| 0009702 | ParaView | Bug | public | 2009-10-12 20:15 | 2010-03-09 21:27 | ||||
| Priority | immediate | Severity | minor | Reproducibility | always | ||||
| Product Version | |||||||||
| Target Version | 3.8 | Fixed in Version | 3.8 | ||||||
| Summary | 0009702: Python trace error - plot selection | ||||||||
| Description | ParaView 3.6.2, XP, local server. * open can.exo, all variables on, Apply. * surface with edges. * select a point. * Python shell. Trace. Start Trace. * Plot selection over time. Apply. * Stop Trace. Save Trace. * Delete the plot selection over time filter. Now, run the saved trace. It will really mess up - even trying to open the plot in a 3d window. You also get the following output in the python shell: Traceback (most recent call last): File "<string>", line 12, in <module> File "F:/alan/paraviewWork/3.6.2/bld/ParaView3/Utilities/VTKPythonWrapping/paraview\servermanager.py", line 201, in __setattr__ "to add this attribute.") AttributeError: Attribute XArrayName does not exist. This class does not allow addition of new attributes to avoid mistakes due to typos. Use add_attribute() if you really want to add this attribute. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0019482) Utkarsh Ayachit (administrator) 2010-02-08 15:42 |
Extracting of selection now can be tracked correctly using python. Ensuring that the selection source is registered correctly from python and it's properties are tracked when saving trace. Fixed bug in the GUI where the selection proxy was registered after being set as the input, this was causing the trace is ignore the setting of the selection input. /cvsroot/ParaView3/ParaView3/Utilities/VTKPythonWrapping/paraview/smtrace.py,v <-- Utilities/VTKPythonWrapping/paraview/smtrace.py new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/Utilities/VTKPythonWrapping/paraview/servermanager.py,v <-- Utilities/VTKPythonWrapping/paraview/servermanager.py new revision: 1.72; previous revision: 1.71 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPropertyManager.h,v <-- Qt/Core/pqPropertyManager.h new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPropertyManager.cxx,v <-- Qt/Core/pqPropertyManager.cxx new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionInputWidget.h,v <-- Qt/Components/pqSelectionInputWidget.h new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionInputWidget.cxx,v <-- Qt/Components/pqSelectionInputWidget.cxx new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/pqNamedWidgets.cxx,v <-- Qt/Components/pqNamedWidgets.cxx new revision: 1.58; previous revision: 1.57 |
(0019484) Utkarsh Ayachit (administrator) 2010-02-08 15:55 |
Ensure that the vtkSMFieldDataDomain has valid values by default. This bug was causing run time errors when playing back the trace saved from BUG 0009702 (complaining AttributeType failed to locate "Row Data" as a valid value). Fixed that. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMFieldDataDomain.h,v <-- Servers/ServerManager/vtkSMFieldDataDomain.h new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMFieldDataDomain.cxx,v <-- Servers/ServerManager/vtkSMFieldDataDomain.cxx new revision: 1.12; previous revision: 1.11 |
(0019783) Alan Scott (manager) 2010-03-09 21:27 |
Tested trunk, local server, XP. |
| Notes |
| Issue History | |||
| 2009-10-12 20:15 | Alan Scott | New Issue | |
| 2010-01-21 11:02 | Utkarsh Ayachit | Relationship added | related to 0009829 |
| 2010-02-01 14:26 | Utkarsh Ayachit | Priority | normal => immediate |
| 2010-02-08 15:42 | Utkarsh Ayachit | Note Added: 0019482 | |
| 2010-02-08 15:55 | Utkarsh Ayachit | Note Added: 0019484 | |
| 2010-02-08 15:55 | Utkarsh Ayachit | Status | backlog => @80@ |
| 2010-02-08 15:55 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
| 2010-02-08 15:55 | Utkarsh Ayachit | Resolution | open => fixed |
| 2010-02-08 15:55 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2010-03-09 21:27 | Alan Scott | Note Added: 0019783 | |
| 2010-03-09 21:27 | Alan Scott | Status | @80@ => closed |
| Issue History |
