pqSampleScalarWidget.h
3  Program: ParaView
4  Module: pqSampleScalarWidget.h
5
6  Copyright (c) 2005-2008 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 =========================================================================*/
32
33 #ifndef _pqSampleScalarWidget_h
34 #define _pqSampleScalarWidget_h
35
36 #include "pqComponentsModule.h"
37 #include "pqSMProxy.h"
38 #include "vtkSetGet.h" // for VTK_LEGACY_REMOVE
40 #if !defined(VTK_LEGACY_REMOVE)
41 #include <QList>
42 #include <QModelIndex>
43 #include <QVariant>
44 #include <QWidget>
45
46 class QItemSelection;
47
49
61 class PQCOMPONENTS_EXPORT pqSampleScalarWidget : public QWidget
62 {
63  typedef QWidget Superclass;
64
65  Q_OBJECT
66  Q_PROPERTY(QVariantList samples READ samples WRITE setSamples)
67
68 public:
69  // If preserve_order == true, then the widget will preserve value orders
70  // and allow for duplicates, otherwise the values are unique and sorted.
71  pqSampleScalarWidget(bool preserve_order, QWidget* Parent = 0);
72  ~pqSampleScalarWidget() override;
73
77  void setDataSources(pqSMProxy controlled_proxy, vtkSMDoubleVectorProperty* sample_property,
78  vtkSMProperty* range_property = 0);
79
83  void accept();
87  void reset();
88
89  // Returns the samples currently selected in the widget
90  // (these may differ from the accepted values).
91  QList<QVariant> samples();
92
93  // Set the current value of the widget.
94  void setSamples(QList<QVariant> samples);
95 Q_SIGNALS:
99  void samplesChanged();
100
101 private Q_SLOTS:
102  void onSamplesChanged();
103  void onSelectionChanged(const QItemSelection&, const QItemSelection&);
104
105  void onDelete();
106  void onDeleteAll();
107  void onNewValue();
108  void onNewRange();
109  void onSelectAll();
110  void onScientificNotation(bool);
111
112  void onControlledPropertyChanged();
113  void onControlledPropertyDomainChanged();
114
115 private:
117  pqSampleScalarWidget& operator=(const pqSampleScalarWidget&);
118
119  bool getRange(double& range_min, double& range_max);
120
121  class pqImplementation;
122  pqImplementation* const Implementation;
123
124  bool eventFilter(QObject* object, QEvent* e) override;
125 };
126
127 #endif // !defined(VTK_LEGACY_REMOVE)
128 #endif // !_pqSampleScalarWidget_h
samples
property representing a vector of doubles
