MantisBT - ParaView
View Issue Details
0014287ParaView(No Category)public2013-09-18 15:262015-01-11 08:23
Ken Moreland
Utkarsh Ayachit
normalminorhave not tried
closedfixed
git-master
4.14.1
Sandia
14287_fix_time_and_find_data
incorrect functionality
0014287: Find Data dialog spreadsheet not updated when time changes
Showing an interactive selection in the Find Data dialog's spreadsheet is awesome. One problem I have found, though, is that the data in the spreadsheet is not properly updated when time changes. To replicate this problem, do the following.
1. Open can.ex2. Load all variables. Apply.
2. Use the Select Cells Through tool to select some cells in the body of the can.
3. Open the Find Data dialog. Dialog is populated with proper data.
4. Play or go to last time step.
At this point the data in the Find Data dialog should have a different set of cells selected and, if any are still selected, the EQPS value should be positive. However, the data does not change. Note, though, that if you close the dialog and reopen it, the values get updated.
No tags attached.
related to 0010962closed Utkarsh Ayachit Find Data dialog should be populated with the current selection
Issue History
2013-09-18 15:26Ken MorelandNew Issue
2013-10-29 17:02Ken MorelandRelationship addedrelated to 0010962
2013-10-31 11:12Utkarsh AyachitAssigned To => Utkarsh Ayachit
2013-10-31 11:13Utkarsh AyachitProjectTBD => Sandia
2013-10-31 11:13Utkarsh AyachitTarget Version => 4.1
2013-11-01 10:58Utkarsh AyachitTopic Name => 14287_fix_time_and_find_data
2013-11-01 10:58Utkarsh AyachitNote Added: 0031808
2013-11-01 10:58Utkarsh AyachitStatusbacklog => gatekeeper review
2013-11-01 10:58Utkarsh AyachitFixed in Version => git-next
2013-11-01 10:58Utkarsh AyachitResolutionopen => fixed
2013-11-01 13:11Utkarsh AyachitFixed in Versiongit-next => git-master
2013-11-01 13:11Utkarsh AyachitStatusgatekeeper review => customer review
2013-11-01 13:11Utkarsh AyachitNote Added: 0031810
2013-11-01 13:17Utkarsh AyachitFixed in Versiongit-master => 4.1
2013-11-04 13:49Ken MorelandStatuscustomer review => closed
2015-01-11 08:23Utkarsh AyachitSource_changeset_attached => ParaView master 7ee24278
2015-01-11 08:23Utkarsh AyachitSource_changeset_attached => ParaView master 6b000cf1
Notes
(0031808)
Utkarsh Ayachit
2013-11-01 10:58
commit 6b000cf18ecfc722ad4336ef6c1f2d68f628b9f2
Date: Fri Nov 1 10:55:57 2013 -0400
    BUG 0014287: Fix find-data not updating with time changes.
    Ensure that pqFindDataCurrentSelectionFrame updates the spreadsheet whenever the
    data pipeline is updated for the seleceted port.
    Also fixed logic in vtkSMProxy which was resulting in duplicate firing of
    vtkCommand::UpdateDataEvent event if the UpdateDataEvent callback resulted in
    calls to request further updates to the pipeline e.g. render some other view.
    Change-Id: I51469a0e81a64a7bd314c90a8c9e0ee97312e32b
(0031810)
Utkarsh Ayachit
2013-11-01 13:11
SUMMARY
Topics merged into master:
  selection_enhancements
  pvweb-fix-script-path
  fix_chart_interactions
  14376_fix_settings_dialog
  14375-in-situ
  14371_fix_color_function_rescale
Topics reverted from next:
  paraview-web-client-tests
  vtkweb-url-arg-parsing
*NOTE* these topics were reverted since the referenced VTK topics were not
merged in VTK master
