| macro | _vtk_module_parse_module_args (name_output) |
Parse vtk.module file contents. More... | |
| macro | _vtk_module_parse_kit_args (name_output) |
Parse vtk.kit file contents. More... | |
| function | _vtk_module_verify_enable_value (var) |
| Verify enable values. More... | |
| function | _vtk_module_target_function (prefix) |
| Generate arguments for target function wrappers. More... | |
| function | _vtk_private_kit_link_target (module) |
| Manage the private link target for a module. More... | |
| function | _vtk_module_standard_includes () |
| Add "standard" include directories to a module. More... | |
| function | _vtk_module_default_export_macro_prefix (varname) |
| Determine the default export macro for a module. More... | |
| function | _vtk_module_write_wrap_hierarchy () |
| Generate the hierarchy for a module. More... | |
| function | _vtk_module_add_header_tests () |
| Add header tests for a module. More... | |
| function | _vtk_module_mark_third_party (target) |
| Mark a module as being third party. More... | |
| function | _vtk_module_graphviz_module_node (var, module) |
| Output a node in the graph. More... | |
| macro | _vtk_json_bool (output, name, cond) |
| Output a boolean to JSON. More... | |
| macro | _vtk_json_string_list (output, name, var) |
| Output a string list to JSON. More... | |
| function | _vtk_module_wrap_java_sources (module, sources, java_sources) |
| Generate sources for using a module's classes from Java. More... | |
| function | _vtk_module_wrap_java_library (name) |
| Generate a JNI library for a set of modules. More... | |
| function | _vtk_module_wrap_python_sources (module, sources, classes) |
| Generate sources for using a module's classes from Python. More... | |
| function | _vtk_module_wrap_python_library (name) |
| Generate a CPython library for a set of modules. More... | |
| macro _vtk_module_parse_module_args | ( | name_output | ) |
This macro places all vtk.module keyword "arguments" into the caller's scope prefixed with the value of name_output which is set to the NAME of the module.
For example, this vtk.module file:
called with _vtk_module_parse_module_args(name ...) will set the following variables in the calling scope:
name: Namespace::TargetNamespace::Target_LIBRARY_NAME: nsTargetWith namespace support for module names, the variable should instead be referenced via ${${name}_LIBRARY_NAME} instead.
Definition at line 251 of file vtkModule.cmake.
| macro _vtk_module_parse_kit_args | ( | name_output | ) |
Just like _vtk_module_parse_module_args, but for kits.
Definition at line 332 of file vtkModule.cmake.
| function _vtk_module_verify_enable_value | ( | var | ) |
Verifies that the variable named as the first parameter is a valid enable status value.
Definition at line 411 of file vtkModule.cmake.
| function _vtk_module_target_function | ( | prefix | ) |
Create the INTERFACE, PUBLIC, and PRIVATE arguments for a function wrapping CMake's target_ functions to call the wrapped function.
This is necessary because not all of the functions support empty lists given a keyword.
Definition at line 1332 of file vtkModule.cmake.
| function _vtk_private_kit_link_target | ( | module | ) |
This function manages the private link target for a module.
Definition at line 1516 of file vtkModule.cmake.
| function _vtk_module_standard_includes | ( | ) |
Add the "standard" includes for a module to its interface. These are the source and build directories for the module itself. They are always either PUBLIC or INTERFACE (depending on the module's target type).
Definition at line 2735 of file vtkModule.cmake.
| function _vtk_module_default_export_macro_prefix | ( | varname | ) |
Determines the export macro to be used for a module from its metadata. Assumes it is called from within a vtk_module_build call.
Definition at line 2791 of file vtkModule.cmake.
| function _vtk_module_write_wrap_hierarchy | ( | ) |
Write wrap hierarchy files for the module currently being built. This also installs the hierarchy file for use by dependent projects if INSTALL_HEADERS is set.
Definition at line 3029 of file vtkModule.cmake.
| function _vtk_module_add_header_tests | ( | ) |
vtkModuleTesting.cmake. Each module would then need to manually call this function. It currently assumes it is in VTK itself.Definition at line 3720 of file vtkModule.cmake.
Mark a module as being a third party module.
Definition at line 4679 of file vtkModule.cmake.
| function _vtk_module_graphviz_module_node | ( | var | , |
| module | |||
Queries the properties for modules and generates the node for it in the graph and its outgoing dependency edges.
Definition at line 8 of file vtkModuleGraphviz.cmake.
| macro _vtk_json_bool | ( | output | , |
| name | , | ||
| cond | |||
Appends a condition as a JSON boolean with the given dictionary key name to the given string variable.
Definition at line 12 of file vtkModuleJson.cmake.
| macro _vtk_json_string_list | ( | output | , |
| name | , | ||
| var | |||
Appends a variable as a JSON list of strings with the given dictionary key name to the given string variable.
Definition at line 33 of file vtkModuleJson.cmake.
| function _vtk_module_wrap_java_sources | ( | module | , |
| sources | , | ||
| java_sources | |||
This function generates the wrapped sources for a module. It places the list of generated source files and Java source files in variables named in the second and third arguments, respectively.
Definition at line 26 of file vtkModuleWrapJava.cmake.
A single JNI library may consist of the Java wrappings of multiple modules. This is useful for kit-based builds where the modules part of the same kit belong to the same JNI library as well.
The first argument is the name of the JNI library. The remaining arguments are modules to include in the JNI library.
The remaining information it uses is assumed to be provided by the vtk_module_wrap_java function.
Definition at line 192 of file vtkModuleWrapJava.cmake.
| function _vtk_module_wrap_python_sources | ( | module | , |
| sources | , | ||
| classes | |||
This function generates the wrapped sources for a module. It places the list of generated source files and classes in variables named in the second and third arguments, respectively.
Definition at line 108 of file vtkModuleWrapPython.cmake.
A Python module library may consist of the Python wrappings of multiple modules. This is useful for kit-based builds where the modules part of the same kit belong to the same Python module as well.
The first argument is the name of the Python module. The remaining arguments are modules to include in the Python module.
The remaining information it uses is assumed to be provided by the vtk_module_wrap_python function.
Definition at line 240 of file vtkModuleWrapPython.cmake.
