pqProxyGroupMenuManager.h
3  Program: ParaView
4  Module: pqProxyGroupMenuManager.h
5
6  Copyright (c) 2005,2006 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 ========================================================================*/
32 #ifndef pqProxyGroupMenuManager_h
33 #define pqProxyGroupMenuManager_h
35 #include "pqApplicationComponentsModule.h"
36 #include <QMenu>
37
38 class vtkPVXMLElement;
39 class vtkSMProxy;
40
46 class PQAPPLICATIONCOMPONENTS_EXPORT pqProxyGroupMenuManager : public QObject
47 {
48  Q_OBJECT
49  typedef QObject Superclass;
50
51 public:
61  QMenu* menu, const QString& resourceTagName, bool supportsQuickLaunch = true);
62  ~pqProxyGroupMenuManager() override;
63
67  QMenu* menu() const { return static_cast<QMenu*>(this->parent()); }
68
73  void setRecentlyUsedMenuSize(unsigned int val) { this->RecentlyUsedMenuSize = val; }
74
75  unsigned int recentlyUsedMenuSize() const { return this->RecentlyUsedMenuSize; }
76
80  QWidget* widgetActionsHolder() const;
81
85  QList<QAction*> actions() const;
86
90  vtkSMProxy* getPrototype(QAction* action) const;
91
95  void addProxy(const QString& xmlgroup, const QString& xmlname);
96
100  void removeProxy(const QString& xmlgroup, const QString& xmlname);
101
106  QStringList getToolbarCategories() const;
107
111  QList<QAction*> actions(const QString& category);
112
116  QList<QAction*> actionsInToolbars();
117
121  bool hideForTests(const QString& category) const;
122
131  void addProxyDefinitionUpdateListener(const QString& proxyGroupName);
132  void removeProxyDefinitionUpdateListener(const QString& proxyGroupName);
133
138  bool supportsQuickLaunch() const { return this->SupportsQuickLaunch; }
139
140  void setEnableFavorites(bool enable) { this->EnableFavorites = enable; }
141
142  QMenu* getFavoritesMenu();
143
147  QString categoryLabel(const QString& category);
148
149 public Q_SLOTS:
156  void loadConfiguration(vtkPVXMLElement*);
157
161  void lookForNewDefinitions();
162
166  void removeProxyDefinitionUpdateObservers();
167
171  void addProxyDefinitionUpdateObservers();
172
176  void setEnabled(bool enable);
177
182  void populateMenu();
183
184 Q_SIGNALS:
185  void triggered(const QString& group, const QString& name);
186
191  void menuPopulated();
192
193 protected Q_SLOTS:
194  void triggered();
195  void quickLaunch();
196  void switchActiveServer();
197  void updateMenuStyle();
198
203  void populateRecentlyUsedMenu();
204
209  void populateFavoritesMenu();
210
211 protected:
215  bool Enabled;
217
218  void loadRecentlyUsedItems();
219  void saveRecentlyUsedItems();
220
224  void loadFavoritesItems();
225
229  QAction* getAction(const QString& pgroup, const QString& proxyname);
230
231  QAction* getAddToCategoryAction(const QString& path);
232
233 private:
234  Q_DISABLE_COPY(pqProxyGroupMenuManager)
235
236  class pqInternal;
237  pqInternal* Internal;
238  bool SupportsQuickLaunch;
239 };
240
241 #endif
When size>0 a recently used category will be added to the menu.
pqProxyGroupMenuManager is a menu-populator that fills up a menu with proxies defined in an XML confi...
Returns true if the pqProxyGroupMenuManager has been registered with quick-launch mechanism maintaine...
name
Definition: vtkSMProxy.h:152
QMenu * menu() const
Access the menu.
