pqDoubleRangeWidget.h
3  Program: ParaView
4  Module: pqDoubleRangeWidget.h
5
6  Copyright (c) 2005-2008 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 =========================================================================*/
32 #ifndef pqDoubleRangeWidget_h
33 #define pqDoubleRangeWidget_h
35 #include "pqDoubleSliderWidget.h"
36 #include "pqWidgetsModule.h"
37 #include "vtkSetGet.h" // for VTK_LEGACY
38 #include <QWidget>
44 class PQWIDGETS_EXPORT pqDoubleRangeWidget : public pqDoubleSliderWidget
45 {
46  Q_OBJECT
47  Q_PROPERTY(double minimum READ minimum WRITE setMinimum)
48  Q_PROPERTY(double maximum READ maximum WRITE setMaximum)
49 #if !defined(VTK_LEGACY_REMOVE)
50  Q_PROPERTY(bool strictRange READ strictRange WRITE setStrictRange);
51 #endif
52  Q_PROPERTY(int resolution READ resolution WRITE setResolution)
53
55
56 public:
60  pqDoubleRangeWidget(QWidget* parent = NULL);
61  ~pqDoubleRangeWidget() override;
62
63  // get the min range value
64  double minimum() const;
65  // get the max range value
66  double maximum() const;
67
71  VTK_LEGACY(bool strictRange() const);
72
73  // returns the resolution.
74  int resolution() const;
75
76 public Q_SLOTS:
77  // set the min range value
78  void setMinimum(double);
79  // set the max range value
80  void setMaximum(double);
81
82 #if !defined(VTK_LEGACY_REMOVE)
83
86  void setStrictRange(bool);
87 #endif
88
89  // set the resolution.
90  void setResolution(int);
91
92 protected:
93  int valueToSliderPos(double val) override;
94  double sliderPosToValue(int pos) override;
95
96 private Q_SLOTS:
97  void updateValidator();
98
99 private:
100  int Resolution;
101  double Minimum;
102  double Maximum;
103 #if !defined(VTK_LEGACY_REMOVE)
104  bool StrictRange = false;
105 #endif
106 };
107
108 #endif
#define VTK_LEGACY(method)
Definition: vtkLegacy.h:52
A widget with a tied slider and line edit for editing a double property.
virtual int valueToSliderPos(double val)
Extends pqDoubleSliderWidget to use it with a range of doubles : provides control on min/max...
resolution
virtual double sliderPosToValue(int pos)
