MantisBT - ParaView
View Issue Details
0010962ParaViewFeaturepublic2010-07-08 15:172013-11-04 13:52
Ken Moreland
Utkarsh Ayachit
highminorhave not tried
closedfixed
4.1
Sandia
10962_find_data_initialization
incorrect functionality
0010962: Find Data dialog should be populated with the current selection
When you first open the Find Data dialog box, it is always blank regardless of what the current selection is. Instead, the dialog should be populated as best as possible with the current selection. At a minimum, the spreadsheet should show the data of the selection and the other buttons (selection color, labels) should reflect the current state of the selection.
If the selection also happens to be a query selection, the Find Data should be initialized to have that query filled in.
No tags attached.
related to 0009344closed Utkarsh Ayachit One-click spreadsheet view of selected elements
related to 0014287closed Utkarsh Ayachit Find Data dialog spreadsheet not updated when time changes
child of 0010627closed David Thompson Additional functionality for find data
Issue History
2010-07-08 15:17Ken MorelandNew Issue
2010-07-08 15:17Ken MorelandRelationship addedchild of 0010627
2011-02-18 14:46Ken MorelandRelationship addedrelated to 0009344
2011-06-16 13:10Zack GalbreathCategoryFeature Request => Feature
2012-11-07 21:25Alan ScottStatusexpired => backlog
2012-11-07 21:25Alan ScottResolutionopen => reopened
2012-11-07 21:26Alan ScottNote Added: 0029659
2012-11-07 21:26Alan ScottStatusbacklog => todo
2012-11-07 21:27Alan ScottProject => Sandia
2012-11-07 21:27Alan ScottType => incorrect functionality
2012-11-07 21:27Alan ScottNote Added: 0029660
2012-11-07 21:27Alan ScottPrioritynormal => high
2012-12-11 09:44Sebastien JourdainAssigned To => David Thompson
2012-12-19 13:17David ThompsonTopic Name => 10962_find_data_initialization
2012-12-19 13:17David ThompsonNote Added: 0029912
2012-12-19 13:17David ThompsonStatustodo => gatekeeper review
2012-12-19 13:17David ThompsonFixed in Version => git-next
2012-12-19 13:17David ThompsonResolutionreopened => fixed
2012-12-21 09:45David ThompsonNote Added: 0029922
2012-12-21 09:45David ThompsonStatusgatekeeper review => active development
2013-10-21 08:16Utkarsh AyachitFixed in Versiongit-next => git-master
2013-10-21 08:17Utkarsh AyachitFixed in Versiongit-master =>
2013-10-29 17:02Ken MorelandRelationship addedrelated to 0014287
2013-10-31 11:10Utkarsh AyachitAssigned ToDavid Thompson => Utkarsh Ayachit
2013-10-31 11:12Utkarsh AyachitNote Added: 0031805
2013-10-31 11:12Utkarsh AyachitStatusactive development => gatekeeper review
2013-10-31 11:12Utkarsh AyachitFixed in Version => git-master
2013-11-01 13:11Utkarsh AyachitStatusgatekeeper review => customer review
2013-11-01 13:11Utkarsh AyachitNote Added: 0031809
2013-11-01 13:17Utkarsh AyachitFixed in Versiongit-master => 4.1
2013-11-04 13:52Ken MorelandStatuscustomer review => closed
Notes
(0029659)
Alan Scott
2012-11-07 21:26
Although there are related requests like this, Kens' is the best. Thus, marking it todo.
(0029660)
Alan Scott
2012-11-07 21:27
This really needs to be done. Please make it a priority.
(0029912)
David Thompson
2012-12-19 13:17
The 10962_find_data_initialization branch in git-next now initializes the Find Data dialog; the selection's source is always set to the current selection's source. If there is no selection, the "active" source is used. If the current selection is a query selection (i.e., was created using the Find Data dialog), then the query is parsed and used to initialize the dialog. Otherwise, the dialog selection type (cell/point) and mode (ID, frustum, etc.) take on default values. This has been tested in client/server mode and the FindDataDialog test modified so that it should not pass unless defaults are populated when the dialog is opened.
This branch depends upon the seln-inspector-spreadsheet branch, which moves the spreadsheet to the selection inspector (where it is properly updated by each new selection -- as opposed to the Find Data dialog, where it was not). However, according to the comments for issue 10956, this is apparently not its final resting place.
(0029922)
David Thompson
2012-12-21 09:45
Taking out of gatekeeper review so it doesn't get into the 3.98 patch release.
(0031805)
Utkarsh Ayachit
2013-10-31 11:12
This is now supported in git/master.
(0031809)
Utkarsh Ayachit
2013-11-01 13:11
SUMMARY
Topics merged into master:
  selection_enhancements
  pvweb-fix-script-path
  fix_chart_interactions
  14376_fix_settings_dialog
  14375-in-situ
  14371_fix_color_function_rescale
  14287_fix_time_and_find_data
Topics reverted from next:
  paraview-web-client-tests
  vtkweb-url-arg-parsing
*NOTE* these topics were reverted since the referenced VTK topics were not
merged in VTK master
