| 0014287 | ParaView | (No Category) | public | 2013-09-18 15:26 | 2015-01-11 08:23 | ||||
| Reporter | Ken Moreland | ||||||||
| Product Version | git-master | ||||||||
| Target Version | 4.1 | Fixed in Version | 4.1 | ||||||
| Summary | 0014287: Find Data dialog spreadsheet not updated when time changes | ||||||||
| Description | Showing an interactive selection in the Find Data dialog's spreadsheet is awesome. One problem I have found, though, is that the data in the spreadsheet is not properly updated when time changes. To replicate this problem, do the following. 1. Open can.ex2. Load all variables. Apply. 2. Use the Select Cells Through tool to select some cells in the body of the can. 3. Open the Find Data dialog. Dialog is populated with proper data. 4. Play or go to last time step. At this point the data in the Find Data dialog should have a different set of cells selected and, if any are still selected, the EQPS value should be positive. However, the data does not change. Note, though, that if you close the dialog and reopen it, the values get updated. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | 14287_fix_time_and_find_data | ||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0031808) Utkarsh Ayachit (administrator) 2013-11-01 10:58 |
commit 6b000cf18ecfc722ad4336ef6c1f2d68f628b9f2 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Nov 1 10:55:57 2013 -0400 BUG 0014287: Fix find-data not updating with time changes. Ensure that pqFindDataCurrentSelectionFrame updates the spreadsheet whenever the data pipeline is updated for the seleceted port. Also fixed logic in vtkSMProxy which was resulting in duplicate firing of vtkCommand::UpdateDataEvent event if the UpdateDataEvent callback resulted in calls to request further updates to the pipeline e.g. render some other view. Change-Id: I51469a0e81a64a7bd314c90a8c9e0ee97312e32b |
(0031810) Utkarsh Ayachit (administrator) 2013-11-01 13:11 |
SUMMARY --------------------------------------------- Topics merged into master: selection_enhancements pvweb-fix-script-path fix_chart_interactions 14376_fix_settings_dialog 14375-in-situ 14371_fix_color_function_rescale 14287_fix_time_and_find_data --------------------------------------------- Topics reverted from next: paraview-web-client-tests vtkweb-url-arg-parsing *NOTE* these topics were reverted since the referenced VTK topics were not merged in VTK master |
| Notes |
| Issue History | |||
| 2013-09-18 15:26 | Ken Moreland | New Issue | |
| 2013-10-29 17:02 | Ken Moreland | Relationship added | related to 0010962 |
| 2013-10-31 11:12 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2013-10-31 11:13 | Utkarsh Ayachit | Project | TBD => Sandia |
| 2013-10-31 11:13 | Utkarsh Ayachit | Target Version | => 4.1 |
| 2013-11-01 10:58 | Utkarsh Ayachit | Topic Name | => 14287_fix_time_and_find_data |
| 2013-11-01 10:58 | Utkarsh Ayachit | Note Added: 0031808 | |
| 2013-11-01 10:58 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
| 2013-11-01 10:58 | Utkarsh Ayachit | Fixed in Version | => git-next |
| 2013-11-01 10:58 | Utkarsh Ayachit | Resolution | open => fixed |
| 2013-11-01 13:11 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2013-11-01 13:11 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2013-11-01 13:11 | Utkarsh Ayachit | Note Added: 0031810 | |
| 2013-11-01 13:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
| 2013-11-04 13:49 | Ken Moreland | Status | customer review => closed |
| 2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 7ee24278 |
| 2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 6b000cf1 |
| Issue History |
