2 @defgroup module-wrapping-java Module Java CMake APIs
6 @file vtkModuleWrapJava.cmake
7 @brief APIs
for wrapping modules
for Java
12 @brief Generate sources
for using a module
's classes from Java 14 This function generates the wrapped sources for a module. It places the list of 15 generated source files and Java source files in variables named in the second 16 and third arguments, respectively. 19 _vtk_module_wrap_java_sources(<module> <sources> <classes>) 24 cmake_policy(SET CMP0053 NEW) 26 function (_vtk_module_wrap_java_sources module sources java_sources) 27 _vtk_module_get_module_property("${module}" 28 PROPERTY "exclude_wrap" 29 VARIABLE _vtk_java_exclude_wrap) 30 if (_vtk_java_exclude_wrap) 34 file(MAKE_DIRECTORY "${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/${_vtk_java_library_name}Java") 36 set(_vtk_java_args_file "${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/${_vtk_java_library_name}Java/${_vtk_java_library_name}-java.$<CONFIGURATION>.args") 37 set(_vtk_java_init_data_file "${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/${_vtk_java_library_name}Java/${_vtk_java_library_name}-java-init.data") 39 set(_vtk_java_hierarchy_depends "${module}") 40 _vtk_module_get_module_property("${module}" 41 PROPERTY "private_depends" 42 VARIABLE _vtk_java_private_depends) 43 list(APPEND _vtk_java_hierarchy_depends ${_vtk_java_private_depends}) 45 set(_vtk_java_command_depends) 46 foreach (_vtk_java_hierarchy_depend IN LISTS _vtk_java_hierarchy_depends) 47 _vtk_module_get_module_property("${_vtk_java_hierarchy_depend}" 49 VARIABLE _vtk_java_hierarchy_file) 50 if (_vtk_java_hierarchy_file) 51 list(APPEND _vtk_java_hierarchy_files "${_vtk_java_hierarchy_file}") 52 get_property(_vtk_java_is_imported 53 TARGET "${_vtk_java_hierarchy_depend}" 55 if (_vtk_java_is_imported OR CMAKE_GENERATOR MATCHES "Ninja") 56 list(APPEND _vtk_java_command_depends "${_vtk_java_hierarchy_file}") 58 _vtk_module_get_module_property("${_vtk_java_hierarchy_depend}" 59 PROPERTY "library_name" 60 VARIABLE _vtk_java_hierarchy_library_name) 61 if (TARGET "${_vtk_java_hierarchy_library_name}-hierarchy") 62 list(APPEND _vtk_java_command_depends "${_vtk_java_hierarchy_library_name}-hierarchy") 65 "The ${_vtk_java_hierarchy_depend} hierarchy file is attached to a non-imported target " 66 "and a hierarchy target (${_vtk_java_hierarchy_library_name}-hierarchy) is " 73 set(_vtk_java_genex_compile_definitions 74 "$<TARGET_PROPERTY:${_vtk_java_target_name},COMPILE_DEFINITIONS>") 75 set(_vtk_java_genex_include_directories 76 "$<TARGET_PROPERTY:${_vtk_java_target_name},INCLUDE_DIRECTORIES>") 78 OUTPUT "${_vtk_java_args_file}" 79 CONTENT "$<$<BOOL:${_vtk_java_genex_compile_definitions}>:\n-D\'$<JOIN:${_vtk_java_genex_compile_definitions},\'\n-D\'>\'>\n 80 $<$<BOOL:${_vtk_java_genex_include_directories}>:\n-I\'$<JOIN:${_vtk_java_genex_include_directories},\'\n-I\'>\'>\n 81 $<$<BOOL:${_vtk_java_hierarchy_files}>:\n--types \'$<JOIN:${_vtk_java_hierarchy_files},\'\n--types \'>\'>\n") 83 set(_vtk_java_sources) 84 set(_vtk_java_java_sources) 86 _vtk_module_get_module_property("${module}" 88 VARIABLE _vtk_java_headers) 89 set(_vtk_java_classes) 90 foreach (_vtk_java_header IN LISTS _vtk_java_headers) 91 get_filename_component(_vtk_java_basename "${_vtk_java_header}" NAME_WE) 92 list(APPEND _vtk_java_classes 93 "${_vtk_java_basename}") 95 # The vtkWrapJava tool has special logic for the `vtkRenderWindow` class. 96 # This extra logic requires its wrappers to be compiled as ObjC++ code 98 set(_vtk_java_ext "cxx") 99 if (APPLE AND _vtk_java_basename STREQUAL "vtkRenderWindow") 100 set(_vtk_java_ext "mm") 103 set(_vtk_java_source_output 104 "${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/${_vtk_java_library_name}Java/${_vtk_java_basename}Java.${_vtk_java_ext}") 105 list(APPEND _vtk_java_sources 106 "${_vtk_java_source_output}") 108 set(_vtk_java_wrap_target "VTK::WrapJava") 109 set(_vtk_java_macros_args) 110 if (TARGET VTKCompileTools::WrapJava) 111 set(_vtk_java_wrap_target "VTKCompileTools::WrapJava") 112 if (TARGET VTKCompileTools_macros) 113 list(APPEND _vtk_java_command_depends 114 "VTKCompileTools_macros") 115 list(APPEND _vtk_java_macros_args 117 -imacros "${_VTKCompileTools_macros_file}") 121 set(_vtk_java_parse_target "VTK::ParseJava") 122 if (TARGET VTKCompileTools::ParseJava) 123 set(_vtk_java_parse_target "VTKCompileTools::ParseJava") 127 OUTPUT "${_vtk_java_source_output}" 128 COMMAND ${CMAKE_CROSSCOMPILING_EMULATOR} 129 "$<TARGET_FILE:${_vtk_java_wrap_target}>" 130 "@${_vtk_java_args_file}" 131 -o "${_vtk_java_source_output}" 132 "${_vtk_java_header}" 133 ${_vtk_java_macros_args} 135 CXX "${_vtk_java_header}" 136 COMMENT "Generating Java wrapper sources for ${_vtk_java_basename}" 138 "${_vtk_java_header}" 139 "${_vtk_java_args_file}" 140 "$<TARGET_FILE:${_vtk_java_wrap_target}>" 141 ${_vtk_java_command_depends}) 143 set(_vtk_java_java_source_output 144 "${_vtk_java_JAVA_OUTPUT}/${_vtk_java_basename}.java") 145 list(APPEND _vtk_java_java_sources 146 "${_vtk_java_java_source_output}") 149 OUTPUT "${_vtk_java_java_source_output}" 150 COMMAND "${_vtk_java_parse_target}" 151 "@${_vtk_java_args_file}" 152 -o "${_vtk_java_java_source_output}" 153 "${_vtk_java_header}" 154 ${_vtk_java_macros_args} 156 CXX "${_vtk_java_header}" 157 COMMENT "Generating Java sources for ${_vtk_java_basename}" 159 "${_vtk_java_header}" 160 "${_vtk_java_args_file}" 161 "$<TARGET_FILE:${_vtk_java_parse_target}>" 162 ${_vtk_java_command_depends}) 166 "${_vtk_java_sources}" 169 set("${java_sources}" 170 "${_vtk_java_java_sources}" 176 @brief Generate a JNI library for a set of modules 178 A single JNI library may consist of the Java wrappings of multiple modules. 179 This is useful for kit-based builds where the modules part of the same kit 180 belong to the same JNI library as well. 183 _vtk_module_wrap_java_library(<name> <module>...) 186 The first argument is the name of the JNI library. The remaining arguments are 187 modules to include in the JNI library. 189 The remaining information it uses is assumed to be provided by the 190 @ref vtk_module_wrap_java function. 192 function (_vtk_module_wrap_java_library name) 193 set(_vtk_java_library_sources) 194 set(_vtk_java_library_java_sources) 195 set(_vtk_java_library_link_depends) 196 foreach (_vtk_java_module IN LISTS ARGN) 197 _vtk_module_get_module_property("${_vtk_java_module}" 198 PROPERTY "exclude_wrap" 199 VARIABLE _vtk_java_exclude_wrap) 200 if (_vtk_java_exclude_wrap) 203 _vtk_module_real_target(_vtk_java_target_name "${_vtk_java_module}") 204 _vtk_module_get_module_property("${_vtk_java_module}" 205 PROPERTY "library_name" 206 VARIABLE _vtk_java_library_name) 207 _vtk_module_wrap_java_sources("${_vtk_java_module}" _vtk_java_sources _vtk_java_java_sources) 208 list(APPEND _vtk_java_library_sources 209 ${_vtk_java_sources}) 210 list(APPEND _vtk_java_library_java_sources 211 ${_vtk_java_java_sources}) 213 _vtk_module_get_module_property("${_vtk_java_module}" 215 VARIABLE _vtk_java_module_depends) 216 foreach (_vtk_java_module_depend IN LISTS _vtk_java_module_depends) 217 _vtk_module_get_module_property("${_vtk_java_module_depend}" 218 PROPERTY "exclude_wrap" 219 VARIABLE _vtk_java_module_depend_exclude_wrap) 220 if (_vtk_java_module_depend_exclude_wrap) 224 _vtk_module_get_module_property("${_vtk_java_module_depend}" 225 PROPERTY "library_name" 226 VARIABLE _vtk_java_depend_library_name) 228 # XXX(kits): This doesn't work
for kits.
229 list(APPEND _vtk_java_library_link_depends
230 "${_vtk_java_depend_library_name}Java")
234 if (NOT _vtk_java_library_sources)
238 if (_vtk_java_library_link_depends)
239 list(REMOVE_DUPLICATES _vtk_java_library_link_depends)
242 set(_vtk_java_target "${
name}Java
") 244 # XXX(java): Should this be a `MODULE`? If not, we should probably export 245 # these targets, but then we'll need logic akin to the `vtkModuleWrapPython` 246 # logic for loading wrapped modules from other packages. 247 add_library("${_vtk_java_target}
" SHARED 248 ${_vtk_java_library_sources}) 249 add_custom_target("${_vtk_java_target}-java-sources
" 251 ${_vtk_java_library_java_sources}) 252 add_dependencies("${_vtk_java_target}
" 253 "${_vtk_java_target}-java-sources
") 255 set_property(TARGET "${_vtk_java_target}
" 260 set_property(TARGET "${_vtk_java_target}
" 264 set_property(TARGET "${_vtk_java_target}
" 266 "_vtk_module_java_files
" "${_vtk_java_library_java_sources}
") 268 if (_vtk_java_JNILIB_DESTINATION) 270 TARGETS "${_vtk_java_target}
" 273 DESTINATION "${_vtk_java_JNILIB_DESTINATION}
" 274 COMPONENT "${_vtk_java_JNILIB_COMPONENT}
" 277 DESTINATION "${_vtk_java_JNILIB_DESTINATION}
" 278 COMPONENT "${_vtk_java_JNILIB_COMPONENT}
") 283 TARGETS "${_vtk_java_target}
") 285 target_link_libraries("${_vtk_java_target}
" 288 # XXX(java): If we use modules, remove this. 289 ${_vtk_java_library_link_depends} 294 @ingroup module-wrapping-java 295 @brief Wrap a set of modules for use in Java 298 vtk_module_wrap_java( 300 [WRAPPED_MODULES <varname>] 302 [JAVA_OUTPUT <destination>]) 305 * `MODULES`: (Required) The list of modules to wrap. 306 * `WRAPPED_MODULES`: (Recommended) Not all modules are wrappable. This 307 variable will be set to contain the list of modules which were wrapped. 308 * `JAVA_OUTPUT`: Defaults to 309 `${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/vtkJava`. Java source files are 310 written to this directory. After generation, the files may be compiled as 312 * `LIBRARY_DESTINATION` (Recommended): If provided, dynamic loader 313 information will be added to modules for loading dependent libraries. 314 * `JNILIB_DESTINATION`: Where to install JNI libraries. 315 * `JNILIB_COMPONENT`: Defaults to `jni`. The install component to use for JNI 318 For each wrapped module, a `<module>Java` target will be created. These targets 319 will have a `_vtk_module_java_files` property which is the list of generated 320 Java source files for that target. 322 For dependency purposes, the `<module>Java-java-sources` target may also be 325 function (vtk_module_wrap_java) 326 cmake_parse_arguments(PARSE_ARGV 0 _vtk_java 328 "JAVA_OUTPUT;WRAPPED_MODULES;LIBRARY_DESTINATION;JNILIB_DESTINATION;JNILIB_COMPONENT
" 331 if (_vtk_java_UNPARSED_ARGUMENTS) 334 "${_vtk_java_UNPARSED_ARGUMENTS}
") 337 if (NOT _vtk_java_JAVA_OUTPUT) 338 set(_vtk_java_JAVA_OUTPUT "${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/vtkJava
") 341 if (NOT _vtk_java_JNILIB_COMPONENT) 342 set(_vtk_java_JNILIB_COMPONENT "jni
") 346 set(CMAKE_BUILD_RPATH_USE_ORIGIN 1) 349 set(_vtk_java_origin_rpath_prefix 352 set(_vtk_java_origin_rpath_prefix 356 list(APPEND CMAKE_INSTALL_RPATH 357 # For sibling wrapped modules. 358 "${_vtk_java_origin_rpath_prefix}
") 360 if (DEFINED _vtk_java_LIBRARY_DESTINATION AND DEFINED _vtk_java_JNILIB_DESTINATION) 361 file(RELATIVE_PATH _vtk_java_relpath 362 "/prefix/${_vtk_java_JNILIB_DESTINATION}
" 363 "/prefix/${_vtk_java_LIBRARY_DESTINATION}
") 365 list(APPEND CMAKE_INSTALL_RPATH 367 "${_vtk_java_origin_rpath_prefix}/${_vtk_java_relpath}
") 371 if (DEFINED _vtk_java_JNILIB_DESTINATION) 372 set(CMAKE_RUNTIME_OUTPUT_DIRECTORY "${CMAKE_BINARY_DIR}/${_vtk_java_JNILIB_DESTINATION}
") 373 set(CMAKE_LIBRARY_OUTPUT_DIRECTORY "${CMAKE_BINARY_DIR}/${_vtk_java_JNILIB_DESTINATION}
") 376 if (NOT _vtk_java_MODULES) 378 "No modules were requested
for java wrapping.
") 382 # Disable CMake's automoc support for these targets. 387 set(_vtk_java_all_wrapped_modules) 388 foreach (_vtk_java_module IN LISTS _vtk_java_MODULES) 389 _vtk_module_get_module_property("${_vtk_java_module}
" 390 PROPERTY "library_name
" 391 VARIABLE _vtk_java_exclude_wrap) 392 _vtk_module_get_module_property("${_vtk_java_module}
" 393 PROPERTY "library_name
" 394 VARIABLE _vtk_java_library_name) 395 _vtk_module_wrap_java_library("${_vtk_java_library_name}
" "${_vtk_java_module}
") 397 if (TARGET "${_vtk_java_library_name}Java
") 398 list(APPEND _vtk_java_all_wrapped_modules 399 "${_vtk_java_module}
") 403 if (NOT _vtk_java_all_wrapped_modules) 405 "No modules given could be wrapped.
") 408 if (DEFINED _vtk_java_WRAPPED_MODULES) 409 set("${_vtk_java_WRAPPED_MODULES}
" 410 "${_vtk_java_all_wrapped_modules}
function vtk_module_wrap_java()
Wrap a set of modules for use in Java.
