| 0009829 | ParaView | Bug | public | 2009-11-03 13:12 | 2010-01-21 17:25 | ||||
| Product Version | |||||||||
| Target Version | 3.8 | Fixed in Version | 3.8 | ||||||
| Summary | 0009829: Extract selection - Save State doesn't work | ||||||||
| Description | 1) Add a cone source 2) Use "Select Points Through" to select a point of the cone 3) Apply the ExtractSelection filter. The ExtractSelection1 object now has 1 Point and 1 Cell on the Information tab of the Object Inspector. 4) File->Save State. Save the state as test.pvsm 5) close paraview 6) open paraview 7) load test.pvsm through File->Load State | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0019240) Utkarsh Ayachit (administrator) 2010-01-21 11:06 edited on: 2010-01-21 11:06 |
Fixed pqSelectionInputWidget so that extract selection filters now work well with state saving and undo-redo. The solution was to add a slot to pqSelectionInputWidget to be called on accept(). In this slot, it registers the accepted selection source as well as cleans up any obsolete sources. /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionInputWidget.h,v <-- Qt/Components/pqSelectionInputWidget.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionInputWidget.cxx,v <-- Qt/Components/pqSelectionInputWidget.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqNamedWidgets.cxx,v <-- Qt/Components/pqNamedWidgets.cxx new revision: 1.57; previous revision: 1.56 |
(0019250) Alan Scott (manager) 2010-01-21 17:25 |
Tested local server, XP, trunk. |
| Notes |
| Issue History | |||
| 2009-11-03 13:12 | Utkarsh Ayachit | New Issue | |
| 2010-01-21 11:02 | Utkarsh Ayachit | Relationship added | related to 0009702 |
| 2010-01-21 11:06 | Utkarsh Ayachit | Note Added: 0019240 | |
| 2010-01-21 11:06 | Utkarsh Ayachit | Status | backlog => @80@ |
| 2010-01-21 11:06 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
| 2010-01-21 11:06 | Utkarsh Ayachit | Resolution | open => fixed |
| 2010-01-21 11:06 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2010-01-21 11:06 | Utkarsh Ayachit | Note Edited: 0019240 | |
| 2010-01-21 17:25 | Alan Scott | Note Added: 0019250 | |
| 2010-01-21 17:25 | Alan Scott | Status | @80@ => closed |
| Issue History |
