QLayout specialization that supports a hierarchical layout. More...
#include <pqHierarchicalGridLayout.h>
Inherits QLayout.
| class | Item |
| pqHierarchicalGridLayout (QWidget *parent=0) | |
| ~pqHierarchicalGridLayout () override | |
| void | setSplitFraction (int location, double splitFraction) |
| Specify the split fraction for a location. More... | |
| QVector< QWidget * > | rearrange (const QVector< Item > &layout) |
| API to rearrange the widgets in this layout. More... | |
| void | addItem (QLayoutItem *item) override |
| pure virtual methods from QLayout More... | |
| QLayoutItem * | itemAt (int index) const override |
| QLayoutItem * | takeAt (int index) override |
| int | count () const override |
| QSize | minimumSize () const override |
| recommended overrides from QLayout More... | |
| void | setGeometry (const QRect &rect) override |
| QSize | sizeHint () const override |
| bool | isLocationValid (int location) const |
| Returns true if the location points to a valid reachable location. More... | |
| void | split (int location, Qt::Orientation direction, double splitFraction) |
| Adds a splitter item. More... | |
| void | splitAny (int location, double splitFraction) |
| void | splitVertical (int location, double splitFraction) |
| void | splitHorizontal (int location, double splitFraction) |
| void | maximize (int location) |
| Maximize any cell location. More... | |
pqHierarchicalGridLayout supports a layout where the widgets added to the layout can be treated as laid out in a binary tree with each non-leaf node splitting the viewport horizontally or vertically.
If one adds widgets to the layout using QLayout API e.g. addWidget then the layout will automatically build the binary tree by adding splits in the layout as needed.
Another way to explicitly provide an arrangement of widgets is to use rearrange to add/remove widgets from the layout and place them in particular fashion.
If pqHierarchicalGridLayout is added to a pqHierarchicalGridWidget then it is possible to allow the user to interactively resize individual widgets.
pqHierarchicalGridLayout currently does not support adding non QWidget items to the layout e.g. another QLayout or QSpacerItem etc. Support for these can be added in future when needed.
Definition at line 66 of file pqHierarchicalGridLayout.h.
| pqHierarchicalGridLayout::pqHierarchicalGridLayout | ( | QWidget * | parent = 0 | ) |
| bool pqHierarchicalGridLayout::isLocationValid | ( | int | location | ) | const |
| void pqHierarchicalGridLayout::split | ( | int | location, |
| Qt::Orientation | direction, | ||
| double | splitFraction | ||
location specified must be valid and reachable.
Definition at line 107 of file pqHierarchicalGridLayout.h.
Definition at line 111 of file pqHierarchicalGridLayout.h.
location must be valid and reachable.
| void pqHierarchicalGridLayout::maximize | ( | int | location | ) |
Set to 0 to return to default un-maximized state. Invalid location i.e. negative or referring to a non-existent or unreachable cell will be ignored with a warning message.
The argument is simply a sequential representation for a binary tree were for a split node at index i, the first child node is at index 2*i + 1 and the second child node is at index 2*i + 2.
Any widgets previously added to the layout no longer present in the arrangement are removed from the layout and returned.
Any widgets not already present in the layout are added to the layout using addWidget.
