| vtkMultiProcessController * | NewConnection (const char *url) override |
| | Creates a new connection given the url. More...
| void | AbortPendingConnection () override |
| | Used to abort pending connection creation, if any. More...
| int | ProcessEvents (unsigned long timeout_msecs) override |
| | Process any network activity. More...
| bool | GetNetworkEventsAvailable () override |
| | Peeks to check if any activity is available. More...
| bool | GetPendingConnectionsPresent () override |
| | Returns true is the manager is currently waiting for any connections. More...
| virtual void | DisableFurtherConnections (int port, bool disable) override |
| | Enable/disable further connections for given port. More...
| virtual bool | GetWrongConnectID () override |
| | Returns true if the last check of connect ids was wrong. More...
| | vtkTCPNetworkAccessManager () |
| | ~vtkTCPNetworkAccessManager () override |
| int | ProcessEventsInternal (unsigned long timeout_msecs, bool do_processing) |
| vtkMultiProcessController * | ConnectToRemote (const char *hostname, int port, const char *handshake, int timeout_in_seconds) |
| | Connects to remote processes. More...
| vtkMultiProcessController * | WaitForConnection (int port, bool once, const char *handshake, bool nonblocking) |
| | Waits for connection from remote process. More...
| int | ParaViewHandshake (vtkMultiProcessController *controller, bool server_side, const char *handshake) |
| void | PrintHandshakeError (int errorcode, bool server_side) |
| int | AnalyzeHandshakeAndGetErrorCode (const char *clientHS, const char *serverHS) |
| | vtkNetworkAccessManager () |
| | ~vtkNetworkAccessManager () override |
| | vtkObject () |
| | vtkObjectBase () |
vtkTCPNetworkAccessManager is a concrete implementation of vtkNetworkAccessManager that uses tcp/ip sockets for communication between processes.
It supports urls that use "tcp" as their protocol specifier.
Definition at line 31 of file vtkTCPNetworkAccessManager.h.
This call may block until the connection can be established. To keep user-interfaces responsive, one can listen to the vtkCommand::ProgressEvent fired periodically by this class while waiting.
vtkNetworkAccessManager can be waiting for atmost one connection at a time. Calling NewConnection() while another connection is pending will raise an error.
To abort the connection and cancel the waiting, simply call AbortPendingConnection() in the vtkCommand::ProgressEvent callback.
Returns the new connection instance on success, otherwise NULL.
URLs are of the following form: <transport>://<address>
tcp://<hostname>:<port>
tcp://localhost:<port>?listen=true& – listen for connection on port.
tcp://localhost:<port>?listen=true&multiple=true – listen for multiple Examples:
tcp://medea:12345
tcp://localhost:12345?listen&handshake=3.8.12 Supported parameters: handshake :- specify a message that is matched with the other side listen :- open a server-socket for a client to connect to multiple :- leave server-socket open for more than 1 client to connect (listen must be set to true) nonblocking:- When listen is true, this will result in the call returning NULL if a client connection is not available immediately. It leaves the server socket open for client to connect. timeout :- When connecting to remote i.e listen==false, specify the time (in seconds) for which this call blocks to retry attempts to connect to the host/port. If absent, default is 60s. 0 implies no retry attempts. A negative value implies an infinite number of retries.
Implements vtkNetworkAccessManager.
