Core
pqContextView.h
1
3
Program: ParaView
4
Module: pqContextView.h
5
6
Copyright (c) 2005,2006 Sandia Corporation, Kitware Inc.
7
All rights reserved.
9
ParaView is a free software; you can redistribute it and/or modify it
10
under the terms of the ParaView license version 1.2.
11
12
See License_v1.2.txt for the full ParaView license.
13
A copy of this license can be obtained by contacting
14
Kitware Inc.
15
28 Corporate Drive
16
Clifton Park, NY 12065
17
USA
18
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
20
``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
21
LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
22
A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHORS OR
23
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
24
EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
25
PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
26
PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
27
LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
28
NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
30
31
32
#ifndef pqContextView_h
33
#define pqContextView_h
35
pqView.h
36
vtkType.h
37
38
vtkSMContextViewProxy
vtkContextView
40
vtkObject
41
vtkSelection
42
47
PQCORE_EXPORT
pqContextView
public
pqView
48
49
Q_OBJECT
50
typedef
pqView
Superclass
51
52
public
53
pqContextView
override
54
59
vtkContextView
* getVTKContextView()
const
60
64
* getContextViewProxy()
const
65
69
bool
supportsSelection()
const
70
76
bool
supportsCapture
const override
return
true
77
82
// Default is vtkChart::SELECT_RECTANGLE
83
void
setSelectionAction(
int
selAction);
84
int
selectionAction();
85
89
void
resetDisplay
override
90
91
Q_SLOTS:
93
98
void
startInteraction();
99
void
endInteraction();
101
102
pqContextView
const
QString&
type
const
QString& group,
const
QString&
name
113
vtkSMViewProxy
* view,
pqServer
* server, QObject* parent = NULL);
114
119
QWidget*
createWidget
override
120
124
void
selectionChanged();
125
129
void
setSelection(
vtkSelection
130
command;
131
command*
Command
132
133
private
134
Q_DISABLE_COPY(
pqContextView
135
136
pqInternal;
137
pqInternal* Internal;
138
139
140
#endif
vtkObject
type
type
pqContextView
pqContextView is an abstract base class for all charting views based on the VTK context charting libr...
Definition:
pqContextView.h:47
vtkSMViewProxy
Superclass for all view proxies.
Definition:
vtkSMViewProxy.h:54
vtkSelection
pqView
This is a PQ abstraction of a generic view module.
Definition:
pqView.h:54
name
name
abstract base class for all Chart Views.
Definition:
vtkSMContextViewProxy.h:38
pqView::resetDisplay
virtual void resetDisplay()
Called to reset the view's display.
Definition:
pqView.h:146
pqContextView::Command
command * Command
Definition:
pqContextView.h:130
vtkType.h
pqView.h
pqView::createWidget
virtual QWidget * createWidget()=0
Subclasses must override this method to create a widget for the view.
vtkContextView
pqServer
pqServer (should be renamed to pqSession) is a pqServerManagerModelItem subclass that represents a vt...
Definition:
pqServer.h:64
pqContextView::supportsCapture
bool supportsCapture() const override
Returns if this view module can support image capture.
Definition:
pqContextView.h:76
