23 #ifndef vtkSMAnimationSceneProxy_h 24 #define vtkSMAnimationSceneProxy_h 26 #include "vtkRemotingAnimationModule.h" 41 virtual bool UpdateAnimationUsingDataTimeSteps();
45 return self ?
self->UpdateAnimationUsingDataTimeSteps() :
false;
54 virtual vtkSMProxy* FindAnimationCue(
vtkSMProxy* animatedProxy,
const char* animatedPropertyName);
59 return self ?
self->FindAnimationCue(animatedProxy, animatedPropertyName) : NULL;
85 void OnUpdateStartEndTimesEvent(
vtkObject*,
unsigned long,
void*);
static vtkSMAnimationSceneProxy * SafeDownCast(vtkObject *o)
vtkSMAnimationSceneProxy observe vtkCommand::ModifiedEvent on the client-side VTK-object to call Upda...
static vtkSMProxy * FindAnimationCue(vtkSMProxy *scene, vtkSMProxy *animatedProxy, const char *animatedPropertyName)
Returns the first animation cue (enabled or otherwise) that animates the given property on the proxy...
static vtkSMProxy * New()
virtual void CreateVTKObjects()
Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s)
virtual int LoadXMLState(vtkPVXMLElement *element, vtkSMProxyLocator *locator)
Loads the proxy state from the XML element.
void operator=(const vtkSMProxy &)=delete
static bool UpdateAnimationUsingDataTimeSteps(vtkSMProxy *scene)
Setups the animation scene's playback mode and time-ranges based on the timesteps available on the ti...
