virtual void | UpdateFromGlobal (const char *key) |
| | Update the current instance to use a previously registered global data object as current output. More...
| void | SetOutput (vtkDataObject *output) override |
| | Set the data object that is "produced" by this producer. More...
| virtual void | SetOutput (vtkDataObject *output, double time) |
| | Set the output data object as well as time information for the requests. More...
| int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| | Process upstream/downstream requests trivially. More...
| vtkTrivialProducer * | NewInstance () const |
| virtual void | SetWholeExtent (int, int, int, int, int, int) |
| virtual void | SetWholeExtent (int[6]) |
| virtual int * | GetWholeExtent () |
| virtual void | GetWholeExtent (int &, int &, int &, int &, int &, int &) |
| virtual void | GetWholeExtent (int[6]) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkDistributedTrivialProducer () |
| | ~vtkDistributedTrivialProducer () override |
| | vtkPVTrivialProducer () |
| | ~vtkPVTrivialProducer () override |
| | vtkTrivialProducer () |
| | ~vtkTrivialProducer () |
| virtual int | FillInputPortInformation (int, vtkInformation *) |
| virtual int | FillOutputPortInformation (int, vtkInformation *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
