| int | IsInDomain (vtkSMProperty *) override |
| | Returns 1 always. More...
| void | Update (vtkSMProperty *requestingProperty) override |
| | The SIL may have changed. More...
| vtkSubsetInclusionLattice * | GetSIL () |
| | Returns the vtkSubsetInclusionLattice. More...
| int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| | Overridden to set default from SIL. More...
Public Member Functions inherited from vtkSMStringListDomain |
| int | IsInDomain (vtkSMProperty *property) override |
| | Returns true if the value of the property is in the domain. More...
| int | IsInDomain (const char *string, unsigned int &idx) |
| | Returns true if the string is in the domain. More...
| const char * | GetString (unsigned int idx) |
| | Returns a string in the domain. More...
| unsigned int | GetNumberOfStrings () |
| | Returns the number of strings in the domain. More...
| void | SetAnimationValue (vtkSMProperty *, int, double) override |
| virtual char * | GetNoneString () |
| | Return the string that is used as "none_string" in XML configuration. More...
| virtual void | SetNoneString (const char *) |
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| | vtkSMSubsetInclusionLatticeDomain () |
| | ~vtkSMSubsetInclusionLatticeDomain () |
| int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) override |
Protected Member Functions inherited from vtkSMStringListDomain |
| void | ChildSaveState (vtkPVXMLElement *domainElement) override |
| virtual void | SetStrings (const std::vector< std::string > &strings) |
| | Call to set the strings. More...
| const std::vector< std::string > & | GetStrings () |
| | vtkSMStringListDomain () |
| | ~vtkSMStringListDomain () override |
| | vtkSMDomain () |
| void | DomainModified () |
| void | InvokeModified () |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
domain for block selection properties using a vtkSubsetInclusionLattice.
vtkSMSubsetInclusionLatticeDomain is the domain to use for a vtkSMStringVectorProperty permitting uses to select blocks with structure described using vtkSubsetInclusionLattice or subclass.
vtkSMSubsetInclusionLatticeDomain replaces vtkSMSILDomain. vtkSMSILDomain is available for old-style readers that have not been updated to produce vtkSubsetInclusionLattice and instead simply generate a vtkGraph for representing the SIL.
Example Server-Manager configuration XML
<StringVectorProperty ...>
<SubsetInclusionLatticeDomain name="sil" class="vtkCGNSSubsetInclusionLattice"
default_path="//Grid">
<RequiredProperties>
<Property name="SILUpdateStamp" function="TimeStamp" />
</RequiredProperties>
</SubsetInclusionLatticeDomain>
</StringVectorProperty>
Supported Attributes
vtkSMSubsetInclusionLatticeDomain supports that following attributes that can be specified in the XML configuration for the domain.
class attribute
vtkSubsetInclusionLattice is the default, if not specified. However readers often create subclasses for vtkSubsetInclusionLattice that make it easier to identify nodes in the SIL using native terminology for the file format e.g. vtkCGNSSubsetInclusionLattice. To indicate to the domain to create a specific subclass, one can use the class attribute.
default_path attribute
default_path attribute can be set to a string that defines a path to use to select nodes by default. If not empty, same as calling vtkSubsetInclusionLattice::SelectAll during initialization to pick default block selection state.
Supported required properties.
vtkSubsetInclusionLattice depends on a required property with function TimeStamp which is an information_only property of type vtkSMIdTypeVectorProperty. This property indicates a time-stamp for when the SIL was rebuilt by the reader. This is used to limit fetching of SIL from the server only when it has changed.
- See also
- vtkSMSILDomain
Definition at line 82 of file vtkSMSubsetInclusionLatticeDomain.h.
