1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Remoting/Core 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
40 # Set path to fallback-tool for dependency-resolution. 41 if(NOT DEFINED CMAKE_OBJDUMP)
42 set(CMAKE_OBJDUMP
"/usr/sbin/objdump")
46 file(INSTALL DESTINATION
"vtkRemotingCore-hierarchy.txt" FILES
"/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkRemotingCore-hierarchy.txt")
51 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingCore-pv6.2.so.6.2
" 52 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingCore-pv6.2.so.1
" 54 if(EXISTS "${file}
") 58 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
" TYPE SHARED_LIBRARY FILES 62 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingCore-pv6.2.so.6.2
" 63 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingCore-pv6.2.so.1
" 66 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingCore-pv6.2.so.6.2
" 67 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingCore-pv6.2.so.1
" 69 if(EXISTS "${file}
") 73 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 74 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 75 if(CMAKE_INSTALL_DO_STRIP) 76 execute_process(COMMAND "/usr/sbin/strip
" "${file}
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingCore-pv6.2.so
" TYPE FILE FILES 119 "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/
vtkPVPlugin.h
" 129 "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/
vtkPVSession.h
" 140 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 141 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Remoting/Core/vtkRemotingCoreModule.h
") 144 if(CMAKE_INSTALL_COMPONENT STREQUAL "licenses
" OR NOT CMAKE_INSTALL_COMPONENT) 145 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkRemotingCore
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/LICENSE
") 148 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 149 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Remoting/Core/vtkRemotingCore.spdx
") 152 string(REPLACE ";
" "\n
" CMAKE_INSTALL_MANIFEST_CONTENT 153 "${CMAKE_INSTALL_MANIFEST_FILES}
") 154 if(CMAKE_INSTALL_LOCAL_ONLY) 155 file(WRITE "/builds/gitlab-kitware-sciviz-ci/build/Remoting/Core/install_local_manifest.txt
" 156 "${CMAKE_INSTALL_MANIFEST_CONTENT}
When run on the process it enables a stacktrace signal handler for common errors. ...
vtkTCPNetworkAccessManager is a concrete implementation of vtkNetworkAccessManager that uses tcp/ip s...
a global manager for each processes to keep track of plugins loaded on that process.
parallel aware vtkResourceFileLocator
Enum listing custom remote object with dedicated GlobalID.
vtkPVSession defines a session i.e.
Used to load ParaView plugins.
display configuration container
class to create socket connections between two servers
Stores code and option for python modules.
vtkSessionIterator is used to iterate over sessions in the global ProcessModule.
vtkCompositeMultiProcessController offer a composite implementation of vtkMultiProcessController that...
runtime configuration options for vtkRemotingCore module.
runtime configuration for vtkProcessModule
vtkNetworkAccessManager is used to create new connections and monitor activity of those connections...
process initialization and management core for ParaView processes.
vtkPVSessionIterator is used to iterate over sessions in the global ProcessModule.
