| 0010962 | ParaView | Feature | public | 2010-07-08 15:17 | 2013-11-04 13:52 | ||||
| Reporter | Ken Moreland | ||||||||
| Priority | high | Severity | minor | Reproducibility | have not tried | ||||
| Product Version | |||||||||
| Target Version | Fixed in Version | 4.1 | |||||||
| Summary | 0010962: Find Data dialog should be populated with the current selection | ||||||||
| Description | When you first open the Find Data dialog box, it is always blank regardless of what the current selection is. Instead, the dialog should be populated as best as possible with the current selection. At a minimum, the spreadsheet should show the data of the selection and the other buttons (selection color, labels) should reflect the current state of the selection. If the selection also happens to be a query selection, the Find Data should be initialized to have that query filled in. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | 10962_find_data_initialization | ||||||||
| Attached Files | |||||||||
| Relationships | ||||||||||||||||
| Relationships |
| Notes | |
(0029659) Alan Scott (manager) 2012-11-07 21:26 |
Although there are related requests like this, Kens' is the best. Thus, marking it todo. |
(0029660) Alan Scott (manager) 2012-11-07 21:27 |
This really needs to be done. Please make it a priority. |
(0029912) David Thompson (developer) 2012-12-19 13:17 |
The 10962_find_data_initialization branch in git-next now initializes the Find Data dialog; the selection's source is always set to the current selection's source. If there is no selection, the "active" source is used. If the current selection is a query selection (i.e., was created using the Find Data dialog), then the query is parsed and used to initialize the dialog. Otherwise, the dialog selection type (cell/point) and mode (ID, frustum, etc.) take on default values. This has been tested in client/server mode and the FindDataDialog test modified so that it should not pass unless defaults are populated when the dialog is opened. This branch depends upon the seln-inspector-spreadsheet branch, which moves the spreadsheet to the selection inspector (where it is properly updated by each new selection -- as opposed to the Find Data dialog, where it was not). However, according to the comments for issue 10956, this is apparently not its final resting place. |
(0029922) David Thompson (developer) 2012-12-21 09:45 |
Taking out of gatekeeper review so it doesn't get into the 3.98 patch release. |
(0031805) Utkarsh Ayachit (administrator) 2013-10-31 11:12 |
This is now supported in git/master. |
(0031809) Utkarsh Ayachit (administrator) 2013-11-01 13:11 |
SUMMARY --------------------------------------------- Topics merged into master: selection_enhancements pvweb-fix-script-path fix_chart_interactions 14376_fix_settings_dialog 14375-in-situ 14371_fix_color_function_rescale 14287_fix_time_and_find_data --------------------------------------------- Topics reverted from next: paraview-web-client-tests vtkweb-url-arg-parsing *NOTE* these topics were reverted since the referenced VTK topics were not merged in VTK master |
| Notes |
| Issue History | |||
| 2010-07-08 15:17 | Ken Moreland | New Issue | |
| 2010-07-08 15:17 | Ken Moreland | Relationship added | child of 0010627 |
| 2011-02-18 14:46 | Ken Moreland | Relationship added | related to 0009344 |
| 2011-06-16 13:10 | Zack Galbreath | Category | Feature Request => Feature |
| 2012-11-07 21:25 | Alan Scott | Status | expired => backlog |
| 2012-11-07 21:25 | Alan Scott | Resolution | open => reopened |
| 2012-11-07 21:26 | Alan Scott | Note Added: 0029659 | |
| 2012-11-07 21:26 | Alan Scott | Status | backlog => todo |
| 2012-11-07 21:27 | Alan Scott | Project | => Sandia |
| 2012-11-07 21:27 | Alan Scott | Type | => incorrect functionality |
| 2012-11-07 21:27 | Alan Scott | Note Added: 0029660 | |
| 2012-11-07 21:27 | Alan Scott | Priority | normal => high |
| 2012-12-11 09:44 | Sebastien Jourdain | Assigned To | => David Thompson |
| 2012-12-19 13:17 | David Thompson | Topic Name | => 10962_find_data_initialization |
| 2012-12-19 13:17 | David Thompson | Note Added: 0029912 | |
| 2012-12-19 13:17 | David Thompson | Status | todo => gatekeeper review |
| 2012-12-19 13:17 | David Thompson | Fixed in Version | => git-next |
| 2012-12-19 13:17 | David Thompson | Resolution | reopened => fixed |
| 2012-12-21 09:45 | David Thompson | Note Added: 0029922 | |
| 2012-12-21 09:45 | David Thompson | Status | gatekeeper review => active development |
| 2013-10-21 08:16 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2013-10-21 08:17 | Utkarsh Ayachit | Fixed in Version | git-master => |
| 2013-10-29 17:02 | Ken Moreland | Relationship added | related to 0014287 |
| 2013-10-31 11:10 | Utkarsh Ayachit | Assigned To | David Thompson => Utkarsh Ayachit |
| 2013-10-31 11:12 | Utkarsh Ayachit | Note Added: 0031805 | |
| 2013-10-31 11:12 | Utkarsh Ayachit | Status | active development => gatekeeper review |
| 2013-10-31 11:12 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2013-11-01 13:11 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2013-11-01 13:11 | Utkarsh Ayachit | Note Added: 0031809 | |
| 2013-11-01 13:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
| 2013-11-04 13:52 | Ken Moreland | Status | customer review => closed |
| Issue History |
