| int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| | Returns 1 if the domain updated the property. More...
Public Member Functions inherited from vtkSMStringListDomain |
| int | IsInDomain (vtkSMProperty *property) override |
| | Returns true if the value of the property is in the domain. More...
| int | IsInDomain (const char *string, unsigned int &idx) |
| | Returns true if the string is in the domain. More...
| const char * | GetString (unsigned int idx) |
| | Returns a string in the domain. More...
| unsigned int | GetNumberOfStrings () |
| | Returns the number of strings in the domain. More...
| | Update self checking the "unchecked" values of all required properties. More...
| void | SetAnimationValue (vtkSMProperty *, int, double) override |
| virtual char * | GetNoneString () |
| | Return the string that is used as "none_string" in XML configuration. More...
| virtual void | SetNoneString (const char *) |
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| | vtkSMRepresentationTypeDomain () |
| | ~vtkSMRepresentationTypeDomain () override |
| vtkPVDataInformation * | GetInputInformation () |
| | Returns the datainformation from the current input, if possible. More...
Protected Member Functions inherited from vtkSMStringListDomain |
| int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| void | ChildSaveState (vtkPVXMLElement *domainElement) override |
| virtual void | SetStrings (const std::vector< std::string > &strings) |
| | Call to set the strings. More...
| const std::vector< std::string > & | GetStrings () |
| | vtkSMStringListDomain () |
| | ~vtkSMStringListDomain () override |
| | vtkSMDomain () |
| void | DomainModified () |
| void | InvokeModified () |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
domain for "Representation" property on representations in "RenderView".
vtkSMRepresentationTypeDomain is designed to be used as the domain for "Representation" property on representation proxies in the "RenderView". It extends vtkSMStringListDomain to add logic to set default values based on the input data information.
Supported Required-Property functions:
Input : (optional) refers to a property that provides the data-producer. When present will be used to come up with default representation type using data information.
Definition at line 39 of file vtkSMRepresentationTypeDomain.h.
