pqHierarchicalGridLayout.h
3  Program: ParaView
4  Module: pqHierarchicalGridLayout.h
5
6  Copyright (c) 2005,2006 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 ========================================================================*/
32 #ifndef pqHierarchicalGridLayout_h
33 #define pqHierarchicalGridLayout_h
35 #include <QLayout>
36 #include <QScopedPointer> // for ivar
37
38 #include "pqWidgetsModule.h" // for export macros
66 class PQWIDGETS_EXPORT pqHierarchicalGridLayout : public QLayout
67 {
68  Q_OBJECT
69  typedef QLayout Superclass;
70
71 public:
72  pqHierarchicalGridLayout(QWidget* parent = 0);
73  ~pqHierarchicalGridLayout() override;
74
76
79  void addItem(QLayoutItem* item) override;
80  QLayoutItem* itemAt(int index) const override;
81  QLayoutItem* takeAt(int index) override;
82  int count() const override;
84
86
89  QSize minimumSize() const override;
90  void setGeometry(const QRect& rect) override;
91  QSize sizeHint() const override;
93
95
98  bool isLocationValid(int location) const;
100
102
105  void split(int location, Qt::Orientation direction, double splitFraction);
106  void splitAny(int location, double splitFraction);
107  void splitVertical(int location, double splitFraction)
108  {
109  this->split(location, Qt::Vertical, splitFraction);
110  }
111  void splitHorizontal(int location, double splitFraction)
112  {
113  this->split(location, Qt::Horizontal, splitFraction);
114  }
116
121  void setSplitFraction(int location, double splitFraction);
123
125
130  void maximize(int location);
132
133  class Item
134  {
135  public:
136  Item(Qt::Orientation direction, double fraction)
137  : Direction(direction)
138  , Fraction(fraction)
139  {
140  }
141  Item(QWidget* widget = nullptr)
142  : Widget(widget)
143  {
144  }
145
146  private:
147  QWidget* Widget = nullptr;
148  Qt::Orientation Direction = Qt::Horizontal;
149  double Fraction = -1.0;
151  };
152
164  QVector<QWidget*> rearrange(const QVector<Item>& layout);
165
166 private:
167  Q_DISABLE_COPY(pqHierarchicalGridLayout);
168
169  class pqInternals;
170  QScopedPointer<pqInternals> Internals;
171 };
172
173 #endif
Adds a splitter item.
direction
location
QLayout specialization that supports a hierarchical layout.
void split(const std::string &s, const char &delim, std::vector< std::string > &elems)
QVector< QWidget * > rearrange(const QVector< Item > &layout)
API to rearrange the widgets in this layout.
index
